Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
SimpleDrive Will not Run
I have a simpledrive poratable harddrive. I've only had it 2 months and it has worked fine up till a week ago. All the cords are in perfect shape. I have tried 3 different power outlets and 2 different computers and my hard-drive is not recognized. When I turn it on the blue light glows once and then it starts making clicking noises. I have tried all USB ports on both computers and it is still not being recognized. Any help would be appreciated as is I have all of my documents, music etc. on it.
buffy_729@yahoo.com
  • 6,831 Answers
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Posted on Dec 08, 2010
My SimpleDrive 320 is being recognized as "storage" with no drive letter designation. Ideas?
Connect harddrive to computer then when you power up the computer press F8 key 5 to 6 times then enter in safe mode then if still letter will not assigned then follow below.First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Apr 11, 2011 | SimpleTech 320GB SimpleDrive External by...
Is it okay to use a 14-17 volt power cord for a Simpletech External Hard Drive?
The SimpleDrive requires a 12V/2A tip positive power supply. A 14-17V supply might work, but you run the risk of damaging your drive.
Mar 31, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
What watt power supply do I need for 500GB SimpleDrive USB 2.0 External Hard Drive (designed by Pininfarina)?
The power adapter for the SimpleDrive is 12V, 2A, with center pin positive. I hope this helps.
Feb 17, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Transfered contents to a terabyte drive weeks ago. Not recognized
thats a file system related problem, try to download this file systems repair tool, let see if work. download data recovery wizard tool from this link. http://www.easeus.com/disk-copy/download.htm
Apr 13, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
External Harddrive Won't turn on
SimpleTech SimpleDrive Pininfarina 320GB External
I need to replace my ac adapter what is the voltage
6 volts or 12 volts
Dec 10, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Computer suddenly not reading external harddrive
I managed to fix it by unplugging the harddrive from the main electrical power source.
Nov 23, 2008 | Western Digital 500GB My Book World...
Isn't being read anymore
Please repair the master boot record(mbr) might be damage cause of viruses. If the harddrive detected in the CMOS there is no possible that can able to format the harddrive using windows utility such as XP Bootable CD or 98SE.
Hope this will be helpful to you.
Oct 25, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Mac does not recognize...
Haskel, Have you tried a different USB wire? Constantly remove of the cord can wear down the contacts/something is on the contacts? Check that I'll get back to you if I find anything relevant. Good Luck, Tim
Feb 07, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
Computers & Internet Logo
213 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Roshan Rijal
Roshan Rijal
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
