Question about HP Officejet 6310 All-In-One InkJet Printer
Doesn't start Light goes on then the little camera sign next to the usd flickers and all other lights go out
  • gva1936 Oct 16, 2008
    My printer showed an error message "Reset power" after a blackout in the neighborhood. Power was reset and the printer actually printed 1 page and the error message appeared again. The power was reset again and the blinking camera light appeared and now the printer will not turn on.
  • HP Master
  • 4,338 Answers
According to HP, if you follow this document and it does not fix it,then you need to have it serviced.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c01059445&dlc=en&lc=en&jumpid=reg_R1002_USEN
Joe
Posted on Oct 09, 2008
Powered but not booting. No visual. HDD light not doing anything.
Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
Let me know how it goes
Cheers
Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
Garage door when i close it it goes all the way down but then reopens all the way up then light starts blinking
Make sure your door sensors are pointed at each other and the small light on each one is lit and not flickering. Tweak them a little.
Jul 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
Washer gets to rinse cycle and starts to pump water then stops?
Before hitting any buttons you need to write down the fault code. As soon as it starts beeping take note of which lights are on along the top row. There are 8 lights. Count from the right and tell us which number light is on and which are off. That will tell us the error code and what it means.
May 30, 2017 | Fisher and Paykel GWL11 Top Load Washer
Sears craftsman 1/2 hp. Door goes up with remote, but when button pushed to go down the light flashes and door doesn't move. If you push the wall mounted switch, the door goes down like normal. Works...
Check the sensors in the doorway. They should both have a small light that is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
My battery light flickers when I am at a stop sign--it goes off when i accelerate. i bought a battery and the alternator tests ok.
either the belt is slipping or the alternator is losing juice at a lower rpm....i take it it was checked in park,or taken out and tested by a machine which spins fast?
May 19, 2009 | 1992 Ford Taurus
Doesn't start
Try doing this steps to your printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power.
2. Wait 30 seconds.
3. Plug in the power cable only.
4. Repeat steps 1-3 two more times.
5. On the third time after plugging the unit into power and check the functionality.
Hope that helps.........
Sep 28, 2008 | HP Officejet 6310 All-In-One InkJet...
Veo camera blinks on for an instant then off....
Hello, Put your camera back together it's not a hard ware problem. The blue light means you have internet connectivity, It sometimes drops (blue light goes off)because of a loss of connectivity. This is one of those driver problems that plagued Veo. Try unistalling and reinstalling your driver.
Jul 25, 2007 | Veo Advanced Connect Webcam
HP Officejet 6310 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
