Question about Mitsubishi WD-62525 62" Rear Projection HDTV
No power - Mitsubishi 62" WD62525
Wife turned off the set last night. Came home from work ....and no power !
I tried unplugging for 5 mins. Did not make any difference.
  • 3 Answers
You probably need to replace the lamp part #:915P020010. Hard to diagnose the exact problem without a more detail explanation on symptoms.
Posted on Sep 29, 2008
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
I have a mitsubishi 62" wd62525, I replaced all
When you unplug the set it then when powered up waits for the DM unit to boot up----the green light blinks on the front for about 70 seconds and when it goes out the set can be turned on.
If this is the case I have a suggestion, let me know if I have described the situation correctly.
SD TECH
Oct 25, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have Mitsubishi WD62525 for the past 5 years. Last week the lamp light came on RED and I replaced it with a newer lamp and the TV still doesn't work. The RED light continues to stay on. Any ideas on what...
check to make sure the lamp cover is pressing the lamp switch in it is at bottom right corner of lamp panel, also make sure lamp is set in properly,another thing to check is the lamp cooling fan panel on right back side,remove and clean filter and replace
Nov 28, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My mitsubishi tv has a blinking green light and tv wont come on. I have tried unplugging, resetting but the light continues to blink. My set is the WD62525 model.
maybe your tv is defective there is parts is shorted it cannot osolate. if you have a mitsubishi service center in your area ask the technician to fix your problem
Jun 19, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62 in 1080p turns on ,has sound but no picture
Your going to need to measure the various power supply voltages to see if its a bad main or power supply board
Nov 08, 2017 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
Aug 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking light
what is the model number of the set.?
if it is one of the wd62525 sets then the chassis needs to be rebuilt.
check out my site www.tv-techs.com.
let me know
Jan 04, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD62525 does not turnon - Lamp light on constant
Its more likely that the Capacitors on the power pwb have failed You can get the V26 Power board repair kit at the following link which has instructions. That is the most probable fault on your model DLP when the lamp wont light. Heres the link its listed under their repair kit category.
http://servicemanuals.vstore.ca/
Dec 21, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
