Question about RCA 27R410T 27" TV
RCA model#27R410T Chasis#ITC008FAM 2003
My problem is that up until a couple days ago TV was doing perfect then all of a sudden it turns off,never could get it back on so I waited till the Next day and it was good for about 5 minutes then shuts off and will not come back on. All TV repair shops in my area has some kind of policy that states they can't fix TV's made after the year 2000 (which I don't understand) so any help please give I love this TV
techman
  • 3130 Answers
SOURCE: tv will not power up
no reset button ,sorry. The problem you describe is pretty common with this model as its a fault in the horizontal drive circuit or in the main power supply and without the proper service manual as well as the prober tools and equipment this set its not gonna get fixed. there are no panels or user changable boards as it is a solid state set. ptscorp.com could repair this board or exchange it with a referbished board but it would still requir some adjustment that a user may not be able to handle. time to call the pro.. Sorry couldnet help ya more.. Good Luck.
Posted on May 24, 2006
snakehead
  • 1074 Answers
SOURCE: RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Posted on Jun 04, 2007
VOTIT
  • 2071 Answers
SOURCE: rca tv turns off and on
This trouble has two common causes,the switch is shorted and the memory IC 24COxx is busted.If you bring this to a shop maybe they will cost you $300 plus.But if you have a knowledge of electronics,this will not cost you much.This problem is very easy you can do it yourself.Just open the back cover of your TV,then locate this 24COxx IC has 8 legs,it's better you use a magnefying glass,if ever you already located this IC.Desolder this IC take out from the board,then turn on the TV to see if the "on and off" problem if still there.If the problem is gone,you should buy this IC with identical rating.You can buy this in electronics store.This memory IC is blank you must ask the store where to program the memory IC or this is already have a program.We continue the troubleshooting,if the "on and off" problem is still there,then IC is good put it back (remember the marks of the IC so it will not interchange,this will cause to be shorted) Then next you do is to take all the switches / button,power,tv / video,volume up,volume down,channel up,channel down and menu button .These switch / button must not have no resistance,small amount of resistance can cause the trouble. It's better you change all the switch / button,im going to find a links for electronics store online..
Hope this may help you;
DON'T FORGET TO RATE;
Regards,
VOTIT
Posted on Sep 07, 2008
SOURCE: Turn tv on, shuts immediately off.
Same problem with my 28 inch 16:9 CRT Sanyo. I usually fix it by cutting the power to the outlet and then it works fine. Had it into the repair shop - and of course it never acts up there...
Posted on Jan 27, 2009
SOURCE: 27R410T 27" TV: our RCA Model 27R410T has maybe 20 hrs of total us...
Ok, well the good news is prize or NOT it is still covered by a warranty, that's the law, you need to contact your local RCA office, and ask them for a referral to an Authorised service center, and you will be able to make a claim, and in any event, that's where you are going to have to take it to be repaired in any event. The Consumer Act, indicates that anything sold must be of "Merchantable" quality, clearly any unit that fails after less than 24 hours use, falls into that definition. You simply have to find a Dealer, Service center, whatever, and in all fairness, they should take care of it, there may be some costs involved, but usually not. Below is a technical Service manual, this is what I use to train the engineers to repair these units, have a look, www.electro-tech-online.com/.../36401d1261034747-rca-32-television-32v434t-need-help-repairing-atc010_training_manual-1-.pdf
Posted on May 06, 2010
I have a rca model # 27r410t TV that has (3) (red,yellow,white) composit input. I purchased a Netgear NTV 300 streaming media player that only has HDMI output, What time cable do I need to make this w
Your TV has only A/V inputs. Red and White is to connect the audio outs of the streaming media, and Yellow for video. But here, your streaming media player have only HDMI output. That is, it is compactable only to TVs, which have digital inputs, where your TV has not. A converter [HDMI to A/V] in between the two devices will do it to work. There is no other chance.
Jan 24, 2013 | Televison & Video
I NEED EEPROM NUMBER
could you provide the ic designator for this item, please?
Feb 29, 2008 | RCA 27R410T 27" TV
Model 27r410t chassis itc008fam
What is the problem you faces with your TV? What is its model number? Brand? Provide these details please.
Jul 29, 2012 | Televison & Video
Hi, We have an RCA 27R410T that appears to have the ITC008 chasis. My son was watching the TV then the picture started to flutter and the color washed out. No more flutter but colors are washed out. Im...
Tv have video board problems.The tv video board main big colors inverter incoders IC it is dead.Must be replace and all those capacitors around IC should be tested and replace too.Fixed this problems before,but not as a CRT tube design for as a tv,but as CRT tube design for as a computer monitor.
Jun 15, 2011 | RCA 27R410T 27" TV
Stuck on 1 channel
Get a cable box from the cable company it will be cheaper than repairing the tuner. Then you use the tuner from the cable box instead.
May 07, 2010 | RCA 27R410T 27" TV
May 06, 2010 | RCA 27R410T 27" TV
Still can't get parental block to turn off on my RCA 27r410t. Have tried most of the steps found here on Fixya. Front panel is blocked also.
Unknown password-- ITC008 chassis with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
Feb 09, 2010 | RCA 27R410T 27" TV
RCA model P52927
Look, take out back cover and on the bottom left and right side you will see screw (2 or 4), take out it,Disconnect 2 plugs wire from chasis, pull out the box and you will have space for clean your screen.( You will take out all box with main chasis, convergence chasis )
Apr 22, 2008 | RCA P52926 52" Rear Projection Television
Help i want to fix it myself!!!
yes, you can but you need the right tools and follow the instructions, but you better think the cost to repair because,you'll need parts , tools. shipping expenses ,time to expend and guidance to do the job,just the tools and the parts you may need can cost to ,you no less than 100.00 if you want to try let me know
Jun 10, 2007 | RCA 32V420T 32" TV
Jun 04, 2007 | RCA 27R410T 27" TV
RCA 27R410T 27" TV Logo
120 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
