Question about Philips Senseo HD-7810 Coffee Maker
Pump doesn't pump
The start button heated the water and went through the full cycle. then the ring light quit blinking and the serve button was pushed. the pump started, but makes a subdued sound compared to the sound it makes when working properly. it sounds as though the pump is clogged. is there a procedure to clean the pump system? I do have the same problem.. do you think it's the pump?
    Genius:
  • 1,847 Answers
If the start button is getting heated then there is definitely an issue with the button, it could be a loose connection.
Posted on Sep 23, 2008
  • Legin Varghese
    Legin Varghese Sep 23, 2008
    You have to manually check and find the loose connection. Loose connection cause spark and hence cause heat.
Mr coffee problems
You didn't indicate a specific model. So, I'm going to assume yours is relatively the same as my JWX27.
Let me start by clarifying what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Jul 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
Water light is on ,Water tank is full but the light stays on
If the water tank stays full it indicates that the pump cannot function properly.
Before first use, the Sirena pump needs to be 'primed'. This is indicated by the blinking blue 'water' LED. On a new machine (or a refurbished one as in my case), empty the water container first, then
  • remove the plastic water container
  • activate the small spring valve mechanism built into the bottom of the water tank.
    This plastic valve mechanism could initially be hard to depress, because the small metal spring is too strong, or the entire mechanism may be stuck altogether. Exercise this spring and the small valve a few times (ok: 10 times).
  • once the spring-loaded valve moves freely (it becomes easy to depress with your finger), the pump will have no problem activating the spring mechanism and starts sucking water out of the tank:
  • refill with filtered water almost to the top and observe the floating magnet (fill indicator) now in its UP position. You will have to refill the water after a few shots and using steam.
  • Press the ON/OFF button and open the steam knob clockwise all the way until you can hear the pump working and a steady stream of water escapes... onto the floor, or if you're smart, into a small container.
  • Once primed, the pump can operate and in turn, the machine starts heating up.
  • Now you can make your espresso, and even try the steam wand after it shoots out a short stream of water. Once you have steam coming out of the wand, you can start getting serious about making your brew...
I believe that a lot of problems, like failure to heat up, machine doesn't work, etc. are caused by this small spring mechanism being a little hard to operate initially. The Sirena is programmed to operate ONLY if it can extract water out of the tank.
Try it and enjoy the superb cappucino, espresso, etc. -the beautiful Sirena was born in Italy and is a little temperamental, but will be your best friend with a little help in the mechnical department (Think FIAT). By the way: I am a German engineer -no kidding.
Sep 08, 2011 | Saeco Starbucks Sirena Espresso Machine
Tassimo Coffee Maker: Tell me how to operate it. I can fill the water, put the pod in and all the lights keep flashing. Pressing the start/stop button does nothing.
• All lights will blink the first time you turn on your
machine. This is your cue to prepare your machine for use by
following the quick instructions in Step 1 on separate insert.
• If the water level runs low while you are preparing a
beverage, all lights will flash. Simply remove and refill the
water container, and brewing will continue automatically
where it left off. It should not be necessary to discard the T-DISC
and start over.
• The AUTO light will blink throughout the brewing process.
Some drinks require a pause in brewing as part of the recipe
for brewing your perfect cup - this is to allow the optimal flavors
to unfold and is a normal part of the brewing process. The AUTO
light will continue to blink throughout this process.
HOW TO MAKE A DRINK
• Place the mug of your choice on the cup stand.
• When the STANDBY light illuminates, insert the T-DISC® of your choice
and close the clamp.
• The HEATING light will blink as the brewer heats the water to the
optimal temperature for your drink.
• Once the proper temperature is reached, the AUTO light will
illuminate. When it lights up, press the start/stop button to begin
the brew cycle.
• The AUTO light will continue to flash throughout the brewing cycle.
PLEASE NOTE: Some beverages have a pause in brewing
after the initial influx of water into the T-DISC®.
• The MANUAL light will illuminate when your drink is ready.
Jan 14, 2011 | Braun Tassimo Espresso Machine/Coffee...
Blinking power button
The power button blinks when it is heating the water up prior to use. It should switch off automatically when the water has boiled.
Aug 26, 2009 | Philips Senseo HD7820 Deluxe Single-Serve...
Starbucks Sirena. lights blink, won't heat.
johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Jun 10, 2009 | Saeco Starbucks Sirena Espresso Machine
Hi, cleaning cycle stalled, all lights on, machine stuck
We forced the mechanism!! Works like a charm!  I think we'll get a backup, the french press didn't cut it this AM.......
Feb 14, 2009 | Solis Palazzo Espresso Machine
Pump is not working
The reason could be the following.
You used your machine on a mains working with 50 cycles/sec. In U.S. frequency is 60 cycles /sec. this could alter the working of the oscillating piston in the pump. The impedance of the coil is somehow about 20% higher on this mains, reducing so current and power of the pump.
To be quite shure of this, try to fill the pump thoroughly with water.
(Disconnect machine from mains, use Low pressure hose , max 0,5 bar, tied to the inlet -where the water tank feeds-, and fill until water comes out of the open hood)
If now the same humming persists an no pumping effect is noticed, i even will be a bit wiser knowing that 60Hz is not good to 50 Hz pumps.
Jan 04, 2009 | Philips Senseo HD-7810 Coffee Maker
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
Dec 11, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
Pump doesn't pump
Yes, it is called descaling. Use a descaling solution, or vinegar and water, and follow the procedure for flushing your machine. After that, re flush it with plain water- nothing worse than vinegary coffee!
Sep 17, 2007 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
176 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
kenneth njonjo
Tom Chichester
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
