Question about Hoover U5720-900 WindTunnel Upright Vacuum
How to replace belt on type vu01 - Hoover U5720-900 WindTunnel Upright Vacuum
Replace belt
On that Eureka Canister, you're going to want to unscrew the cover on the base of the vacuum in order to gain access to the brushroll and belt. That vacuum takes a type EXT-U belt. Remove the brushroll and the old belt and stretch the new belt on using the brushroll. Click it into place and secure the cover back on.
Dec 12, 2011 | Eureka 3276AZ Pet Lover Bagless Upright...
Trying to change belt
The procedure for changing a belt will vary depending on the type of vacuum you have. However, I can give you some general guidelines. Unplug the vacuum and turn it over. Generally there will be some type of cover you need to remove to expose the beater bar. This cover can sometimes be removed by taking out screws and sometimes there are plastic tabs you need to push in with a screwdriver to loosen it. Once this cover is removed you will probably see the broken belt. You need to buy a replacement belt of the same size. You can probably look up your vacuum online to find out what size you need. You can also take the old belt to the store and match it up with the available new belts. Once you have a new belt you need to remove the beater bar. The ends of the beater bar will probably fit into some type of indentations or slots. Pull on the beater bar and it should slide out. Place the new belt around the beater bar. Also hook the belt around the metal motor stub located near the rear and to one side of the exposed underside of the vacuum. Now insert the beater bar back into its original slots. This will require pulling hard on the beater bar to stretch the belt forward and away from the metal motor stub. Replace the cover and you’re good to go. I hope this helps you out
Mar 30, 2010 | Vacuums
Eureka 431BX Bagless Upright Vacuum: i would like to know how to replace and if there is a specific type of belt to use?
Here is a link to the exact belt you need to replace (the belt should be replaced yearly for optimum performance) and a manual you can view which has instructions.
Eureka 431BX Replacement Belt
Owner's Guide (1.1 MB download)
Dec 07, 2009 | Eureka 431BX Bagless Upright Vacuum
Not picking up all fluff and other dirt
I don't know what type of vacuum you have but it could be that the belt is worn, stretched or broken. If that is the case then it won't pick up well. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
The region of the motor gets very hot during use. What can I do?
The Hoover is likely built with a temperature overload protector, to shut down the unit if it gets excessively hot. All the units will get heat build-up from the suction motor during use.
Sep 29, 2009 | Hoover Vacuums
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Broken belt
Hi.
If you cant easily see how to replace the Belt then I think your Dc07 has A clutch unit.
This type of Dc07 has 2 belts one from motor to clutch & the second belt goes clutch to brush roller.
You will need to remove the clutch unit completey from the machine in order to replace the belts, Its alot to explain so try this site it has service manuals covering this.
http://dysonmanuals.llc.nu/
Jul 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Replacement belt
Replacement belt for which model and brand??
Apr 19, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
1800 vacuum cleaner belt replacement
Generic problem for all Vacuums
How do you get into the belt to replace it?
Not knowing the brand name of the vacuum other than the 1800 vacuum cleaner belt replacement, normally the belt is located @ the bottom the vacuum attached to the brushroll and is held on by either screws, clips, or some even snap on – but mostly they use some type of screws to open the area to replace the belt, if needed contact the company website, include the brand name and the model number and request a schematic of the vacuum and that will give you an exploded view of how the vacuum assm goes together and also shows the belt replacement and how that is connected.
http://www.dooyoo.co.uk/vacuum-cleaner/typhoon-1800-upright-vacuum-cleaner/1021772/
Apr 07, 2008 | Vacuums
Hoover U5720-900 WindTunnel Upright Vacuum Logo
100 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
