Question about KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer
KitchenAid Artisan Stand Mixer - Tilt is Tilting too Much & hits the bowl!
I'm not certain, but I think I may have overloaded the mixer when using it recently and now I've screwed up the tilt alignment on my Artisan KitchenAid Stand Mixer. The entire top part of the mixer that can lock into place, and what you lift up to remove the bowl, is now tilting too low causing the mixer attachments to hit the bottom of the bowl. This is causing the entire mixer jump, vibrate and shimmy til it almost falls off my counter top. I've tried to tighten up some of the screws, and now I think I have just made it worse. Any ideas would be greatly appreciated. Thanks a lot.
  • 145 Answers
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Posted on Jul 08, 2009
3 Suggested Answers
BelgianAlien
  • 50 Answers
SOURCE: I can't find out how
On my kitchenaid stand mixer, the lock lever to lift the head is located on the opposite side of the speed control. If there is no lever there, check to see if there is a spot that looks like there should be a lever there, if there is, but the lever is missing, you might have ended up with a mixer with a manufacturing error. In that case, your only option is to take it back to the store where you bought it.
Posted on Mar 27, 2009
  • 10 Answers
SOURCE: Head tilting problem
OK,Where the mixer pivots there is an ajustment screw ( Flat head). Place a dime at the bottom of the bowl and make your adjustment carefully ( quarter turn at a time).Using the low speed only, adjust until the tip of the flat beater barely touches the dime.When your done, you'll be back in business.
Posted on Nov 04, 2007
How to put the steel pin back in so the head will tilt without falling down
Tip it upside down on a towel. Look deep inside the pedestal where the hinge pin goes through. Right in the middle there is a single headless screw, undo it 2 turns. Wriggle things about and push the pin through to the middle, now tighten that screw up really tight. See how you go now.
Jul 25, 2015 | KitchenAid Artisan Series Tilt-Head Stand...
Head does not lock but when adjusted whisk touches bowl
The screw is purely for adjusting the head height and that is with the flat paddle. If the head is not locking when the paddle is at the correct height then the locking mechanism needs to be adjusted. If you take it to a Kitchen Aid authorised service person they will sort it for you, they will have done heaps of them. Often the solution is with a file, if you go too far there is no going back so best left to the experts.
Jan 21, 2014 | KitchenAid Artisan Stand Mixer KSM150PS -...
I have a Kitchenaid Artisan stand mixer and the head is loose. When in the down, locked position, I can move it up and down by probably an inch. I've been into shops and tried to do the same with
If you have also tightened up the screw that you can see from the front in the middle where the hinge pivots when head us up then that's where your problem is. That is the head height adjustment and is to set the flat paddle to just clear the bowl when the head is down.
Aug 01, 2017 | KitchenAid Artisan Series Tilt-Head Stand...
The mixer goes real fast on all the settings. Whats wrong?
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must
be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 14, 2011 | KitchenAid K45SS Classic Stand Mixer
I bought the mixer used without hearing it run. When I turn it on the lower speeds I hear a buzzing sound. It's not in the mechanical gears it sounds more electrical to me. I have replaced the...
The KSM90 is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the KSM90 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 12, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Speeds don't increase after 6
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 03, 2011 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Artisan KSM150 Stir problem - Stir speed is the same as setting 2, but all others (4, 6, 8, 10) work fine. Tried adjusting the control board but "stir" and "2" still spin...
You are not adjusting the screws correctly. All three screws (2 top left and right, and 1 bottom)
must all be adjusted. Here is how:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Overheat after grating cheese, make an awful noise to top it up , have i burned the gears ?
You are putting too much pressure and overloading (motor) the Mixer. Specially if you run it for long time.
Grating cheese is hard on mixers.
Let it rest and turn it back on, ON LOW and little or no load.
Jan 14, 2011 | KitchenAid Artisan Series Tilt-Head Stand...
Top section is tilting forwards too far
If you lift the top section up you will see a screw, turn it a little in an anti-clockwise direction to reduce the tilt.
Aug 28, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Mixer won't tilt back
You may need to remove the head from the base to find the problem.  This is a simple procedure, and is easily reversed, so if it doesn't help you, you can just put it back and take it to a repair shop later.
To remove the head:
First, make sure to unplug the mixer unit!
Next, turn the unit upside down.  Inside the neck, you will see a screw.  Use a slotted screwdriver to loosen (turn counter-clockwise) the screw a few turns.  This will release the pivot pin on which the head swivels.
Push the pin out from one side using a long, slender implement (a screwdriver, pen, etc.).  With the pin removed, the head will lift off of the base, and you may be able to determine the problem from there.
Best of luck!
Oct 15, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
651 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
