Mitsubishi VS-60707 60 in. Rear Projection Television
Problem for Mitsubishi VS-60707 60 in. Rear Projection Television
I have a Mitsubishi VS-60707
By monterey2000 on Sep 23, 2008
I have a Mitsubishi VS-60707 that won't turn on. Just prior to this it would turn on with normal audio but the video was very, very dark.
Same Problem
Dec 31, 2008
-   I have a Mitsubishi VS-60707 and when I press the power button on the remote, the TV clicks like it's going to come on but it doesn't the timer light just blinks. When I press the power button on the TV it doesn't do anything. HELP!!???-   cavarlosherr
Dec 31, 2008
-   I have a Mitsubishi VS-60707 problem, where my T.V will not turn on-   Guest
Best Solution
posted on Dec 27, 2008
Very Helpful)
Kylewillfixu
Rank: Apprentice
Rating: 100%, 1 votes
Try this nubs.
Take the speaker panel off, and then the other black panel directly underneath exposing the guts, there should be some multi colored wires exposed that go to your power on and volume up and down, whatever... follow the wires up underneath, they go in the hole the panel was covering up.. (dont try to take the screen off just plain dumb..) there should be 2 white plugs connecting the to sets of multi colored wires just inside that go to somewhere in the back of the tv... Unplug them both big one first then push power on nothing should happen yet.. then unplug the second one wait about a minute or whatever plug them both back in and push power. it should come to life... remember not to touch random **** or you will get shocked to ****. MY vs. 60707 works fine now... (you might have to do this a couple times before the fuckin' passive aggressive ****** will work:)
form kyle c peace..........
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 23, 2008
Somewhat Helpful)
experttv
Rank: Guru
Rating: 88%, 108 votes
Most common thing on the model to cause werid problems such as this is a fluid leak. There are 3 tubes in that set a red, blue and green. These tubes get very hot so they have a coolant in them to keep them from melting. The seals on the tubes have been knowen to brake and leak some coolant on the board and as you know liquid and electronics dont mix. I would reccomend opening up the front of the tv and looking in with a flashlight to see if you can find any corrosion or fluid on the boards. Let me know what you find!
Tim Nolan
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi VS-60707 60 in.
Questions and Unsolved Problems for Mitsubishi VS-60707 60 in.
Do you recommend Mitsubishi VS-60707 60 in. Rear Projection Television?
Answer
Answer
Our Mitsbishi 60 projection TV picture keeps flipping when we turn it on. sometimes if we unplug it... (More)
Answer
my tv does not want to power on but green timer light blinks on
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Surprise, AZ
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
