Question about E-Machines emachines (emachinees) CD-ROM Drive
E-machine is locked up
Entered the cd-rom disk that came with my new video camera. after entering the cd the program was working fine. I shut the computer off
and the next time I turned the computer on it booted up and a screen with
the e-machine logo showing a big E on the screen locked up. I have not been able to get by that screen with the E whenever I boot the computer.
  • mikestaddon Jan 21, 2009
    I cannot get past the E screen, holding the F8 key did not work
    Problem Solver:
  • 8 Answers
Try to reboot the machine in safe mode. This is generally done with the F8 key. To do this...start computer, make sure F lock key light is on and hold down the F8 function key. It will ask whether you want to start in several different ways: Safe Mode, Last Known Good Configuration, Normal, etc. Try Safe Mode. Go to Start>Control Panel>System. Under System Properties>Device Manager and look for Yellow exclamation points. Delete all of the exclamation points (make sure you have your original system disk). The video camera will probably be listed. Hope this helps.
Posted on Nov 25, 2008
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
Tip
How to Recover Windows XP Administrator Password?
Computer plays a vital role nowadays. No matter for the business man or home computer user, they all need use PC to do work, watch TV & Video, play online games and so on. Indeed, in some sense computer is already becoming a part of our life. Most of computer users get use to create a Windows administrator password in case of privacy data lack. So, you can image that there are more and more people need to gain access to their PC when Windows XP administrator passwords forgot. Absolutely, you want get out of this situation without formatting and re-installing the operating system? Thus here I point out the easiest and safest method that can help you recover Windows XP administrator password. Let's roll it.
Part 1: Select Windows XP administrator password recovery tool
As you can't login Windows XP operating system, the only thing you can do is making a Windows password recovery disk and using the disk to recover your Windows password, and then you need:
1> a blank CD disk.
2> a computer that can download from Internet and have a CD writer.
3> a program that can recover Windows password. In this tutorial we highly recommended Windows Login Recovery and use it as an example.
Part 2: Recover the forgotten Windows XP administrator password
Step 1. Download Windows Login Recovery from the official website.
Step 2. Install Windows Login Recovery on your Windows XP computer, then launch it (When launch the program, you will see the ISO image file has automatically entered. Please leave it as the default).
Step 3. Choose a device to burn the ISO image file, we select the CD writer.
Step 4. Click Burn and then start to burn the ISO image file (Please insert the blank CD disk into the CD writer first). When the burning completes, click OK and the disk will eject itself.
Step 5. Change your locked computer's BIOS settings to make it boot from CD-ROM: (3 steps)
1). Reboot your locked computer, press F2 or Delete to enter your BIOS setup during the booting.
2). On the Boot tab, set the Boot Device Priority. Make sure the CDROM Drives is before Hard Disk Drives.
3). Press F10 and Y followed by Enter to save the BIOS settings and reboot your locked computer.
Step 6. Use the created disk to recover the Windows XP administrator password: (5 steps)
1). Insert the created disk into the CD-ROM of the locked computer and reboot it (When the locked computer boots, you can see Windows Login Recovery initializing).
2). Enter the ID number of the hard drive volume that Windows is installed.
3). Enter the ID number for the User Name.
4). Enter y (yes) to confirm your action or n (no) to deny the action, then hit Enter.
5). Enter y to continue to remove passwords of other accounts or n to finish (If you enter n, the locked computer will reboot, please eject the created disk first).
Congratulations! You have successfully removed the Windows XP administrator password. Now you can login Windows XP without password and you can create a new one.
on Jul 29, 2010 | Computers & Internet
I bay my netbook is locked i need e password
DO NOT panic, you can reset the password YOURSELF.
Windows Password Recovery is right what you need in your case. The password recovery tool is designed to reset Windows login password once you accidentally forgot it or have no access to your system including Windows 7, Vista, XP etc. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy, I am sure you can handle it!
Step 1: Download Windows Password Recovery and install it on another computer.
Step 2: Prepare a blank CD/USB and run the software and use it to burn the ISO file to it.
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive. Note: start computer and press F2 or Delete to enter BISO setup
Step 4: Boot your locked computer from the created disk and remove your forgotten password. GOOD LUCK!
Feb 06, 2011 | Sylvania G-Netbook
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
How do i get my master system disk to work on my new hard drive
You will need to put the disk in - and then boot the pc.
look for a notice that to start the machine using the cd rom or DISK drive to push the space bar or enter key or the famous any key.
IF this doesn't work - you will need to enter the bios - and set the pc to boot first to the cd rom drive.
start the pc - and tap the DELETE key - until the bios screen appears - - wait awhile for this- - - then select the BOOT - choice and then select [ instructions will be at the bottom of the screen] the first boot drive to be CD-ROM - DVD - --
click F10 and reboot - again looking for the notice I put above.
Apr 02, 2010 | Computers & Internet
How do i reformat my pc?
This is a pretty drastic process and takes several hours. If you have system slow downs and ongoing bugs you may be able to repair with software tools (see here), however that said, on with the show.
The procedure will decimate the data on your C: drive, so it's crucial that you back up all the data you don't want to lose.
Don't forget items like e-mail data and address books (see: How to backup e-mail.). Back up all your documents including your "My Documents" folder and all the data you've stored on your Windows Desktop which you'll find in c:\Windows\Desktop or c:\Windows\Profiles\<yourname>\desktop, where <yourname> is your Windows log-on.
Don't worry about backing up programs that you can reinstall later, unless you want a complete backup of your C: drive in the event of a problem.
Now, create a boot disk. Creating a Windows 98 boot disk is easy. If Windows 98 came factory-installed with your machine then one may have been supplied with your documentation. If not, you can create one through the Control Panel. In Windows, go to Add/Remove Programs and click the "StartUp Disk" tab and click the "Create Disk" button. It will create a boot disk on a blank floppy for you with CD-ROM support.
This is important, as you'll need access to your CD-ROM drive to do a new Windows98 install.
Once the boot disk is created, test it to see if you can access your CD-ROM drive. To do this reboot the machine with the floppy disk in the floppy drive and when the machine restarts choose "Start with CD-ROM support".
At the prompt type d: and hit the Enter key. If the machine responds with D:\> you are in business.
Next type "format c:" without the quotes (and hit ENTER).
The C: drive (main hard drive) will then be wiped clean.
Once the reformat is finished put your Windows CD-ROM disk in the CD-ROM drive, and type "D:\setup" at the prompt.
Once Windows is finished installing, reinstall your backup software and restore your data to the hard drive.
And Thanks.
Mar 05, 2010 | Microsoft Windows 98 for PC
Problem with ASUS P5GD1 mobo
Is the cpu fan working, remove all the memory,but one stick, then try each stick you have. Then, When you get your post, enter safe mode, this does not use full video, so if you can, and it works in safe mode, it is probably your video, if not it is either
your power supply or another piece of hardware.
Unless you installed something on windows just before this problem.
Post back if you need more help, any code errors would be great to post.
Feb 05, 2010 | Computers & Internet
No software
If you camera software disc is broken you can download it from the camera's manufactor website.
1. There should be a search bar on the website, and enter in your
model number.
2. Look for support and dirvers for your camera.
3. Then click on download to download the correct software for your
windows.
Dec 07, 2009 | Hitachi DZ-MV550 DVD Camcorder
I have an old Presario 5000 series PC, hard disk crashed, bought a new hard disk and tried to use the Quick Restore CD's to Restore to Factory settings. Can't seem to boot up from Disc 1 of the Quick...
For boot from disk first you have to set first boot device option in BIOS.
for that when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot menu then set first boot device as your cd/dvd rom.
then save settings then insert recovery diks in rom then check.
Then it boot from disk if your disk and cd.dvd rom works fine.
Let me know if you need more assistance.
Thanks.
Nov 05, 2009 | Compaq Presario 5000 PC Desktop
HDD Partition help
Important If you follow these steps on a hard disk that is not empty, all the data on that hard disk is permanently deleted. We recommend that you back up your hard disk before you follow these steps.
To partition and format your hard disk by using the Windows XP Setup program:
1. Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer.
Note To start your computer from the Windows XP CD-ROM (or from the startup disk), your computer must be configured to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive, see the documentation that is included with your computer, or contact the computer manufacturer.
2. If you are starting the computer from the Windows XP CD-ROM, select any options that are required to start the computer from the CD-ROM drive if you are prompted to do this.
Note If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver.
For additional information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base:
314859 Limited OEM driver support is available with F6 during Windows XP Setup If you are starting from the Windows XP Setup disks, insert each of the additional disks when you are prompted, and then press ENTER to continue after you insert each disk.
3. At the Welcome to Setup page, press ENTER.
4. Press F8 to accept the Windows XP Licensing Agreement.
5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
6. All the existing partitions and the unpartitioned spaces are listed for each physical hard disk. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition by using unpartitioned space. If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each of the existing partitions that you want to use for the new partition. When all the partitions are deleted, select the remaining unpartitioned space, and then press C to create the new partition.
Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition.
7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
8. Repeat Steps 4 and 5 to create additional partitions if you want them.
9. If you want to install Windows XP, use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER. If you do not want to format the partition and install Windows XP, press F3 two times to quit the Windows Setup program, and then do not follow the remaining steps. In this case, you must use a different utility to format the partition.
10. Select the format option that you want to use for the partition, and then press ENTER. You have the following options:
Format the partition by using the NTFS file system (Quick)
Format the partition by using the FAT file system (Quick)
Leave the current file system intact (no changes)
The option to leave the current file system intact is not available if the selected partition is a new partition. The FAT file system option is not available if the selected partition is more than 32 gigabytes (GB). If the partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm). If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
Note If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you will be prompted to select a file system for both the System and startup partitions. 11. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue. After the Windows Setup program is completed, you can use the Disk Management tools in Windows XP to create or format more partitions.
For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base:
Oct 19, 2008 | Computers & Internet
Computers & Internet Logo
136 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
