Question about Whirlpool Duet GHW9150P Front Load Washer
Clothes have a mildew smell
Whenever we wash clothes...especially towels they smell rank (like mildew).  We do not do large loads of wash and we use Tide HE detergent.
  • 706 Answers
Hello billpmm,
You are not alone with this problem. Seems that that everyone of the front loader washers exhibit similar characteristics .. the short story is that in order for a washing machine to be a front loader, they need to be water tight .. being water tight, they are also air tight and herein lies the problem.. any water left over from a wash cycle will sit in gaskets , nooks and crannies and eventually develop mold or mildew.. here is a link to product you may find that solves your problem
http://www.smellywasher.com/
or.. you can use the AFRESH tablets sold in Home Depot and other home improvement stores.. in either case.. these products will help rid that musty mold out of your washer..
Posted on Sep 24, 2008
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Smell of mildew on our towel and sheets
This is probably happening because the clothing is being left damp in the washer. When it is warm during the summertime mildew will grow very quickly in the towels. On front load washers you need to leave the door open when not in use to keep mildew from growing. You should wipe out behind the inner seal any moisture when you are done doing laundry. This is an issue for most front loaders. Some front loaders have a clean washer cycle that uses bleach to sanitize the drum. Other washers like the Samsung have a block of silver and release silver ions in the wash to sanitze the clothes.
Sep 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Same problem with our LG Tromm
I had the same problem with my LG Tromm and was ready to throw away every one of my towels they were so rank smelling. As a last resort I filled the detergent area with one cup of white vinegar and ran a load through on hot. Then I washed them with just a tablespoon at most of detergent. They came out smelling fine, the mildew smell was completely gone. How long it will last, I don't know.
I also read somewhere recently that we all use way too much detergent in our washers and dishwashers. And surprise, surprise, the post went on to say that too much detergent in your towels/clothes can leave a musty, mildewy smell in them.
Now when I do laundry, no matter what it is, I use about 1/4 of the amount of detergent called for, even though the HE uses so much less. In all, maybe 1-2 Tbsp, and everything comes out just as clean.
Also, try using a product from Clorox just for front loading washing machines. It's Clorox Washing Machine cleaner...it seemed to help with the overall smell. And I agree, I will never buy this particular machine again.
Aug 10, 2009 | LG WM2688HWM TROMM SteamWasher
Mildew smell on cloths
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
Oct 28, 2008 | LG WM-1832C Front Load Washer
Clothes/towels smell like mildew
Front load washers are so tight ( to seal in water ) that they tend to leave water in door gaskets and other places.. This water gets stagnant and can build up mildew etc..Home depot and other home goods stores sells a product called AFRESH and you use it about once a month ( with no clothes in washer).. It does help a bit..
Other techniques you can try would be to wipe down the gasket around the door opening after a wash is complete and to leave the door open between washes to let it air dry.. You should be using HE type laundry detergent and very little of it ( sveral drops is enough per load)..
hope that helps you...
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell in towels
are you using liquid detergent? if so, change to powder. liquid detergent used for a long period causes a smell.
try putting on the hottest wash with no clothes in to get rid of the smell
Aug 05, 2008 | LG WM-1485FHD Front Load Washer
Smely Clean Clothes
We had a similiar problem. It was mildew in the washer and in the fabrics. We ran two or three empty loads with some bleach added in, and we leave the door open so the drum dries.
The towels and clothes we hung out in bright sunlight. The UV rays kill the mildew.
Dec 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
274 people viewed this question
Dan Webster
Dan Webster
Sal De
