Question about Maytag Neptune MDE6700A Electric Dryer
Maytag Dryer med9700sqo
Dryer has absolutely no power. Control panel won't light up at all. Only the drum light comes on. 220v is fine. Any ideas?
    Problem Solver:
  • 5 Answers
You have thermal fuses that may have went bad. How long has machine been in use,and is your dryer venting all clear of lint and debris?
Posted on Sep 24, 2008
Bravo 2012 gas dryer control panel
I have the same dryer. My control panel went dead today too. Light in drum works just fine. Nothing working at all on the control panel.
Mar 07, 2014 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Control lights come on briefly, then turn off, dryer will not run
make sure your getting 220v from the receptacle . good luck APPLIANCES R EN
Mar 02, 2013 | Maytag MDE4806 Electric Dryer
No power. Checked 220V input - fine Replaced control board Replaced control panel board. Absolutely nothing.
check for main power at control board, if no power at board then cable/cord probably needs renewing
Jul 29, 2011 | Samsung DV218AEW Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do i remove the drum on a maytag top-loading washer.MAV 7000aww
If you want to remove the drum of your maytag wahser follow this procedure:
  1. Disconnect the power supply to the Maytag dryer by unplugging it from the wall outlet.
  2. Use a screwdriver to remove the three screws located at the top of the control console.
  3. Pull the control console forward to release the tabs that hold it to the Maytag dryer top. Maneuver the control panel out of your way without disconnecting any wires.
  4. Use a putty knife inserted between the top and front panel to disengage the retaining clips that secure the top panel of the Maytag dryer. Lift the top panel up, and remove it from the dryer.
  5. Use needle nose pliers to remove the wires from the door switch terminals. The door switch is located just inside the front right corner. Grasp the wire leads with the pliers and pull them off the terminals.
  6. Use a screwdriver to remove the retaining screws that hold the front and side panels together on the Maytag dryer. Lift the front panel up and out of the work area.
  7. Use a screwdriver to remove the Maytag dryer drum light lens screw. Press the locking tabs on the light socket, and remove it from the cavity of the drum.
  8. Use a socket wrench to remove the four retaining bolts that secure the drum bulkhead to the sides of the Maytag dryer.
  9. Reach your hand beside the drum and the motor, and push the idler pulley forward to release tension on the belt. Make notes of how the belt is routed on the pulleys, and then remove the belt from the motor pulley and idler pulley.
  10. Grab the belt with one hand, and the Maytag dryer drum with the other. Pull the drum out of the front of the dryer.
Jan 30, 2010 | Maytag Washing Machines
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Doesn't heat and dryer light no longer works
make sure you have power to BOTH legs of the 220v.
Feb 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Dec 19, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune MDE6700A Electric Dryer Logo
252 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
