I have a 3 year old 43pp92 philips rear projection 43" HDTV, just the other day the convergence went out of whack, I was able to converge the red and green pin cushions, however when i tried to converge blue, it lets me converge the ones closer to the middle, but Top right corner and Bottom left corners, the little crosses will NOT adjust up or down, just left and right. I am usually a 'do it yourself' person and not afraid on taking a chance destroying this TV and I'd like to fix it myself, any suggestions on what the problem with is, and/or how to go about fixing it
-   Bray, I was curious if you were able to fix your TV as I have the exact same problem with the exact same model. Any help you could offer would be greatly appreciated. Where do you order the convergence chips from? What site did you use to fix it? Thanks, BR -   brjackbauer
Best Solution
posted on Feb 13, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Large IC chips STK###-###, replace all of them, then converge. With back removed, these are away from yo centered in the set. attached to large heat sinks for cooling. .You must remove pcb from set and remove solder from theses ic's( about 22 pins each.) remount with new heatsink compound and re solder.good luck.
They sometimes blow out a couple resistors, if after replacing the IC's it still wont converge, you need to ohm out the large resistors near the IC's. Should have like 12 or so. If they look discolored and you cant read the #'s then replace them.
Was this helpful?
Yes
No
Popular Solutions for Philips 43PP9202 43 in. Rear
Hello I need some help and going way back with this model. I own a Philips Model#43PP92 0217 and the...
(More)
Hello I need some help and going way back with this model. I own a Philips Model#43PP92 0217 and the picture looks like its keeps rolling.. Any suggestions?
I have Same problem exactly with a 4 year old 43pp92 philips rear projection 43" HDTV,
just...
(More)
