Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Ryobi string trimmer
Whenever I "bump" the trimmer to advance the line, the entire line unwinds around the shaft and stalls the engine. I put in a new reel thinking that that was the problem but it wasn't. Nothing appears to be worn or broken. Any suggestions??
SOURCE: The fuel line leaks coming out of the plastic fuel
There is a little white ring that goes over the line and into the opening on the tank. This is what seals the line so the gas won't leak out. They are about $1.00 at any small engine service shop.
Posted on May 15, 2009
  • 4 Answers
SOURCE: My new Ryobi boggs down/ stalls as soon as I pull on the trigger.
You should have 2 small adjuster screws next to each other on top of the carb.Try adjusting each of them a little with a thin screwdriver as the engine is running.Put strimmer on the ground first and adjust screws while you are revving engine until it runs correctly.Trial and error and very small adjustments can make quite a difference.Hope this helps.
Posted on Jun 12, 2009
#1 Taper
  • 1041 Answers
SOURCE: Ryobi CS30 straight shaft. I can not get the
There should be a half sphere shaped object over the spool of string. Twist off in a counter clockwise motion and the spool will come off so that you can replace the line.
Jim
Posted on Jun 19, 2009
  • 148 Answers
SOURCE: Installing new string line for Ryobi 4 cycle straight shaft s430
Go to www.managemyhome.com and download a free copy of the onwers manual.
Posted on Jul 14, 2009
kenny8262
  • 12 Answers
SOURCE: HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Posted on Oct 29, 2010
I changed the string in my ryobi 725r and since then it feeds the string so fast it wraps around the shaft. What did I do wrong?
multiple failures with bump advance string trimmers - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Jul 5, 2008 - I have indeed hurled my own ryobi across the yard in a fit. ... Some heads are not designed for curved shaft trimmers or on engines under a .... the fence so thestring won't wrap around the fence instead of whipping in and out.
Sep 30, 2015 | Ryobi Garden
Ryobi 26cc gas trimmer. Can't replace line. Used 1 8'' line thru slots in spool. (3'' each side). Don't understand next step. Push down spool and twist? Should spool stay level...
You line up the head with "arrows" by turning the plastic bump knob on extreme bottom. When arrows line up with the head then you insert your line through the slots "OR" you insert the line in one side and it comes out the other side. Then you have to push pressure DOWN ******* the bump head while twisting the bump head clockwise to "pull in" the string until there's only about six inches left remaining on the "shortest" piece hanging out the side. use scissors to make the lines equal in size before staring the trimmer. Hope this helps.
Sep 08, 2017 | Ryobi 30cc 17" String Trimmer Zrry30530...
I cannot get the line to feed as it is used up. bumping does no good. the spring is in place. thanks for your help
Did you wind in the new string in the correct direction? The string should be wound in the SAME direction that the head spins.
Jun 16, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I was given a used 31cc trimmer but can't get the spool off to replace it. how do i do this?
A typical trimmer has a small bump knob, an inner spool with the plastic string wound on it and the housing for that which is the string head.To remove the small bump knob, hold string head firmly and turn the bump knob counterclockwise. To remove the head entirely, first remove the bump knob. Next, remove the inner spool with string. What should be left is the spring with the end of the gear shaft showing. Some heads are locked on and some just slip over the end of the shaft. Check the gear drive just above the string head for any holes in the collar. An object can be placed in one of the holes to lock the drive and twist the head off.Ryobi's use retaining clips on the shaft which have to be removed.
May 06, 2011 | Garden
I have a cs30 ryobi weedeater and something in the shaft is causing the weedeater to either stall out or completely shut off, how can i fix this problem?
Usually this is a fuel supply problem. It can be caused by a cracked fuel line, debris in the fuel tank of in the tank to carb fuel connection. If you have a primer bulb a pin hole in the primer bulb or (if so equipped) the line that goes to the primer bulb it will do the same thing. Small air leaks will cause the trimmer to run fine at idle but anytime you demand more speed it just will not speed up or it will stall. Additionally the diaphragm in the carb can also have a small hole or tear in it. (Located under the 4 small screw plate on the carb)
A problem in the shaft is rare unless the shaft itself breaks or the internal flexible drive shaft has a partial break and the spring material is unwinding. If this is the case the flexible drive shaft will have to be replaced. It requires removal of the engine from the curved shaft assy to replace. Once the engine is removed the shaft is supposed to just pull out. WHen installing a new shaft you must make sure the 4 sided drive spline drops into the string head or you an not install the engine correctly. The same goes for the engine to shaft mating area. Align the 4 sided spline.
Thanks for choosing FixYa.
Kelly
Sep 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do u remove the bump feed spool from the bump feed string head on my ryobi gas trimmer
Grasp the outer portion of the cutting head in your left hand and turn the inner knob with your right. Depending on model, some bump knobs are threaded and some are post and notch. Use a little spray like wd40 to loosen the mechanism. It may take a firm hand, but the two will separate so that you can reload the line. Consider reloading with the .095 five sided line. It cuts much easier than the round line.
Aug 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
725r trimmer
You can buy new Line to re-spool on your existing head
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Jul 05, 2009 | Garden
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Sep 09, 2007 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
322 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
