No picture or sound
HP PL5060N...model #CPTOH-0603...product #EK430AA
one blue light on back of tv is lit when tv is plugged in...other blue light goes on and off every 7 seconds or so...tv never gets to intializing screen anymore...also no sound
  • byoungzipps Sep 23, 2008
    sounds good...just need to find one now?!
    President:
  • 1,263 Answers
You seem to be having the same problem many others are having, you have a power supply issue on your main board. the blue light indicates that your gettin power to the supply module ,hoever that supply chip is not allowing it to give the designed voltage to the main board. if you are comfortable with soldering companants on a circuit board then just go and get the part for your set at a electronics supply shop and install the new part yourself. if your not electronic savy then i suggest having a tech repair the set for you. it's not a main board problem so the costs should be minimal....please rate the solution....thanks
Posted on Sep 23, 2008
    Novelist:
    Champion:
  • 203 Answers
You can have a whole bunch of things causing this problem. Do you know how to use a volt meter? If so we can do some troubleshooting but if not you will need to contact a local service center for repair. Let me know
Tim Nolan
    Genius:
  • 1,550 Answers
It sounds to be the problem of the fuse .
Replace fuse in your tv will solve the problem .
SAM ANDERSON
On my CPTOH-0603, i'm getting great picture but no sound. Just have antenna hookup directly. Would I need a receiver for the sound to come on? Or maybe not hooking it right.
the antenna is getting a good picture and as sound and picture are bound from transmission I am thinking that there is a problem in the sound board/ section of the tv
Mar 24, 2017 | Televison & Video
Picture just went out on my tv but I still have sound
I have the same problem with my HP PL4260N 42" Plasma HDTV serial # CNH6141988, model # CPTOH-0602. I have perfect sound and can change channels still with sound but NO PICTURE. I am a consumer with a question that need the advise of an expert.
Apr 17, 2013 | HP PL4260N 42 in. Plasma HDTV
Hp pl5060 Plasma TV has no sound or pix. Screen flashing white
I have a seven year Plasma TV HP PL5060. When I turn on the TV, I have sound but no picture, the screen display (power on) is a snowy blue screen and vertical pink stripe. What is causing this problem and how can I fix it cheap. I can afford a TV repair man at this time, because I am laid off from work. Thanks.
Dec 15, 2012 | HP PL5060N 50 in. Plasma HDTV
Problem with picture on HP Plasma TV
hello!
This is known problem with PDP displays. That means: one of X-buffers has bad connection to the PDP(plasma display). Or, in some cases, depend on PDP type, it could be panel itself at fault. You need to open your set carefully and get an access to X-buffers. Usually, at the very bottom of PDP, covered with aluminum heat sinks. By turning set on, while face down, start tapping slightly with isolated handle of medium size screwdriver. Observe, when line(s) vanished. That's where connection(ribbon cable) between PDP and X-buffer is compromised.
In some PDPs, those integrated into panel itself and nothing you can do, except to live with that or replace panel. Hope, you end up just reconnecting ribbons. Anyway, you must have very good technician background to do so.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
I was watching tv and then the picture just went out ...no warning when you turn it on nothing a sligt flicker maybe but no sound no picture my hp tv is about 5 years old 2006 the model is hp pl5060n/hp...
check your lights on the front, it could be the temp it may be getting to hot due to a bad fan are it could be the lamp needing to be replaced
Jul 13, 2011 | Televison & Video
Blinking light on plasma television
is this occurring when tv is on/off? how old is plasma tv? they have a screen life of approx 3500-5000 hours. be better to contact manufacterer
Jan 05, 2009 | HP Pavilion dv6000z Notebook
Televison & Video Logo
420 people viewed this question
Top Televison & Video Experts
