I cannot understand what happened to your calculator but ther is a way to restore it to health.
The operating system OS and all the applications that were preloaded in your calculator are available to download freely from
http://education.ti.com.
Use the tab Download--> Apps and software. Then select the OS for your calculator TI84 PLUS and save on your computer. While you are at the site download the TIConnect, if you do not have it already. The link follows.
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.htmlInstall TI connect on your computer and run it to open the main window.Then connectyou calculator to a USB port and, in the TIConnect main window Clickthe TIDeviceInfo icon. Software will try to retrieve the info. If itdoes your calculator is ready to communicate with the computer.
Ifit tells you Device Not found , Click communication settings in samepop up window where it said Not found, and Select Device, Select Cable(USB or TIsilver cable), Select Port (USB1) and Click OK..
Ifyou are lucky and it works, you can reinstall the OS. You drag and drop the OS on theTIconnect main window. Calculator must of course be connected to computer and trurned ON.
Now that your OS is installed you can go back to education.ti.com and download all the applications you want. Drag and drop an application onto the main window of TIConnect to install it.
If you have problem with TIconnect, usethe calc-to-calc cable to transfer the OS and any application from a working calculator.You should be on Receive mode [2nd][Link] --->>Receive. (Whenboth calculators are ready hit enter.) The other calculator, youguessed exactly right, must be on Send [2nd][Link][SEND][Send OS]
Hope it helps
