Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Need to replace the fuse. I don't know where it locates.
Refrigerator doesn't work. I think that I need toto replace tha fuse.
  • Anonymous Sep 24, 2008
    I'm having the same problem, My freezer is working and the refrigerator is zip.
  • 725 Answers
No fuse on kenmore refrigerators is it dead no lights nothing?
Posted on Sep 25, 2008
I need to replace the 100 amp fuse for a '92 Mazda
Hi, The biggest fuse to be replaced is a 30amp. I don't know what you have that is that big. Could be a relay you have. Usually under the steering wheel and left. Good luck.
Mar 11, 2012 | 1992 Mazda 929
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
My daughters TOTO toilet kepted running so she turned off the supply line before she went to bed. when she woke up the next moring and turned the water back on, now the tank won't refill. How do I know...
There could be several reasons why it won't refill. It could be the fill valve, which can be replaced with a standard fill valve located at any hardware store. The more likely reason is the stem inside the shut-off of the toilet has broken off inside the valve. This is very common when a valve is older and usually doesn't get shutoff. If this is the case, a new shut-off valve must be soldered on.
Aug 29, 2011 | Toto CST743S Drake Round Toilet
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter...
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter don't light up. Help!
Aug 29, 2011 | 1997 Honda Accord
There is a failure in the circuit of the heated oxygen sensor-bank 1 sensor 2. I don't know how to check the fuse since I don't know where it is located.
If you're getting a code for a heated oxygen sensor circuit problem, replace the sensor. I don't think I've ever seen a fuse be the problem. Bank 1 is located at the back of the engine compartment, close to the firewall. Sensor 2 is the sensor after the catalytic converter.
Aug 25, 2011 | 2002 Buick Rendezvous
I have a '93 jeep cherokee and my horn doesn't work. I've checked the fuse and it's fine but now i don't know where to locate the horn itself to check for disconnections or to replace...
LOOK UNDER THE LOWER AIR DEFLECTOR FROM BELOW THE RADIATOR. IF YOU HOT WIRE CAR HORN AND IT WORKS.YOU HAVE TO REPLACE THE WHOLE AIRBAG IN STEERING WITH HORN CONTROL BUTTONS.YOU NEED TO DISABLE AIRBAG IN STEERING WHEEL WHEN REPLACING AIRBAG AND HORN CONTROL BUTTON PAD.JUST TURN OFF RADIO FIRST, THEN DISCONNECT REMOVE THE NEGATIVE BATTERY CABLE.WAIT 20 MINUTES BEFORE WORKING ON AIRBAG AND HORN PAD IN THE STEERING WHEEL.
Aug 12, 2011 | Jeep Cherokee Cars & Trucks
The cooling fan doesn't turn on and is not the fuse i think is the rekay but i don't knoe were it is located
i think that it might be your fan relay also, they are located under the hood on your vehicle, on the drivers side, inside of a black box, i think that it might say power distribution on the box cover, or fuses and relays, remove the plastic cover and you will find the fuses and relays, i have a 2008 chevrolet cobalt, and the same thing happen, i replaced the # 2 fan relay, and presto, it was fine after that, good luck, and hope that this information has helped you.
Jun 20, 2011 | 2000 Jeep Grand Cherokee
Its working only in direct & stereo mode
maybe you need to replace a fuse?
is it hooked up correctly
Apr 23, 2009 | Denon AVR-1508 Receiver
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
171 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
Fred Sops
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
