Question about Car Audio & Video
My Sirius sat radio stopped playing. I have a 2006 Toyota Camry with the factory option Sirius, installed at the dealer. Stopped playing Sept. 10th, same day Sirius sent a signal to upgrade sound quality for some receivers. I called Sirius 4 times to have them try sending a signal, and they've had me try the power-boost procedure with the key and the car door. This radio is mounted under the passenger seat it says "Sirius connect" on top, and connects to the factory JBL with in-dash 6 cd, and cassette. The antenna is mounted to the inside of the windshield. When I select Sat, I see channel 185 and I can't tune to any other. All other audio functions are fine, just no sound and no tuning on Sat. I've tried diconnecting my neg battery cable, and have disconnected the Sirius connect box. I'm sure that Sirius downloading a software upgrade (if that's what they did) caused this, but they claim they won't pay for any repairs. Anyone experienced this before?
  • 6 Answers
SOURCE: getting reset 8
Be sure to check and make sure that your option output is selected to other, and not cd changer, and reset the unit.
Posted on Feb 06, 2008
SOURCE: Radio Antenna Adapter for Sirius radio add-on
Brought problem to my trusted auto mechanic and he found a simple disconnect/connect where to antenna cable comes into car under front right side under the glove box. It took literally 30 seconds to do.
Posted on Jun 19, 2008
emissionwiz
  • 77169 Answers
SOURCE: 2006 toyota camry JBL radio; controls don't work
THIS IS A RADIO PROBLEM, THIS PROBLEM WILL REQUIRE THE RADIO BEING SENT OUT TO AN AUTHORIZED FACTORY ELECTRONICS REPAIR CENTER, THERE IS NO BLOWN FUSE OR THE RADIO WOULD NOT EVEN TURN ON.
Posted on Dec 05, 2008
SOURCE: Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
My DX445 does the same thing. Here's my method for fixing it, it should work for any similar Clarion receiver:
1. If possible, make sure the radio is turned off when disconnecting the battery. If the radio turns itself on when the vehicle is restarted (for example after jump starting or battery disconnect for a few seconds only), turn the radio off.
2. Disconnect the battery by removing the negative battery cable from the battery. Leave it disconnected.
NOTE: Car batteries can be dangerous things. If you're unsure how to do this safely, get an experiences mechanic to help you.
3. Reset the radio. On my radio this is done by removing the faceplated, and pressing a tiny button for 30 seconds. Your radio may be different.
4. After waiting at least 20 minutes, reconnect the battery.
5. My radio displayes 'System Check -- Press Power'. After pressing the power button, the display reverts to the clock.
6. Turn on the radio. It should work fine on the broadcast bands.
7. Select 'Sirius'. The radio should display 'Updating'. Don't touch anything until the radio finishes its update phase. When it's done, it should tune to Sirius channel 1 and play as normal.
8. This should restore normal tuning. reset your presets and preferences.
What seems to happen is that the radio gets stuck in a 'Category Select' condition, but not all the categories will load, and manual tuning will not allow, say, Radio Classics to play when the radio is stuck in Pop mode.
On occasion (maybe 1 time out of 10), the radio hangs while doing the 'updating' in Sirius mode. If this happens, just shut off the radio and start over. I've never had to do the brute force reset more than twice since I stumbled on this method.
Posted on Dec 09, 2008
  • 164 Answers
SOURCE: 2001 Lexus LS430 6 Disk CD Player ''CD ERROR''
The sixth place is where the cd that was being played has to be put before it can take another cd to play. there should be a reset button some where im not sure where yet but I will find out and let you know shortly.
Posted on Sep 01, 2009
Toyota sat nav dvd stop watch when brake on
only?
explain that.
and SAT is whole other ball of wax.
Feb 18, 2014 | Toyota Corolla Cars & Trucks
Camry Hybrid Satelitte radio does not work. AM is only option
I dono but it sounds like your subscription has expired for sat radio
Oct 05, 2009 | 2009 Toyota Camry Hybrid
2006 vw jetta gli sat radio, sirius expired, now want xm
U can't change the provider, the radio's are built to recieve sirius or xm, u can't have both on the same radio.
Jun 13, 2009 | Car Audio & Video
How to hook up the sirius stratus 5 radio in my 2008 rav4?
I have sirius installed in my 2008 RAV4 JBL system.
There is an adapter made by VAIS technologies http://www.vaistech.com/ that is called a soundlink. It comes with instructions for the connection. The Sirius radio is hidden in this installation, and is controlled by your JBL system. The antenna runs up the side of the windshield (hidden behind the plastic moulding) and mounts to the top right corner of the roof.
HOWEVER- you will not have the full funcionality of the Stratus 5 radio- which has more funtionality that the JBL system can control. Also, the Scrolling feature on the Stratus 5 screen does not work on the JBL display. . . you get the first 15 or so characters, with no scrolling.
I love having an integrated satelite radio in my car, but I do miss the better screen, and the pause feature I had on my sportster (in my old car). Good Luck.
Dec 25, 2008 | 2008 Toyota RAV4
2006 factory dodge radio sat quit working
soft reset. get in turn on truck with door shut turn on sat radio on ch 184. turn off radio turn off truck and take keys out. next open door fully for 90 seconds. shut door. turn on truck. turn on radio and have sirius reset it. its called a soft reset.
Dec 25, 2008 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Dec 05, 2008 | 2006 Toyota Camry
06 camry cd player
Other than replacing or repairing the radio, not much can be done. The dealer can send your out to be repaired, but buying an aftermarket radio is usually a better option. You can get a better sounding, nicer looking radio for cheaper than repairing yours.
Jul 03, 2008 | 2006 Toyota Camry
Antenna hookup 2007 dodge ram
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
Aug 15, 2007 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
