Question about Canon EOS-AE-1 35mm SLR Camera
Canon ae1 shutter button problem
The shutter button on my ae1 has been working intermitenly it seems like when its not working if i adjust the shutter speed it will work but i cant really tell for sure ive read some posts on here talking about the contacts on the bottom of the button is it possible that would be the problem with my cam and if so how hard would it be to clean or adjust
i changed the battery and that didnt seem to affect it also the contacts are clean
  • 48 Answers
It is possible dirty contacts but it sounds to me and I have run into this more than a few times you are moving setting the camera down picking it up sometimes all this moving it around can cause a cold contact solder joint. I hope this has been helpful. Jerry
Posted on Sep 25, 2008
    Genius:
  • 1,124 Answers
Usually cleaning the contacts becomes an effective solution, but if the problem continues take the camera to the service. All shutter problems requires professional care.
Posted on Sep 23, 2008
My canon AE 1 shutter is not firing, the button will press down but when I pull back to advance the camera it just won't work.
That is normally a classic indication of a failed battery. Try a new 4SR44 battery.
If you are absolutely certain that it cannot be the battery, then your camera is most likely in need of a full professional CLA service (Clean, Lubricate, Adjust). The internal lubricant films dry out over about 30 years of use and gum up the mechanism.
A professional repair costs far more than the camera is worth, and most repairers won't attempt this on your non-functional model unless you agree to pay up front due to the possibility of carrying out work only to find a more serious fault (unusual on the AE1 as it's well built, but still possible). Although the repair may not make economic sense, if it works then you'll have a camera which should be good for many more years and which can still produce results which will put a digital SLR to shame, especially if you shoot on transparencies and then scan them. Plus there's all those nice, cheap/free, used FD lenses lying around...
Oct 08, 2010 | Canon EOS-AE-1 35mm SLR Camera
My AE1 is malfunctioning. The shutter is being released when I advance instead of allowing me to expose the film with the shutter button.
Hmmm. Sounds like something internal is not engaging as it should. It probably is a plastic gear that has aged a little too long, and some of the teeth are broken off. Yes, this will need a trip to the repair shop. It's probably due for Clean, Lube and Adjust anyway.
Garryscamera.com and many others will repair this camera for you. Luckily, AE-1 was a great seller for Canon, so there are lots of spare parts out there. On Ebay, they are inexpensive and common. Buy one as a backup or parts donor, as they are old enough to start falling apart.
Apr 27, 2010 | Canon EOS-AE-1 35mm SLR Camera
Ae1 when i advance film the shutter releases abd takes a photo
You have bad mirror release magnet.
The magnet became weak and not holding the mirror so when you wind, the mirror goes up and takes pictures or releases the shutter by itself.
Canon AE1 program film advance locked
The cost of fixing is almost the same as buying a used or refurbished AE-1 about $80-120
Dec 21, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon AE1 Shutter Problem
It could be a simple issue with the shutter magnets, or something more severe with the electronics. What does the meter needle do when you push the shutter release down? With the speed dial set at 1/125 or higher and no lens, the needle should move fairly high. If it pegs to the bottom right away, that is a bad sign.
You can check the magnets from the bottom with the cover removed. (2 screws) You can release the mechanicals of the shutter by pushing the silver lever arm (located next to the plastic shield around the magnet on the rewind side of the camera) toward the front of the camera. Be mindful of the spring attached
Sep 17, 2008 | Canon EOS-AE-1 35mm SLR Camera
Takes a picture when film advance lever is moved
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
Sep 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Shutter squeal, Canon Cough a1 Ae1
This is in german. Look hard at the pictures. You only need to remove the bottom plate. Use a hypodermic needle loaded with just one drop of non-acidic oil. Practice first. Stick the battery back in an operate the shutter 30 times. leave the camera overnight upside down.
www.aldo-net.com/Canon/
Running the text through Babel will give you a good idea. It does work.
Bob-S
Sep 03, 2008 | Canon EOS-AE-1 35mm SLR Camera
AE-1 self timmer
The battery is not the problem. It is more likely the the internal switch has failed, (always stuck on self timer). The switch is a ring around the release button for the shutter. The small black tab covers the red LED in normal release mode, the self timer is on when the tab is facing forward.
Jun 01, 2008 | Canon EOS-AE-1 35mm SLR Camera
Meter on ae1 not working when aperture setting adjusted
On that camera the needle is not supposed to move when the f-stop ring is turned. It should stay on whatever number it is on and you should set the ring manually to whatever the needle points to.
That camera was really not made to be easy to use in the manual mode. I guess Canon thought everyone would just use it in Auto.
CameraRepairs
May 03, 2008 | Canon EOS-AE-1 35mm SLR Camera
Shuuer stuck down, lever wont advance
The Canon AE-1 has an electronic triped shutter and cocking system and requiires a battery to function. So yes the battery is required. Goog luck!
Aug 26, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
364 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
