Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Memory card error
I have S 400 digital camra and two memory card to it and they both have same problem after uploading woth pictures once they both show memory card error for the second upload. I stop by in "Best Buy" were I bought the camera and they inform me that has a many problems with memory cards, who I can contact to get it fix
Sincerely Halina Skiba
  • Canon Master
  • 4,738 Answers
First remove battery and card and look in your flash card slot for any bent pins. If you see some, don't fret. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
If there are no bent pins, then the internal BIOS battery has likely run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Also, see the following link for tips on contacting Canon regarding camera advisories. This particular post concerns a CCD advisory, but the tips are the same:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Posted on Nov 01, 2008
One of the pictures has got a file error. it doesn't allow me to delet it and once that file error happens it makes all the pictures have a file error too. so i am unable to upload pictures becuase as...
FIRST OF ALL CONNECT TO YOUR PC UPDATE YOUR VIRUS DEFINATION AND SCAN THE MEMORY TO RULE OUT ANY VIRUS.AFTER BACKING UP ALL YOUR PHOTOS FORMAT THE PHONE MEMORY AND THE MEMORY CARD AS WELL. THIS WILL SOLVE THE ISSUE.
REGARDS.
PLZ. RATE THIS
Jul 02, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
I have two brand new Dell computers that have Windows 7 application. I just purchased a Kodak Easyshare C182 digital camera and can't upload to the computer. It keeps giving me a driver error. I have...
here is a another way to upload your images from camra to pc.your camra does have a sd or memory card? upload the images from m.mc through memory card reader
Feb 01, 2010 | Kodak EasyShare One Digital Camera
I cant seem to upload my pitchers form my camra to the computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 12, 2010 | Fuji Finepix Z20fd Digital Camera
How do i upload pictures from my camra when the computer wont recognize it?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 29, 2009 | Vivitar ViviCam 5022 Digital Camera
Camera memory is full. On upload, indicates no
There could be a memory card error or the Operating system may not recognize the entries on the device. Try connecting the card directly to the computer through a card reader. This might help. If not running a photo recovery software will get back your pictures. Check http://digital-assembly.com/products/adroit-photo-recovery/ and try running it on the memory card. After you get back all your pictures, I would recommend formatting your memory card, so you start off fresh the next time.
Dec 21, 2009 | Kodak EasyShare C330 Digital Camera
How do you upload pic to computer
Consider NOT connecting your camera to your computer.
Feb 23, 2009 | HP Photosmart R927 Digital Camera
Communication error when uploading pictures on computer
I had the same problem. My problem was that there were more than 1,000 images stored on the memory card. Once I deleted some of the images from the camera memory card, I was able to download pictures again.
Aug 10, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Camra memory card says write protect
Same here. So just simply changing the card makes the message go away?
Jan 29, 2008 | Olympus Stylus 710 Digital Camera
CARD ERROR
I fix digital cameras call 214-650-6531 or email me at mike@digitalcamrepair.com try formatting the memory card or removing the memory card and replacing it.
Dec 22, 2007 | Casio Exilim EX-S500 Digital Camera
Memory card I?O error
Try using USB SD-card reader to access the files. If it fails, you need a new card.
Otherwise, try formatting the card, and test it by filling it up with test videos and test images.
Oct 27, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
