JVC GZ-MC500 Memory Card Camcorder Logo
Anonymous Posted on Oct 24, 2011
When turned on, says "memory card error! reinsert
Level 3:
  • JVC Master 17,130 Answers
  • Posted on Oct 25, 2011
JVC Master
Level 3:
Answers
17130
Questions
0
Helped
3631768
Points
52372
Remove the card from the camera and use the card reader on your PC to scan the memory card. It is possible there are errors on the card. If so format after copying all the files from the card. Now if the camera shows an error the fault is with an interface issue with the motherboard. make sure that the card holder tray is clean, blow air to dispel any dirt and also try with another card to confirm the case.
How can I solve my sony cyber shot camera modal DSC W630 is shows error as C13:01
This error indicates a memory problem.
The camera can't read or write data to the memory card. Try turning off and on the camera again, or take out and reinsert the memory card several times. Also remove and reinsert the battery.
It also can mean the memory card is not formatted, or there is a format error for an other reason. Format the internal memory or the memory card.
It also could mean the memory card is damaged and can't be used any more. Then you have to place a new memory card.
I hope something will help.
This is also in you user manual.
My problem, when I will take a photo, there is text "reinsert your SD memory".maybe sd memory is error or broken?
What model Sony camera? Is your memory card an SD card or an SDHC card? What size is the card?
We just received our brand new canon t3i in the mail. We formatted the card (a 2GB 700X Professional High Speed Error Free (SD) Memory Card Class 10) and immediately started shooting to test out the...
Sounds like there was an error while the camera was writing information to the card. You can try reformatting the card using a computer and a card reader, then replace it in the camera and format it from the menu. If that doesn't work and the camera is locked up you can try to do a "hard reset" by following the instructions on page 176 of the camera manual.
1helpful
2answers
When i open the camera "no memory card" will displayed, even if they had already memory card.
Check the memory card on your PC or on another phone so as to confirm the card. If it is not detected then replace as the card can have errors in the memory.
If not the camera control unit has faults and will need a probe within the unit.
It can be the fault in the interface of the processor.
2answers
How to fix "reinsert memory
Welcome to FixYa.
There 3 possible causes why do you received an error message " reinsert memory card"
Cause
1 The inserted Memory Stick media is not supported for use with the camera.
2 The terminals on the Memory Stick media are dirty.
3 The Memory Stick media is damaged
Resolution
1 Ensure you are using the supported type and capacity of Memory Stick media for use with the camera
2 Use a clean pencil eraser and lightly rub the Memory Stick terminals to remove any oxidation or dirt build-up
3 Use different Memory Stick media
I hope this steps wil help you to resolve your isuues.
Thank you for using FixYa.
Turn on the camera. "Memory Card Error" displays.
You'd better change a new memory card that doesn't have a problem to check whether it is matter of Canon PowerShot A480,or use another well camera to check if it is error of your memory card.
2answers
Says to reinsert memory card & card is in camera. Try another card & says memory stick formatting error
i have the same problem..
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
16helpful
2answers
Not reading memory card; keeps saying reinsert memory card, diplays error C 13
not reading memory card; keeps saying reinsert memory card, diplays error C 1
Aug 04, 2008 • Cameras
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
