Compaq Pressario Desk top 5333 5000 series PC
The audio system is is totally down and do not hear any audio through
other things are ok This was bought in 2001. As per your advise I had already paid $ 9.99- thgough my master card credit card I am waiting for your advise and solution. Please whebn will it be received and where.
Palanivelu Tandalam
    Genius:
  • 1,124 Answers
1.- Your audio was working fine before?
2.- Did you install any program?
3.- It Is your sound card connected? Go>>My PC>>Properties>>Hardware>>Device Manager (see if the sound card and drivers are installed and working properly)
4.- Your speakers are connected in the right way? Are they ON?
5.- In the control panel >>Sounds>> "mute" must be UNCHECKED
If your audio was working fine before some of above reason are blocking your sound
Posted on Sep 24, 2008
Need help connecting to PC
You need adapter cable 3.5mm mini stereo plug to double RCA plugs (one red, one white). Plug 3.5mm end into headphones/audio out socket on PC, RCA plugs to AUX IN sockets on rear of SA-222, select AUX on front of SA-222 to hear audio from PC through system speakers.
May 03, 2017 | Panasonic Technics Sa-222 Receiver
I wants download audio driver
To download audio driver for your laptop you need to search the driver. Search the model of your laptop in Google and you shall find all the drivers for this laptop. For Example, if you laptop is COMPAQ PRESSARIO 769 US, then search for
"Drivers of Compaq Pressario 769 US for Windows 7".
Nov 01, 2012 | Samsung Computers & Internet
Just bought an RCA RTD317W home theater system. Put in a dvd and the previews sound ok,but when the movie starts I can barely hear the speaking part
Barely or not at all?
The previews are almost always in a format-neutral audio track, like stereo. Once the feature starts you're usually listening to a multichannel soundtrack.
The dialog of a movie is usually carried on the center channel. Check to make sure you can hear and adjust test tones on all speakers per the manual first.
Jul 12, 2011 | RCA RTD317 Theater System
We have an HCL desktop computer. Though we had loaded Ac97 Sound Driver still the sound is not coming (totally soundless) Can you suggest what to do?
Try to download and save the Audio Driver and then Run it to overwrite the Drivers and then restart right away. Make sure that you select the right operating system. Normally when you restart, you'll already hear the sound for shutting down and the welcome sound.
http://www.realtek.com.tw/Downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
Then try to play the sample music using Windows Media Player. Try to use a headset if there's one available. If it's still quiet,
Note: you'd need a sound blaster or any desktop speaker to be able to hear any sounds. But if there's already a speaker built-in, then it that means the speakers are defective.
Hearing a beep is not the speaker you use to hear the music.
Hope this helps.
Jan 20, 2011 | Computers & Internet
What is the total WATT output on the Sony MHC-G101 mini hi-fi 3 CD changer, dual cassette home component system? I misplaced the owner's manual, and I want to know how much power it has. // Tks
According to page 24 of the manual, it delivers 11 Watts RMS (route mean squared) per channel into 8 ohm speakers.
Elsewhere in the manual, you'll see references to "15 watts per channel" and as much as "25 watts per channel". The 15 watt value is valid when putting up with some 10% THD (total harmonic distortion), this value is 11 times higher than the .9% THD value given for 11 watts per channel. You tolerate .9% THD now, but you wouldn't want to listen to anything with 10% THD. The 25 watts per channel is what they call "Music Power". Watts is an electrical term, "music power" is not. You could use it to compare other devices that only offer "music power" values, but the best indication of how it will perform is based on watts in RMS, into an 8 Ohm load (most speakers are 8 ohms). The lowest THD values are best.
From the manual:
AUDIO POWER SPECIFICATIONS
POWER OUTPUT AND TOTAL HARMONIC
DISTORTION:
With 8 ohm loads, both channels driven, from
70 - 20,000 Hz; rated 11 watts per channel
minimum RMS power, with no more than
0.9% total harmonic distortion from 250
milliwatts to rated output.
I hope this helped!
Nov 23, 2010 | Sony MHC-G101 Shelf System
My compaq pressario wont start up windows vista, it only appears a black screen with different commands
That is the boot option screen - if you can't get past it then Windows is totally corrupted and the only thing you can do is to reinstall it.
Nov 05, 2010 | Computers & Internet
How many total watts does this system have
Well... It consumes 240 watts of electrical power total so take the audio power specifications with a huge grain of salt, as no audio device puts out in audio power anywhere near what it consumes in electrical power. Heat produced is power consumed, too and nothing is 100% efficient.
In the specs below the only information useful for comparison is in the line I highlighted with >>> <<<<'s as it conforms the closest to the industry standard practice of using:
"X watts into 8 ohms (standard load) from 20 - 20000 hz plus or minus Y db at no more than .0Z% distortion"
The better amps specify vanishingly low distortion specs (0.0x% vs 0.x%) at the cost of being able to claim higher wattage. But they guarantee cleaner sound at the claimed levels.
JVC is being tricky with their choice of a 40 hz lower limit. THAT is the power hungry end of the spectrum. 20 hz is normally the lower limit stated.
"Output Power .............At Stereo operation
Front channels .............55 watts per channel, min. RMS, driven into 4 ohms at 1 kHz, with no more than 0.9 % total harmonic distortion. (IEC268-3/DIN) 30 watts per channel, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.9 % total harmonic distortion. (IEC268-3/DIN)
>>>>> 30 watts per channel, min. RMS, driven into 8 ohms, 40 Hz to 20 kHz, with no more than 0.8 % total harmonic distortion. <<<<<
At Surround operation
Front channels .............50 watts per channel, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.8 % total harmonic distortion.
Center channel .............50 watts, min. RMS, driven into 8 ohms at 1 kHz, with no more than 0.8 % total harmonic distortion.
Rear channel .................50 watts, min. RMS, driven into 8 ohms at 1kHz, with no more than 0.8 % total harmonic distortion."
Mar 02, 2010 | JVC RX-554V Receiver
I tried viewing a tv program on line and for some reason there is no sound coming through my X-540 speaker system. I checked the power and connections and they all seem OK. I'm running Vista on a Dell 9200...
Here is a solution : On desktop go to ::
my computer----mouse right click----properties----system----device management. There you can find symbols for all devices that are already installed on your system . Scroll down until you find the definition of your audio device software , for example , if your audio driver software is a realtek then right mouse click on it , then you'll find disable , just disable it and then uninstall the audio driver software ! After that you should restart your system . When system started again , install the software again , and restart the system once again . Now you should hear the operating system starting tone .. If you didn't hear the tone , then go to device management again and enable the audio device once again .
good luck . rate if useful please !
Jan 27, 2010 | Logitech X-540 Computer Speakers
Computers & Internet Logo
David Payne
David Payne
