Question about Acomdata HybridDrive E5 Hard Drive
My Mac Won't Mount My Acomdata E5 Firewire External Hard Drive
My PowerBook G4 was having some problem so I restarted and when I did the Acomdata drive didn't mount to my desktop- I've tried using StellarPhoenix for Mac - it is able to get into the drive and create a tree of file types but when I recover the files as raw data most of the actual files are missing or in the case of photos are sometimes just thumbnails- any advice?? There is a lot of stuff on this drive that I really need to recover
  • dmsnyc10 Sep 24, 2008
    I've tried using StellarPhoenix recovery software, it didn't work- the software you are suggesting is for a PC- I'm on a Mac
    Genius:
  • 1,847 Answers
There are many recovery software available online.
http://www.recovermyfiles.com/
Posted on Sep 24, 2008
Want to free up space on my internal hard drive (Apple PowerBook G4) without
Mac do not waste space, I recommend you to use an external hard drive. Try to find one with twice capacity that your computer's hard drive.I mean, if your computer hard drive is 500Gb, then find an external drive with 1Tb
Oct 01, 2012 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Another waterlogged 12" PowerBook story
Sounds like you have done all you can. The hard drive should be ok and still work in an external case so you can transfer the data to a new machine. Good luck!
Feb 19, 2010 | Apple PowerBook G4 Mac Notebook
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Mac External Connection
Easy, FireWire.
Connect the 2 with a firewire cable. If reading off the laptop, for example, reboot it & hold the T key down while it boots up. A large firewire symbol shows on the screen indicating FireWire Target Mode. The laptop should be showing up as a firewire drive on the other Mac.
Apr 05, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
MAC G4 won't boot - Blue screen appears
Hi Sorry to hear you are having troubles,You will need a firewire 400 cableOK, first thing you must do is reboot the eMac in TARGET mode, this means it will be recognized as an external disk. To get the eMac in TARGET mode, you must be sure the eMac is turned OFF and has a functioning keyboard connected.Power on the eMac and very very rapidly press the ( T ) key on the keyboard, be sure the caps lock button is not pressed. If all goes well, you will see the firewire logo appear larger than life on the screen.( If you are unable to get into TARGET mode, it is highly probable that the mother board of the internal hard drive is damaged and preventing the eMac from entering TARGET mode, sorry, that's the end of the line..)Once you enter TARGET mode on the eMac, connect the firewire cable to your G4 PowerBook, you can do this either while it is running or when it is off and then turn it on.
You should see the volume of your eMac internal hard drive appear on the PowerBook desktop...sometimes you need to open Disk Utilities and repair or mount the drive manually.If this all works well, copy the required files directly to your PowerBook...After that, power off both machines, disconnect them and reboot the eMac using a CD or DVD to reformat and reinstall a new system.
Mar 30, 2009 | Apple eMac G4 Desktop
Running mac osx my acomdata external drive lights
This is the solution that worked for me.
Luckily I have another external drive of the exact same model that is working fine.
I used the power supply from the good working model and plugged it into the bad drive. The bad drive booted right up. Evidently the power supply was the issue, not the drive itself.
Even though the bad power supply had enough juice to light up the drive, it was not able to make the drive spin correctly.
Mar 25, 2009 | Acomdata E5 (HD250FE572) 256 GB Hard Drive
My external won't mount, the light works but it won't mount to my power book G4. help!
I opened up the harddrive and noticed that the copper magnetic film strip right above the USB port entry was lifted from the metal. I pressed it down and plugged the drive back in and it worked.
you just have to unscrew the drive on the 4 front side and two small ones on the side using two different phillips. then make sure and register the Western Digital drive inside because it has a seprate warantee. my acomdata is already out of warantee but if the drive ever fails again, I can have it replaced by Western Digital until 2011.
Dec 25, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Won't mount
Western digital drives ****! I'm having the same problem repeatedly. Seagate drives work fine though.
May 30, 2008 | Acomdata 500GB External Firewire HD 500 GB...
80 gb hard drive from apple pro book does not work
Try using Disk Utility to mount the drive. This can be found in the Utilities folder within the main applications folder. Launch Disk utility and see if the drive comes up in the list of drives down the left hand side. I presume that the hard drive in the enclosure is spinning. You can normally hear it, and feel a constant light vibration.
May 29, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Acomdata HybridDrive E5 Hard Drive Logo
293 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
