SD-P5181 Pioneer Projection Monitor Receiver Picture does not work, however audio works when plugging in my playstation II.
  • Anonymous Jan 10, 2009
    have a 1992 Pioneer SD P5047. Sound just stopped. I unplugged, replugged. the speakers are set on ext which is they way it's been set up for years. Any other suggestions before I have an expensive repair guy come out.
My pioneer projection monitor receiver sd-p5181 has something wrong with the srceen it works but it is blurry and has double the picture how do I fix it
Posted on Mar 20, 2011
Video in not working
When you plug the AV cables into the receiver make sure that the channel that it is plugged into is selected on the front of the receiver. Also note that the receiver should have a monitor output that should be plugged into the TV and the TV input must be selected on the TV.
Jan 31, 2014 | Sony STR-DH540 5.2-Channel Home Theater...
Blue convergence will not align...model SD-P5181
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Have got sound through all devices plugged in however no picture. Using video cable (Yellow) and red/ white audio. Have got yellow plugged in monitor out....
your video source (cable box or Blu-ray or satellite box) has to be plugged into a proper video (yellow) input on the Pioneer A/V receiver and you must select on the TV, the video input where the yellow video cable is plugged in from the Pioneer A/V receiver (use TV remote). Also select on the Pioneer which source component you want like the cable box or whatever. Check cables for quality. Swap RCA video cables to see if cable is bad. Try new video cables. May need to adjust a user setting on the Pioneer A/V receiver. Make sure cable box or whatever is plugged into the yellow video input for that component you are selecting on the Pioneer.
Mar 27, 2011 | Pioneer VSX520 Receiver
Pioneer SD-P5181 will not power up
pioneer sd p5181 will not power up redlight on stand by works when i hit the power button makes a funny sound and then nothing anyone plz!!!! help thnks
Jul 11, 2009 | Pioneer Televison & Video
How to hook the thing up and can it be hooked to a home computer
IN regards to your problem of how to hook up your receiver you have know how many components your hooking up to it and whether or not you are using standard analog(red & white), or you are using digital (optical,coaxial or HDMI). Next you need to decide if you are going to use your receiver for all your video picture. If so you just match video input with your audio inputs plugs on the back of the receiver. Then monitor out of receiver to TV.In regards to hooking up you computer to your stereo you need to take audio out of your computer(where speakers are currently plugged in) and plug that into an open slot on your receiver youll need an audio cable that has a headphone plug to RCA ends I picked video 3 on mine because I have nothing plugged in there and just ran monitor out of my computer to the TV.
May 27, 2009 | Pioneer VSX-D108 Receiver
Picture is green and stays green
check the convergence area for bad solder connection
Sony Convergence
Aug 19, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Picture on my rear projection TV
Your set will one day soon not come on at all. theres several capacitors on the PIP board if your set has PIP or the capacitors in the power supply. A good tech should know where to check as this set some say is hard to work on but i quess its like anything you work on for a bit gets easyer. Call an authorized repair center for pioneer. Good Luck
Aug 13, 2006 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
374 people viewed this question
Top Televison & Video Experts
