Question about Kenmore 46462 Front Load Washer
Trouble with kenmore washer
I have a he2 plus that has stopped in mid-cycle the door is locked and it is flashing code f-28 which is not in the manual
  • Anonymous Mar 30, 2014
    my kenmore HE2 plus stopped mid wash and is flashing a F -
I had the same problem. I called the repair center to have the problem looked into and fixed since it was under warranty for just a few more months. This is where I wish you all the luck and patience in the world. After 4 visits to my home over a period of nine weeks, and several attempts to order many parts that never fixed the problem, the tech finally figured out that the problem was with the door latch attachment and just needed an adjustment! I hope that this saves you about eight weeks and six days!
Posted on Sep 23, 2008
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Starts cycle then stops and displays F-28 and F-29 codes wont spin or get all water out of clothes
ok the f-28 means on of these parts are bad,, motor control unit or microcomputer control unit,,, f-29 is the door lock i would start with the microcomputer control unit,, but i always replace both parts at once saves alot of time waiting
Jan 22, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore washer HE2 plus and F26 is flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
May 14, 2010 | Kenmore HE2 Plus Front Load Washer
What does trouble code f28 mean
f-28 was flashing on my washer for the longest time, first i had read that my heating element had gone out which was false, my washer still produced the steam and heat prior to error code f-28 then shutting down.The 2nd thing i read was F-28 meant the locking switch on the door was going bad which again was false, my washer would lock and unlock allowing me to feed more clothes. So i took it upon myself to remove the lower cover clean and was my RINSE filter which at that time I discovered the DRAIN tube was pushed against my wall not allowing enough water to flow out on my washers RINSE & SPIN cycle.
If you have this problem I would recommend following your service guide to trouble shoot the RINSE FILTER & DRAIN PIPE. The washer motor spins so fast that the washer itself need to drain the water out 10X's faster then a regular standard washer!
Hope this helps cause it did for me and saved my wife and I alot of money in repairs!
Mar 31, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore F-28 error - door locked can't get in
Unplug the machine.
Wait 15 seconds.
Plug machine back in.
Press and hold the Power button until the lights come on.
Press and hold Start.
When you hear a click, press Stop.
Open door.
You still have an F-28 issue but you can at least get your clothes now.
Hope this helps.
Jun 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washing machine stops mid-cycle
F30
DISPENSER SYSTEM ERROR
when the dispenser motor cannot be driven to its proper positon.
==========The following information is for a TECHNICION SERVICE(only)========
1.- Unplug washer or disconnect power.
2.- Check mechanical linkage from dispenser motor to the top of the dispenser.
3.- Check wire hamess connections to the dispenser motot and Central Contol Unit(CCU)
4.-Check dispenser motor for power rotation.
Was this helpful?
May 10, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 46462 Front Load Washer Logo
96 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
