Question about Epson Dot Matrix LQ-590 Printer
LQ 590 POS
PRINTS ONE LINE THEN SEEMS TO JAM... STOPS PRINTING AND ALL LIGHTS FLASH UNIT IS FROZEN UNTIL POWER IS TURNED OFF AND THEN BACK ON
  • PRECISIONLAW Sep 24, 2008
    SRY SHOULD HAVE TOLD YOU IT HAS WORKED FOR YRS UP UNTIL THIS HAPPENED OUT OF NOWHERE THE OTHER DAY, ANY IDEAS?
  • paulo_bench Feb 17, 2009
    i have a LQ 590 printer but the problem is when i print only half of the documents was print and then all the light flashes..i already reinstall the driver of LQ 590..can you please help me..
  • 21 Answers
The driver for your printer is not installed correctly. please reinstall.
Posted on Sep 23, 2008
  • Laurentiu TUDOR
    Laurentiu TUDOR Sep 25, 2008
    exactly, you must reinstall your driver, because you must know where the problem is.
    you have: one computer, one printer and one cable. with such a problem describe upper, you must proceed by eliminate one by one.
    when you reinstall your driver: you eliminate the cable and many potentially problems that may came from computer.
    if reinstall works fine you may focus on your printer, just may defective one.
    also you may have a virus computer or something like this.
    are to many solutions for you. to many causes. you must eliminate one by one.
    tips: if your reinstall driver work fine, it may be a defective printer. solution: must buy a new one.
When printing continuous Quicken checks with the Epson LQ-590, the first check prints perfectly but the second check prints about 2 lines lower than the first check, then the third check prints 2 lines...
It can be the margins set within the printer defaults or the margins set by Quicken. In your print preview within Quicken you should be able to see where the margins are set and adjust accordingly. Otherwise, you may need to go to your Epson's print queue and adjust the properties directly on the printer. A nice way to check it is to see if you can print some test checks to plain paper and adjust as you see fit!
Dec 07, 2009 | Epson Dot Matrix LQ-590 Printer
Epson print LQ-590 always paper jammed at roller when printing continuous 5 sheet of paper. May I know how to fix this?
the paper you are using may be moisten. pls try another paper sheets . purchase new papers.
if the problem continue clean the paper feeder assembly roller with moist cotton using cleaning liquid eg petrol or spirit etc.
Aug 21, 2009 | Epson LQ-590 Matrix Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Epson LQ 590 Label Problems
Make sure the option for bidirectional printing is set correctly.
Try it both ways
Make sure you are not printing too far to the left or the right - the print head can hit the end of its run and lose its place.
Mar 27, 2009 | Epson Dot Matrix LQ-590 Printer
When printing document, half prints.
You didn't mention which paper feed you are using but I would guess tractor-feed Z-fold? If so, you may have a damaged sprocket drive.
If not, you need to remove the platen and check for paper scraps in the paper path and if you ever use the printer with labels, you may have some residue from the adhesive impeding paper movement.
Also check that you do not have the printhead positioned too close to the paper as this can cause drag that will cause paper to slip.
These printers are just about bullet-proof with very little maintenance.
Feb 06, 2009 | Epson LQ-590 Matrix Printer
My printer stops printing
I don't know how many hours your Epson has behind it but several printers in this series have some power supply problems relating to service hours and the decay of certain capacitors in the supply. Finding ones that need replacement requires the availability of a capacitance meter with DF (Dissipation Factor) measurement capabilities. Sometimes, a failed electrolytic will deposit some chemicals on the board around its base.
Feb 02, 2009 | Epson LQ-590 Matrix Printer
Screwy Print
could be a driver issue...
try uninstalling and reinstalling the printer driver
also make sure that the paper size that you are printing is correctly set on the driver..
you can either download the epson driver from epson.com/support or add the resident driver built in to your computer (if you are using xp)
Aug 22, 2008 | Epson LQ-590 Matrix Printer
Zig Zag problem
U would have installed improper driver. Try installing proper driver for ur printer.
Feb 26, 2008 | Epson LQ-590 Matrix Printer
Prints one line and stops
hello,
Every printer has inside Rollers that help the transportation of the paper during printing.
When the Rollers are faulty then the paper finds it difficult to move successfully during printing.
Also there is a motor that spins to rotate the Rollers.so i think any of these may be faulty.
Try and get a printer specialist to check it for you or you can come live chat with me and i will direct you..
Good luck
Jan 22, 2008 | Epson LQ-590 Matrix Printer
Epson Dot Matrix LQ-590 Printer Logo
287 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
