Question about JBL Car Audio & Video
I need to know how the remote wire connects from the amp to the car radio.
  • 360 Answers
You should have a remote or an antenna wire out from the radio. most of the time its blue.. if you need any more help ask away....... jimmy
Posted on Sep 23, 2008
Step by step instructions
The pink wire connects the remote CD controller to the radio to enable playing of CDs through the amp via the radio. The DK GRN wire from the radio turns on the amp.
Feb 25, 2014 | GMC Yukon Cars & Trucks
I need help installing a rockford fosgate punch 75hd amp in my 2013 ford f150. I ran the power cable but now I'm having trouble finding the radios remote turn on/off lead. Took the dash apart and...
If u are using a factory radio it may not have a remote turn-on (Usually the blue wire on the main connector to radio. and do not connect to any blue wire without checking the voltage) if there is not blue wire (remote) you can connect your amp to the red 12v (accessory) wire which will turn on amp when key is in accessory position and works the same and will not hurt your amp. If u do use this method and a pop is introduced when turning on radio and amp may need to purchase a relay to delay the amp turn on.
Sep 27, 2013 | Car Audio & Video
Kenwood eXcelon radio problem I have 2 subs in my civic that work perfectly fine but i recently tried to add another amp to run my front door speakers seperately. I spliced the remote wire between the two...
Cut the remote wire from the radio.
install a relay in line
the relay will have 4 or 5 terminals
connect terminal 87 to battery power and fuse it at 3amps
connect terminal 86 to the remote output from the head unit
connect terminal 85 to ground
connect terminal 30 to your amp turn on wires
this allows the turn on load to run thru the relay and not directly off the radio remote output
Nov 25, 2017 | Kenwood Kdc-x494 Car CD/ MP3 Player
Hi, just trying to wire up my pioneer gm-620 car amp and having some problems with which wire goes where, due to not having a wiring diagram. (red is live) (black is ground) but i dont know where the blue...
i need to know is the blue wire comming from the amplfier or comming from the radio?
if its comming from the amplfier then
you need to connect this to the igintion wire (yellow) or if the radio has it connect it to the radio (it shoudl become 12V when radio turns on)
if its comming from the radio then
you need to connect it to the remote jack in the amplfier
the wire become 12V when the radio turns on
and the amplfier only turn on when the remote connection on the amplifier becomes 12V
May 14, 2010 | Car Audio & Video
Hooking up an amp
you need rca cables, an amp kit from your local audio shop(or walmart). make sure you know which wire is the remote from your radio as it will need to connect to the remote on your amp. most radios have the wiring diagram on top of the radio. Ground(black)/Power(from battery) and remote(typically blue from stereo.
Apr 01, 2010 | Jensen's VM9312 Car DVD Player
Connecting amp to stock radio in a 2010 carolla and need to know what wire is remote turn on lead
There is no remote turn on lead on a factory radio. The way the shops do it is to run the remote wire to your radio fuse which turns on/off with the ignitin. If you really wanted to know you can use a volt meter but it will still turn on/off with the ignition but takes a lot longer to find plus you have to remove the radio!!
Sep 07, 2009 | Car Audio & Video
Remote wire?????
The old pioneer car radios solved this problem by supplying the battery power to the radio from the amp. When the radio turned on, it began to draw more power from the amp supply lead and this would turn the amp on. It was a simple circuit in the amp that only used one or two transistors. You may need to build this circuit or find a manufacturer of a similiar circuit. In the short run, you can use a small toggle switch to supply the trigger voltage (+12 volts) to the trigger wire connection on the amp. Good luck.
Nov 18, 2008 | Audio Players & Recorders
Maystar cx475
Ok, I am assuming this is the 600 watt amplifier?
DISCONNECT YOUR BATTERY!!
Supplies needed:
- 8 Gauge power wire (long enough to run from your battery to the amp placement) WITH an inline fuse!!
- Depending on your stereo (if it has amp pre-outs or not) you will either need RCA cables (long enough to reach your amp from your stereo) OR a Line-Out converter AND RCA cables.
- The power lead that connects to your "REMOTE" line on your stereo (long enough to reach from amp to stereo - usually blue)
- A good ground wire ( long enough to reach a metal part of your car from the amp)
STEP 1: Find a spot to run the power wire from your battery - through your firewall and into your car - and then to your amp. (DO NOT CONNECT IT TO ANYTHING YET)
STEP 2: Remove your car stereo and look to see if you have PRE-AMP outs (RCA connectors for an amp on the rear of the unit)
A- if you do, GREAT.. proceed to step 3
B- if you don't.. you will need to get a LINE-OUT CONVERTER - what this does is converts the higher signals from your standard wires on your radio, to RCA style wires to connect to your amp.
B2- you will also want to buy a wiring harness kit for your stereo, unless you want to hack away at your factory wires.. (not recommended) - connect the harness kit to your factory wire harness, wire in your leads for the output converter, and run the other end to your stereo.*
*you will need to know which wires run to the speakers you plan to power with the amplifier
B3 - once the converter is properly connected - proceed to step 3
STEP 3: Plug the RCA cables into the stereo or converter, and run them properly from behind your radio to the amp but DO NOT CONNECT THEM YET.
STEP 4: Connect the REMOTE wire from your stereo to the same wire for your amp . (this enables the amp to turn on/off with your radio.. otherwise.. you will have alot of dead batteries)
STEP 5: re-install your stereo into the car.
STEP 6: Connect the RCA speakers into the INPUTS on your amp
STEP 7: Connect the REMOTE wire to your amp.
STEP 8: Connect the speaker wire from the OUTPUTS on your amp to the speakers you wish to power
STEP 9: Connect the POWER CABLE to the amp PROPERLY
STEP 10: Connect the GROUND CABLE to a metal part of your car (sheet metal, not just a bolt)
STEP 11: Connect the POWER CABLE to the battery cable
STEP 12: Re-connect your Battery
STEP 13: Start your car, and test your radio.
If you have any issues from here.. you need to re-check all of your connections.
Oct 12, 2008 | Car Audio & Video
No bass thru cd player
it seems like you connected the wrong remote wire to the amp.
Alpine has two remote wires.
BLUE (only) This is the pwr antenna remote wire,every time you insert a cd this remote wire,the pwr cut out.
BLUE/WHITE STRIPE This is the AMP REMOTE WIRE,THIS IS THE REMOTE WIRE THAT YOU NEED TO CONNECT TO THE AMP
LET ME KNOW IF IT WORKS
thank's
Dec 25, 2007 | Alpine CDA-9807 CD Player
Hooked my punch Punch P450.4 up to speakers and ran rca cables to front and it wont work
Hi Jon,  you need to hook the Remote wire up to the Radios  Blue remote wire.  The car battery power stays on all the time.  The blue Remote wire watches to see when the radio turns on, and signal the amp to turn on as well.
Dec 12, 2006 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Car Audio & Video Logo
29 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
