Question about HP Office Equipment & Supplies
Cannot run c6280 all-in-one printer from my computor, just got printer back from warrenty repair
    Scholar:
  • 145 Answers
Go to your start button, pick printer and make sure it is your default printer..Little check mark beside it..
Posted on Sep 23, 2008
  • 21 Answers
You may have 2 options:
1. if you use USB cable in order to connect your PC to the printer.
you may need to change to another port of USB cable from your computer.
2. if you use Ethernet port, (and/or pct. 1 does not work) you may need reinstall the driver for c6280.
3. if pct. 1 or pct. 2 does not work, you must go back to the service. (again)
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Hp 5100 printer, can you transfer pictures from your computor back to your printer in the sd slot to make an sd card for a digital picture frame
blnlsn,
No you cannot, but if you go to http://www.mcmelectronics.com and look under computer products you can purchase an adapter box which will plug in to a usb port on your computer and the box will accept just about any memory card on the market which you can then download your picture(s). Here is the link where your part is located http://electronics.mcmelectronics.com/?N=&Ntt=SD+card+writer&x=24&y=10 .
Thanks for using FixYa and for the great rating.
hardrocko
Dec 09, 2010 | HP Photosmart C6280 Printer
C 6280 Photosmart All in One would like to hook to our computor have the code to do so but not sure where to use same
Are you connecting the print using usb cable or in network. While connecting usb cable it will not ask ant code. I think you are connecting the printer in network.????
Mar 13, 2010 | HP C6280 All-in-One Printer
Ink system failure
The error is caused by air in your ink feed tubes. We have a guide posted on our web site at: www.ccl-la.com that will show you how to do a purge of the air and get back going. Look on the printer repair page and the the HP link. This will have to be done with a new set of ink cartridges.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 28, 2009 | HP Photosmart C6280 Printer
Our HP Photosmart C6280 All in One printer is giving me the Ink System Failure message, I have unplugged everything & taken out the ink cartridges & put them back in, same message...HELP!
Check out our web site at: www.ccl-la.com Click on the printer repair link, we have a section under HP that gives a step by step guide to fix your printer. The problem is caused by air in the ink feed tubes and the guide shows you how to purge the lines. You should be back printing in less than 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 25, 2009 | HP Photosmart C6280 Printer
HP Photosmart C6280 "Ink System Failure"
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 26, 2009 | HP Photosmart C6280 Printer
My HP C6280 says that there is a paper jam. I
dear sir this problem is your printer macanical
please open printer cover and chack clought unit spring tension
Aug 12, 2009 | HP Photosmart C6280 Printer
We have a HP Photosmart C6280 All in One Printer/Scanner/copier. We want to scan to computor.The menu only shows "scan to copy" and "scan to memory card" The manual that came with the...
If possible, find the software disk that came with the printer, and reinstall. One of the options should be to scan from the scanner to the computer. Just make sure that option is selected on re-install, and that the necessary communication cables for that option are installed.
Nov 19, 2008 | HP Office Equipment & Supplies
41 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
