Question about Funai PY90VG DVD Player/VCR
FUNAI DVD/VIDEO CASSETTE RECORDER WITH HDD (HDR-B2735D)
I only have just bought this machine but can not seem to get it up & running at all! & the manual is far too difficult for me to grasp. I just wan to try everything before I return the product as I am not at all sure if its the machine are just me being thick!
1. I have a Digital TV with intergrated Freeview but I canonly tune in the Funai into the anologue & not the digital channels, at all!
2. I have connected the Funai the same as my old DVD recorder which tuned into the Digital Channels.
3, Another strange thing is that the Funai says it takes DVD-R & DVD-RW dvds but although I have bought several different makes it keeps coming up as Disk Error. I hasten to add that a previous dvd disk,(that had already been recorded on) being the same make as some the blank discs that I have tried played ok
4. Can someone please help if only to explain in easy english (Very easy) what to do & try to get this horrid machine up & running, It would be much appreciated, Thanx!!
  • 2 more comments
  • Tina De-casas-canham
    Tina De-casas-canham Sep 24, 2008
    I think I may return this product (Good Advice!) but would still like to have ago at tuning it into the Digital Freeview as I want to see if I can get the HDD up & running also.
    The DVD-R & DVD-RW discs that I am using are brand new discs still in the packets & have no scratches or marks on them at all.
    With regards to the discs, What is a "Disk Doctor"?
    Here another funny thing with regards to the DVD discs I am using. One of the dics that I inserted & said "Disc Error", I used upstairs on my other dvd recorder to tape something (without amy problems). I have just bought the disc down & inserted it into th Funai & it plays ok, yet it wont recognise the same disc when it is blank????????
    Still very interested in anyone who can tell me how to tune in the Digital Channels.
  • 4,234 Answers
Becasuse of the fashion in which these units are manufactured, some slip through that have problems. Don't waste time on this. Return it for an exchange. DO NOT open up the unit as that will void the warranty and prevent the exchange. The laser in the optical assembly has a few functions that require different power levels or proper operation. Since the unit will read all discs, that portion of the unit functions properly. When attempting a record function, other portions of the optics assembly are engaged. That portion has a problem that was not caught at the factory. Return the unit.
Dan
Posted on Sep 24, 2008
  • 171 Answers
First, here is the Funai connection wizard
http://www.funai-corp.com/support/setup.aspx
/if this link does not take you to the Funai site, copy and paste it into the address line of your browser and hit enter
Let me know if you need additional assistance
  • 1 more comment
  • Todd Gale
    Todd Gale Sep 24, 2008
    As far as the disc compatibility goes, read this in your manual
    Finalizing a Disc
    • This will allow DVD+R/DVD-RW/DVD-R discs recorded on this unit to be played back on a different DVD player — without finalization it will not be playable on other units.
    • After finalizing a disc, you cannot edit contents on that disc.
    • DVD+RW discs is not required to finalize but to “Make Edits Compatible” to play on other units. You can edit the disc after “Make Edits Compatible”.
    Your disc error relates to:(Page 79 of your manual)
    --- Please eject the disc. ---
    Playback feature may not be available on this Disc.
    • Unplayable disc is inserted in the unit.
    • The disc is upside down.
    • Insert the standardized disc which bear the marks on page 41.
    • Insert the disc with the labeled side facing up.
  • Todd Gale
    For your freeview setup, go to
    http://www.freeview.co.uk/installation
    Here is the true disc compatibility chart for your Funai. Also, make sure the region codes are correct.
    This unit can record to DVD+RW/DVD-RW/DVD+R/
    DVD-R discs.
    DVD+R/DVD-R discs can only be recorded to once.
    DVD+RW/DVD-RW discs can be recorded to and
    erased many times.
    This unit will record DVD+VR mode automatically.
    DVD-RW/DVD-R disc will be recorded in the
    DVD+VR mode automatically in this unit.
  • Todd Gale
    Todd Gale Oct 03, 2008
    Please rate this solution.
  • 1,879 Answers
Brand new machine so dirt on lens is not an issue.
tried diff types of dvd's yet still getting same error.
either bad lens or the circuit board inside that translates the information read from the disc to show on the tv
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
yup!!! u try to return it
    President:
  • 1,952 Answers
Its not a big problem....this may cause due to problem in ur board soldering wiring connection..loose connection will also create this sort of problem...
follow this instruction to solve ur problem
1 Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
Step2 Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
Step3 Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
Step4 Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
Step5 Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem. Step6 Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
Step7 Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
  • 4 more comments
  • mohammed marika thambi
    mohammed marika thambi Sep 24, 2008
    else try this to fix ur pro
    We (gently!) used a cotton bud dipped in a little alcohol (Stolichnaya
    vodka to be precise) to clean the laser lense and the wrong disc error
    has disappeared, the dvd player is now playing discs again.
    thanks for using fixya
    rate this solution
    better ur not familiar with repairing electronic components means..at the same time ur not in warrenty period ....pls give it to authorised service center and fix ur pro...cost may be reasonable
    click this link..u ll get to know about disc doctor
    Disc Doctor','discdoc.com');">http://discdoc.com/
    disc driver can be overcome by followin step;...try it
    step1
    Check
    Step2
    latest DVD formats.
    Step3
    instructions.
    Step4
    Step5
    problem.
    Step6
    Step7
    the money.
    $('.Article .Steps .Image').each(function(i,e){
    e = $(e);
    e.find('img').error(function(){
    $(this).unbind();
    e.remove();
    better suggest with technician to overcome by ur pro..it may cause due to pro in ur dvd player board
    Sergeant:
    Champion:
  • 214 Answers
Try using old-fashioned 2x DVD-RW discs, eg the cheap ones from Datawrite.
This seems to work in my machine MOST of the time.
    Genius:
  • 1,847 Answers
Step1 Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD. Step2 Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats. Step3 Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions. Step4 Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device. Step5 Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem. Step6 Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab. Step7 Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
  • 928 Answers
Based on your reply on #3 I suggest that you dont even bother going forward. These type of DVD player recorders tend to be picky in the disks that it accepts. There is no way around that or fix for that so the best and simplest solution that I can honestly give you is to return the unit this early and save yourself the headache. (honest opinion) but if you want to work at it we can do so too.
Need user manual for Funai Video cassette HDD/DVD Recorder Model No: HDR- B2735D Please. Thank you
Try
mauritron.com
They have the world's largest library of
owners user instructions operating guides
and
technical repair schematics circuits service manuals
I'm not connected to them, just a satisfied user.
Also if you don't find your item in their listing then ask and they will get it for you
Sep 07, 2011 | Funai FDRV90E DVD Recorder/VCR
DVD/VIDEO
visit this site for owner's manual
http://tv.manualsonline.com/manuals/mfg/funai/ewd2203.html
Aug 21, 2008 | Funai Emerson DVD/VCR EWD2004
I have Funai HDR-B2735D. Will not record or dub to dvd. Replay from dvd ok. Record to hdd and tape ok
Do you get error code 03-56? Try cleaning all dust from the lens of the dvd recorder and cleaning the lens itself. It worked for me.
Paul
May 14, 2010 | Televison & Video
Can i override the copy protected vhs tape to copy to dvd using the Funai Dvd/Casstte recorder HDR-B2735
There are ways around macrovision, but you would have to spend money on a box of tricks and you would have problems copying using the DVD/Cassette with it. Some computer programs will get rid of it, but again you would have to spend money to connect the VCR to your computer. In the end I have found it cheaper and less time consuming to purchase the DVD. Plus it will be better picture quality, aside from the fact that copying such an item is against the law.
Apr 05, 2010 | Funai PY90DG DVD Recorder
Will not record all I get is Error 3-51
I had a similar problem, it turned out the first time I tried it I didn't have a DVD in the tray! Then I found I was using a DVD+R blank DVD and this machine needs DVD-R DVD's. It certainly solved my problem using the right blank disc
Jul 13, 2009 | Funai PY90DG DVD Recorder
Funai HDR-B2735D HDD/DVD/VCR how can i copy vhs to the hard drive
If you press the dubbing menu button on the remote it brings up your options so you can copy vhs to the hard drive , it will show you a list on your tv ,vhs-dvd. vhs-hdd which is what you want.Then click speed you want and start dubbing.
Dec 18, 2008 | Funai PY90DG DVD Recorder
connect the antenna or cable to the aerial jack of the funai. connect the rf out jack of the funai to the aerial jack of the tv .connect av1 scart jack of funai to scart
jack of tv.
The discs to try are cheap discs from poundland called mr dvd-r they seem to work
Sep 23, 2008 | Funai PY90VG DVD Player/VCR
I have a Funai HDR-B2735 dvd/video cassette recorder with HDD. When turning the machine on, it automatically switches off with the screen displaying the message "System error 02/56" before going...
Exact same symptom as above, little flashing "W" on standby, error code 02-56 on switching the unit on, promptly turns itself off. It would help no end if Funai would publish a little bit more info about these error codes on their site, or have a forum somewhere. Gona try a factory reset and a replacement HDD, dont know if i could replace it with a new one or not. any ideas or experience with these errors would be greatly appreciated!
Aug 18, 2008 | Televison & Video
Plz help!!...i have recorded a home video,and transfered it from vhs to dvd using the funai HDR-B2735 and dvd-R discs,but they wont play on any other machine?
Hi have you finalised the discs on the dvd part of combi? If you do this they will play in other machines that accept dvd-r
Jul 01, 2008 | Funai DV-220SL8
Funai PY90VG DVD Player/VCR Logo
323 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
