Question about JVC Audio Players & Recorders
I just purchased a L-A55 turntable. When I connected it I get very little volume. I max out the volume on the stereo and can hear it but not at a loud volume. Could this be the stylus? or maybe the phono cord is bad? I know this is an old unit but the shops want $50 just to bring it in.
Hi...I just picked up an L-A55 secondhand myself. To get the volume up to line level, you'll need to get a pre-amplifier. The one I ordered from Radio Shack just arrived today, and it works beautifully. You may also be able to pick up one from a local electronics or audio-video supply house. Here's the link to the pre-amp I bought.
http://www.radioshack.com/product/index.jsp?productId=2573420
Posted on Dec 09, 2008
No volume from turntable, even with volume turned to max, are ther internal fuses ?
You don't state which model the turntable is. Without this we are working blind. If the turntable has a built in amp then that will have failed. A blown fuse would shut down everything. If it has no built in amp and you have it connected to a separate amp, then you have either connected it to the wrong socket - it needs a phono socket - or if the amp doesn't have one you need a magnetic cartridge preamp.
Apr 12, 2013 | Audio Players & Recorders
Very little volumn no groun d on stereo - do i
I can't find a reference to the TT-01, but if it's an old school turntable you need to run it through a Phono preamp.
It would help to know what electronics you're using as THAT is where the volume comes from.
The TT should be connected to a specific PHONO input as it includes special preamplification for a Phono cartridge and frequency shaping for the way LP's are recorded (Google RIAA). I imagine it may sound pretty tinny as you have it now.
Aug 17, 2010 | Philips gemini TT-01 Turntable
Volume Level on Memorex 9299M 4-in-1 Turntable System Way Too Low
It's the nature of the all-in-one turntable beast to be low fi and low performance. Too much volume and vibration would feed back through the turntable.
It does have a Line Out that you could slave over to REAL electronics and speakers.
May 23, 2010 | Memorex Nostalgia Turntable and Stereo...
Faint sound slight buzzing
Connect it to the PHONO input of a receiver that has one or get a PHONO preamp and place it between the TT and your electronics.
http://en.wikipedia.org/wiki/Phonograph
May 21, 2010 | Stanton T52 Turntable
Volume output is low but is turned at Max on sterio
http://www.turntableneedles.com/Pre-Amps_c_4.html
you likely need a preamp between your turntable and the stereo. see details at above link.
Apr 21, 2010 | Gemini XL-100 Turntable
I PURCHASED A LIKE NEW TECHNICS SL BD27 TURNTABLE. I HOOKED THE RCA AUDIO JACKS TO THE AUDIO INPUT ON MY SONY TV AND GET VERY LOW SOUND LEVEL WHEN TV VOLUME CONTROL IS AT MAX. REPLACING CARTRIDGE AND...
Yes you need a pre amp
It would also be the same if you connected it to a computer to record an LP to CD. Mine is a little different and has one already built in that I can switch in and out of line.
Try spend a little more if you can as many pre amps can introduce noise.
You may also want to check that the turntable is properly grounded to prevent noise too
Oct 02, 2009 | Technics SL-BD22 Turntable
No sound when radio is turned on
i have the same problem with mine..did u ever find out how to fix it?
Jun 04, 2009 | Sony MHC-GX450 CD Shelf System
Little and poor quality sound from turntable
Turntables do not produce "line level" audio which is what is required for input into the AUX on the receiver. If you do not have a phono input on the receiver, you must purchase a phono pre-amp. These are readily available for about $20. This will boost the output of the turntable to line level so you can use the AUX input on your receiver. That will resolve the problem.
Dan
Feb 23, 2009 | Panasonic Audio Players & Recorders
Low volume and unbalanced deck
Turntables require amplification, they have very low output on their own. If your Sherwood has an Aux input try using that, older receivers often had a built-in pre-amp on the aux jack. You can obtain a stand alone pre-amp for less than $50, I use one from mcm, #40-630.
Dec 29, 2008 | Technics SL-BD22 Turntable
428 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
