Put a dvd in my cdrom and cannot get it to come out. Any suggestions?
    Genius:
  • 1,124 Answers
If your desktop is old you need to install the dvd bios update (usually from dvd manufacturer site). If your pc is new check the connections of the dvd driver. Be sure that the DVD is connected in the right way (or as a master or as slave depending of your pc connections.)
Posted on Sep 23, 2008
My cyberlink DVD will not eject
There should be a small hole near the button on the CDROM's tray. Get a paper clip and unbend it so it is straight and insert it in the hole making sure that you put it in straight and be gentle. This will manually open the CDROM and you can retrieve the disk. Once it is out, check the disk for dirt and check it in another PC or Laptop to see if it is readable. If it is readable in another CDROM, then I think your CDROM in your envy may have a problem.
Feb 16, 2012 | HEWLETT-PACKARD Hewlett Packard HP Envy 17...
The cd/dvd tray does not open.what is the problem and how do i rectify this?
1) use a paperclip to "force" it open by opening the clip, then inserting one end into the little hole and pressing...
2) while it's coming out, see if the faceplate binds on anything
3) if it's not binding, it's probably the drive motor. Pick up a replacement internal DVD-RW and swap it out...it's very easy!
Quick instructions on how to swap out a CDROM/DVD drive:
1) Turn off the machine
2) Take off the cover
3) Disconnect the power connector and the data ribbon cable from the CDROM drive
4) Undo the screws (or tabs) holding the CDROM in place
5) Slide the drive out the front
6) Slide the replacement unit back into place, after confirming the jumper placement for standalone/slave/etc.
7) Put the screws back in (or the tabs click in place)
8) Plug in the cables, being sure to line it up correctly
9) Put the cover back on and get it going!
Mar 07, 2010 | Dell Dimension 3000 PC Desktop
CDROM won't spin...computer says it's not ready...is it broken and where can I get a new one.
Any decent computer shop or Radio Shack will supply you with a CD-Rom
They are very cheap now
I would go for a DVD burner combo again you are talking very little in the way of cash
Jan 06, 2010 | E-Machines etower 333k PC Desktop
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
Lite on DVD Combo disk read failure
You could take the drive out of the encloser and hook it up. There could be a flaw in the enclouser ive had that happen before to me. I just took it out and put it in standard if this dosent work then there is a flaw in the dvd burner
May 20, 2009 | AMD Duron 1.3 GHz (cpu-amd-1.3g-o)...
Dvd-cdrom plays music-cd.Not dvd-cd :No Valide Drive/Disc Found
Simply change the ROM to DVD RW drive since this is an old PC and now days nobody uses a dvd rom but a dvd writer. It will be worth it since it can do all the functions and is also more hardy........sodeep
Apr 29, 2009 | Compaq Presario 7599 (173952-004) PC...
I need to install an operating system on a Samsung q1 ultra
Suggest you use an external DVD drive, and put your installation disk in it. Then access the BIOS Setup utility.
In BIOS Setup, find the Boot Order menu. (Generally, along the top headings of the main menu, in BIOS Setup, or located in Advanced BIOS Settings) Set the first boot device to be CDROM. Be sure to Save your change.
This way the handheld, will boot from the installation disk, in your external DVD drive.
Should you be trying to downgrade from Vista to XP, you have to change the first boot device, in Boot Order to CDROM. If not, Vista won't let you overwrite it.
Vista is an upgrade over XP.
Apr 21, 2009 | Samsung Q1 Ultra Tablet PC
Cdrom doesnt recognise blank dvd. error message
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Apr 19, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
My dvd and cdrom in Compaq Presario R3000 quit working. Help!
Unfortunately these devices will fail.
A new one will cost in the $20-30 range and is easy to install.
Mar 20, 2009 | Compaq 350831-001 - Presario R3000 Series...
Missing cdrom drive
The triggers determining the slave was set to master with the CD rom drive as well...so I had two master drives...kind've stupid. Everything is now working properly!
Dec 30, 2008 | Memorex (278010300003) Internal DVD Drive
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
