Question about HP PSC 2410 All-In-One InkJet Printer
Printer Ink problem
When I print a page, from my computer , my priter prints all pages black and wet. can you please help me how to solve this problem? thanks very much.will be waiting for you response. thanks again....Maria
  • 1 more comment
  • malicha Sep 23, 2008
    My printer only prints everything black and wet of Ink/ please help me ?thanks again....maria
  • malicha Sep 24, 2008
    my oproblem is when I print a page from my computer it prints all black and wet pages. not able to read anything ? can you please help solve this problem???thanks very much Maria
    how you replace the head faulty , and how much is it ? to fixed? and where / please respond to my question? thanks again ...Maria
    Master:
  • 479 Answers
You have adjusted the print mode on BEST mode so make it NORMAL.thats making the prints wet .because in BEST mode the cartridges produce extra ink on the paper to make the copies dark.and also in the print settings change the settings to print only text in black.you had selected something else so its happening.
if still does not solves your problem just uninstall the printer driver and reinstall the driver again.as when you uninstall all the old settings will be deleted and when you install again all the new settings will be created automatically and the printer will work properly again as normal.
for any more suggestions reply us and keep us updated
Posted on Sep 24, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, if the printer is printing wet. It definitely means the ink catridge is faulty.
You have to replace the catridge with authentic HP catridge (try not using 3rd party catridges).
It should solve the problem.
Else, you may have to contact HP customer service to fix it.
cheers,
  • HP Master
  • 19,396 Answers
Start checking printer settings, ensure that the printer is set up to print on normal paper, not for example photo paper.
Try also setting printer to a lower resolution.
If this does not help try replacing the cartrdges and performing an head/nozzle cleaning procedure.
If it still does not work, then the printer head is faulty and must be replaced.
  • Ginko
    Ginko Sep 24, 2008
    In your model the heads are replaced with the cartridges.
    Try simply buying a new set of original cartridges.
    Before replacing cartridge, check if you see ink, clean the lower and the inner surface of the ink carriage with print head cleaner.
    If that does not solve the problem then you must replace the ink supply, below there is the link to the kit.This job is not easy and should be done by a technician.
    INK_SUPPLY_STATION
    Check first printer settings, eventually replace cartridges and set it to economy mode/fast print.
    Ensure that the stains are not from a dirty part inside, check the traction belt and around the carriage rail. If you find ink clean it with printer cleaning solution, see cleaning inkjet printers.
    If replacing cartridge and cleaning did not help call the number listed on the owner manual, and get a quote for the repair.
  • 10,594 Answers
How does it print Test Page?
  • Shahid Electronics
    Shahid Electronics Sep 24, 2008
    I need more info to understand problem of printer...
    Have you replaced its ink cartridge recently?
    Did you tried to print test page from its control panel.
    Please let me know.
    Please pull out and reinstall ink cartridges in printer.
    Here is procedure how to install Ink Cartridge in your printer.
Why won't my printer print more than 1 Page at a time?
Please go to your printer preferences and select page setup choose default setting and customize other page setup then click apply and restart your PC. If not done then follow the instruction.
1. uninstall your present printer driver.
2. Restart your pc.
3. Install your printer driver again.
4. Restart your pc.
Hope it will solve it.
Thanks
Apr 07, 2016 | Epson Stylus Photo R3000 Inkjet Printer
HP Printing, copying, faxing, scanning black pages
change the ink cartridge & get your printer serviced
Jul 18, 2010 | Office Equipment & Supplies
I installed the Lexmark z715 printer driver on my Mac and it is connected fine, but when you attempt to print documents, it prints blank pages instead. The ink cartridges are brand new. Please help me...
Ok, you need to clean the print heads they are probally clogged, what operating system are you using on your computer? I can walk you thru on what to do, very simple, if you have windows xp, do this: Go to start then all programs then go to your printer, there should be an option to align paper, clean print heads, print test page, you need to pick clean print heads, then after that print a test page, then if you see something printed but not good qaulity, clean print heads again....if this doesn't work you can take a damp cloth and wet and wipe under the ink cartilige where the ink comes out but is dried and clogged up until you see a rainbow streak of red, blue and yellow, be carefully not to wet any other part of cartirige, you can use a moist q tip if you want.
Jun 28, 2010 | Lexmark Z715 InkJet Printer
When i use Hp Laserjet P1007 to print, on my page occur repeat the words of overlap and Blur with ink on paper. please help me solve this problem ->contact me at email address:levinh2585@yahoo.com...
You either have a bad toner cartridge or have a problem with the fusing assembly. If it's the fuser will need to have the fuser replaced.
Here's how to tell which it is. Measure the distance from the original image to the first time it repeats on the page.
30.8mm (1.21") = toner cartridge
76.3mm (3.0") = toner cartridge
41.0mm (1.61") = fuser
56.5mm (2.22") = fuser
Hope that helps you. :)
Nov 15, 2009 | HP LASERJET P1005 Printer
Epson Stylus C86 smearing
Your printer has ink build up inside it. This comes from cleaning cartridges and builds-up steadily over time. Remove top cover. Wet a cotton swab with isopropyl alcohol (available at drug stores) and clean the inside. use a cotton bud where the swab gets entangled.
Aug 07, 2009 | Epson Stylus Photo 1290 InkJet Printer
LX-300 Printing Problem
go to the printer properties and set the correct paper size. printer and application paper size must match.
Nov 20, 2008 | Office Equipment & Supplies
Printing blank pages
fist of all uninstall your printer driver and affter then install printer driver again if problem not get fix
then change cartridge.
Mar 25, 2008 | Lexmark X1195 All-In-One Printer
Wont print in black.
hi,
check the ink level of the color cartridges also. because to print in black it will use some color also.
if everything is ok try this
> unplug the usb cable from the printer
> click on "start-->control panel--> printers and faxes".
> select all the printer icons which is related to your priter and delete it.
> once that is done, plug the usb cable back to the printer.
> wait for few minutes while it installs the driver automatically.
> if done, try printing in black from varius applications like notepad, wordpad, ms word etc.
> if o go, you may have to service the unit as you have already tried with 3 different black cartridges.
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 3210 Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 2410 All-In-One InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
