Question about Epson Stylus CX5400 All-In-One InkJet Printer
Epson CX5400 Blue is coming out magenta. I changed cartriges and did a nozzel check. No help
  • 903 Answers
Take out the cartidge and see if there has been a leak. If there has gently clean away excess ink, then replace cartridge and clean the print heads
Posted on Oct 25, 2008
We have been given a CX5400 Epson printer. One of the cartridges (magenta) was missing. We then ordered compatible ink cartidges from our usual on line supplier - (internet-ink.co.uk). We found that two...
In Windows, click Start
Click Control Panel
Click Classic View
Click Printers
Be sure that the installed printer is listed as the 'cx5400' printer, not some other printer.
Talk to a different supplier, e.g., http://www.theinkshop.ie
in Ireland.
Sep 29, 2010 | Epson Stylus CX5400 All-In-One InkJet...
THe power comes on but thi ink cartrige wont slide over to load the ink. Ipressed ENGLISH and OK
You can always do it thru the utility.
click on start, click on printer n faxes
You will see your epson icon with a check mark, double click on that icon, click on printer tab, then slect printing preferences, printing preferences utility will come up. click on tab, Click on the Maintenance Tab as shown below, then select ink replacement icon. I have a red bullit on it for you to see. Follow thru to changing cartridges. It will move the ink station to the proper stop.
If you find this helpful pls rate me.
Thanks and Good Luck.
Mar 10, 2010 | Epson Stylus CX5400 All-In-One InkJet...
My magenta ink is out and the printer is showing error. Is there a way I can still print with my black and white cartridge.
in the epson cx5400 you can not still print pecause the printer sign red light on the ink the printer design stop from the factory for this now you change the all set not only magenta that is better because the printer make clean when you change and that take charge from the set ink I think you understand what I mean thank you
basher66
Dec 01, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epsonr220 does not print megenta or light megenta colors
The problem seems to be the printhead nozzels are plugged or burntout. I beleive on the Epson, to remove the printhead for cleaning, you must partially disassemble the printer. If you are not up for this, Quit here. If you game, remove the cartridges and tape over the outlet and air hole of each. I find electrical tape the best. Tape snugly but not too tight and once around the cart. If you have a digital camera or a webcam, take photos along the way to help in re-assembly. Remove the drive belt and disconnect the guide rod the printhead slides on at each end. Try and remove the guide rod and print head as one unit. Use alcohol and/or water to clean the print head nozzels, or completely wash the print head with running water. Blow it off and let dry. Put the guide rod back in the print head and put that assembly back in the printer. Attach the guide rod at each end then put the belt back in place. Put the cartridges back and do a nozzel/print head check. If the printer works completely, then you are set. If the magenta still doesn't work, the nozzels may be burnt out. I don't think you can get Epson Print heads, That means a new printer. Lastly DO THIS AT YOUR OWN RISK. I can't even guarantee my work!
May 28, 2009 | Epson Stylus Photo R220 InkJet Printer
Not printing - just replaced ink cartridges
Reseat the cartridges.
Do 3 consecutive head cleanings.
May 02, 2009 | Epson Stylus C84 InkJet Printer
Checking ink levels how do i do this
Install the status monitor, it's usually on the epson cd it comes with
but if you don't have it go HERE
Mar 21, 2009 | Epson Stylus Photo 870 InkJet Printer
Epson c88 how print in magenta
Do you mean "how do I print text in Magenta instead of black". Well, you change the colour of the text from black to magenta. For example in Word, you would select (highlight) all the text, click on Format, then Font. Then click on the down arrow at the side of the Font Color box, then click on Magenta. To check you have the right colour, click again on the down arrow at the side of the Font Color box, and select More Colors. Then click on Custom. Magenta has a Red-Green-Blue value of 255-0-255. Now print the document and it will come out with magenta text.
If this is not what you want, please come back with a new comment explaining further.
If this advice has been helpful, please rate it.
Jan 30, 2009 | Epson Stylus C88 InkJet Photo Printer
Cx5400 printer will not access the magenta color
Sorry. You have a clogged printhead. A new printhead from Epson cost 114.00. Plus labor.
Aug 08, 2007 | Epson Stylus CX5400 All-In-One InkJet...
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
