Question about Cannon Office Equipment & Supplies
Canon mx700 can i use the rear verticle paper feed as an alternative to the front bottom horozintal paper feed
Yes, use the "feed switch" button on the front of the printer. There are small lights that indicate the paper tray to be used.
Posted on Mar 13, 2009
Printer eror code U051
Instructions
    • 1
      Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
    • 2
      Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
    • 3
      Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
    • 4
      Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
    • 5
      Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
    • 6
      Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
    • 7
      Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
Mar 07, 2012 | Canon MX700 Office All-In-One InkJet...
Message says no paper in front tray. Paper is where I've always put it in back. Won't print.
go print -> properties -> page setup -> print options -> tick Disable the paper source setting of the application software -> hit ok and go back to "main" -> select the paper source that you want and hit ok ok and print
Nov 20, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Have a mx700 canon that has error code 6000 is it just becuz im out of ink
no it not because your out of ink, it's a paper feed problem caused by some thing blocking the paper feed. look in all the hole see if you can find it if not it's a repair man time. that all i can tell you as im having the same prob and that what i've beeen told
Jul 05, 2010 | Canon MX700 Office All-In-One InkJet...
Misfeed from the rear tray. The rear tray feed is not working. When it tries to feed it bends the right corner of the paper and then I get a misfeed message. I can't use the printer to print 4x6 photos...
there could be a teenie piece of paper stuck in the feed path causing this to happen, you have to visually inspect and ensure it is clear. Use plain paper to test.
rollers may also contribute to problems with feeding paper its good you tried that too.
lastly maybe the photo paper is too thick for that printer?
Apr 11, 2017 | Canon PIXMA MX700 All-In-One InkJet...
The MX700 will no longer feed from the bottom. It does want to grab the paper but only gets anout 1/8 in and makes a weird noise when trying to continue. Feed from the back is fine. This seems to have...
Ok dont exced the normal paper typeing Like thickness( you need to read your brochure
and check for acceptable thickness and paper class
The bottom is normally a reserve tray for paper
Oct 19, 2009 | Canon MX700 Office All-In-One InkJet...
Canon MX700 - Error msg: Paper Output Slot - Paper Jammed. There is no paper jammed in the machine but I get the msg anyway.
1) Is there a way you can check if there is paper jammed other than looking in the front of the printer, maby the rear or bottom prehaps?
2) Try this link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651
3) Contact your printers manufacturers website.
Oct 14, 2009 | Canon MX700 Office All-In-One InkJet...
My Canon MX700 printer prints crooked--did the maintenance too!
Try printing from the rear tray. My printouts from the bottom tray come out crooked, but the ones from the rear tray seem fine.
Mar 01, 2009 | Canon MX700 Office All-In-One InkJet...
Not reading paper
If you toggle the Feed Switch button (lower left side of control panel) to the Front Tray, does the printer print then? What type of paper is selected in your Printer Settings on the computer? I think that if you have selected anything but Plain Paper, the driver wants you to load the paper (photo paper, etc.) in the Rear Tray.
May 20, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon mx700 printer
Using a q-tip clean the rollers with rubbing alcohol.
Try different paper. The fact that it grabs more than one page means the paper or rollers are dirty.
Mar 05, 2008 | Canon MX700 Office All-In-One InkJet...
56 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Victorman
Victorman
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
