Heating & Cooling Logo
A
Anonymous Posted on Jun 21, 2017
What's your problem? I have a Airtron furnace/air cond unit and last night I smelled a odor that of something electrical burning. I also noticed that the heating unit stayed on and continued to blow warm air throughout the house. The smell did go away but w/the thermostat set on 80 the furnace stays on and when the temp exceeds 80 degrees or more then the air would kick on and cool the house. Is there something wrong with my thermostat or what?
Peter
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Aug 28, 2022
Peter
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
157
Points
Recently I replaced a broken secondary fuse on the furnace and a thermostat for my Bryant Heating and Cooling System, and the LED showed a solid red light. However, when I tried to run the heating by turning the hermostat to auto, the LED turned off and there was a burning plastic smell, but the new fuse on the furnace and the new battery-powered thermostat, as well as the breaker for the furnace are still all intact. On the thermostat, I can only see A/C cool is on after switching to it, but after switching to heating, no sign was shown for it being on. Could you give me an educated guess as what could be wrong? Thank you!
Thomas Woodburn
Level 3:
  • Heating & Co... Master 2,638 Answers
  • Posted on Jun 22, 2017
Thomas Woodburn
Level 3:
Answers
2638
Questions
Helped
1251130
Points
7008
I'm willing to bet a relay burned up. You likely have your tstat set to auto changeover, meaning it automatically goes from heat to cool to maintain desired set points??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
4 Related Answers
Anonymous
  • 149 Answers
  • Posted on Jun 15, 2008
SOURCE: air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Donni Steen
  • 687 Answers
  • Posted on Mar 24, 2009
SOURCE: The furnace is blowing warm air even if the thermostat low.
The only thing that tells the unit to come on and off is the thermostat so I would definatly say it is it. When you turn the system back on, does the a/c run normally? If it does, then it's the problem with the heating side of the tstat. Also, does the fan come on when you put it to on and then turn of when you switch it back to auto? If it does, then the system is working fine, its the t-stat. Let me know if you have any more problems.
Anonymous
  • 2559 Answers
  • Posted on May 30, 2009
SOURCE: odor coming from furnace when running a/c
Sounds like your heating elements are coming on with the A/C This can be from an improperly wire thermostat or furnace.
Anonymous
  • 43501 Answers
  • Posted on Aug 23, 2010
SOURCE: My central AC is a York Diamond 80 (also my
One of the limit switch in the furnace is tripped or went bad....
Try to find all of the reset switches and push the little red button on the top to reset them...
If that don't work you will need to take an electric meter and test each switch to see which one is bad...
heatman101
EW30EW65SS Stainless Steel smells like burning electrical
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
2helpful
My electric furnace has a strange odor.
your coil may have dirty sock, the coil at air handler (evaporator) needs to be cleaned with coil cleaner that will mask or remove the dirty sock smell
When I run the air cond there is a unpleasant odor the we smell. The unit has not been used for a 3 years. Any thing I can do to get rid of the odor. can I clean something ? Change filter ? Ron
Definately change the filters, but im sure there will be an odor from sitting around. Clean the evaporator coil , not with high pressure wash, dont wanna damage the fins, they sell cleaners at HVAC suppliers. That should do the trick
Burning smell and icing
Sounds like your blower motor in your furnace or air handler has burned up. shut the unit down and replace the motor. make sure the ice is melted and the unit is dry before you turn it back on.
2helpful
Odor coming from furnace when running a/c
Smell when unit comes on with heat
Hi!!!remember everytime you turn on yout furnace you will have a strange odor thats all the dirt that is burning from the heating element if your using the emergency heta if not the what you are smelling is your fan motor replace it and you should be fine..Good luck..
2answers
Burning smell from AC Unit
http://www.hannabery.com/faq14.shtml
"Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
We will go through each of the five categories and list the possible causes and things to check.
1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
But this odor problem is almost never due to a problem with your equipment.
Final Tips:
Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
First time we used the heat it smells.
Yes, It probably has electric secondary heat which will kick it about 4 deg under your set temp. It should smell like burned dust and go away within a days time. If it last longer or smells different you might want to have it investigated for a mouse nest or something.
kstfas
Coleman forced air furnace
im assuming you are running a/c and not heat...Was the filter burning??  if not and there are no other obvious burnt wires then id say you need a new motor. The filter, if it was'nt binding the blower wheel or wrapped arround the motor shaft would not have caused the prob.
Top Heating & Cooling Experts
Paul Carew
john h
