Question about Xerox Office Equipment & Supplies
Need to add employee e-mail address to xerox 440st so we don't have to type it in each tme
    President:
  • 2,072 Answers
NOTE: Accessing the Public Address Book is optional. The Document Centre will accept a Public Address Book file that contains a list of user names and their E-mail addresses. This file must be Comma Separated Values (CSV) format for the device to be able to read the file contents. The majority of word processing packages will allow you to create a CSV file. A selection of e-mail applications will also allow you to export a list of users in the CSV file format.
The completed CSV file is imported to the device through CentreWare Internet Services. The file must have the .CSV file extension. A valid CSV file format includes the name and SMTP e-mail address. The CSV file should be created so that the Names are in one column and the E-mail addresses are in the next column. For example, the following are both valid format CSV file entries:
Smith, Smith@company.com
Smith, John - john.smith@company.com
The order in which entries are displayed in the Public Address Book at the Document Centre will depend on how the entries are sorted in the CSV file.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution, as it requires knowledge of the network’s email system. Configuration of the LDAP directory settings requires the network to support LDAP Services.
The Document Centre will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address). Before you begin, print a Configuration Report and make sure the Document Centre has an IP address and the HTTP protocol is enabled.
From the workstation desktop:
  1. Click on [Start], point to [Programs], and select [Internet Explorer] to launch Internet Explorer.
  2. Click on [File] from the toolbar, then select [Open]. The Open window will be displayed.
  3. Enter the IP address for the Document Centre in the Address: field, then press [Enter] on your keyboard. CentreWare Internet Services window will be displayed.
  4. Click on [Index] in the upper, right corner of Internet Services. The Index window will be displayed with a list of hyperlinks to different areas of Internet Services.
  5. Click on [Public Address Book ] from the list of hyperlinks. The Public Address Book Settings window will be displayed.
  6. Click [Browse]. The Choose File window will be displayed.
  7. Browse to the location of your Address Book File (*.CSV).
  8. Highlight the CSV file and click on [Open]. The path for your .CSV file will be displayed in the Address Book File (*.CSV) field.
  9. Click on [Import Now]. An 'Are you sure you want to overwrite the existing Address Book? This cannot be undone' message may be displayed. Click [OK] to import the address book.
    NOTE: You cannot import a .CSV file with a blank name or e-mail field.
  10. An Enter Network Password window may be displayed. In the User Name: field, enter the system login of admin, in lower case letters. In the Password: field, enter the system password, then click [OK].
    NOTE: If you do not know the system password, contact your administrator. The initial system password at machine install is 1111 for the Document Centre 460|470|480|490, and 22222 for the Document Centre 425|430|432|440. If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed.
  11. Click on [Map Existing Address Book] to identify which headings in the CSV file contain the name and e-mail address to use in the Public Address Book.
    NOTE: If the CSV file contains names and e-mail addresses only, the file may map automatically.
  12. Click on the [Display Name] drop-down menu under the Imported heading. Select the heading that corresponds to the data you wish to use as the display name in the address book. The data you selected will be displayed in the Imported Sample field.
  13. Click on the [E-mail Address] drop-down menu. Select the heading that corresponds to the data you wish to use as the e-mail address in the address book. The data you selected will be displayed in the Imported Sample field.
    NOTE: If you are using a DC460|470|480|490, and if the CSV file does not contain a heading row, the drop-down menu will contain information from the first line of data in the file. For correct Public Address operation, the display name must map to a user name and the e-mail address must map to an SMTP format e-mail address, for example, name@domain.com.
    If you are using a DC425|430|432|440 and if your CSV file does not contain a heading row, the first row of data will be lost.
  14. Click on [Apply New Settings] to save any changes.
    NOTE: If you click on the [Clear All Addresses] button all entries will be removed from the current public address book.
  15. Click on the [X] in the upper, right corner to close Internet Explorer and return to the desktop.
Posted on Sep 24, 2008
How to delete an email address (destination) from Ricoh Aficio MP 4001
Open the web click the top box and make it "blue" by clicking on it (the box with the the www.)and type the IP address into it, click enter. On the web image monitor page sighn in an admin no pass word (upper right) and click address book and you will be able to do it. - Carl
Apr 01, 2014 | Ricoh Aficio GX5050 GelSprinter InkJet
Tip
How to setup your email into your iPhone
First, you need to know your IMAP incoming and outgoing mail servers. These servers can be provided by your email service provider. Once you have these info, you may follow the steps below:
1.Go to 'Settings' on the main menu on your iPhone.
2. Click on Mail, Contacts, Calendar...
3. Select Add Account and tap 'Other'
4. Add mail account and then fill out the lines with your name, e-mail address and password then tap 'Save'.
5. Select IMAP and then use the information below:
* Incoming Mail Server *
- Host Name: type the IMAP incoming server
- User Name: type your complete email address
- Password: your e-mail password
* Outgoing Mail Server *
- Host Name: type the IMAP outgoing server
6. Tap Save button.
Thank you!
on May 03, 2010 | Cell Phones
Put ne back on g mail
Combine Multiple Gmail Accounts
You can combine multiple Gmail accounts into a single, primary Gmail account by using the POP3 Mail Fetcher application built into Gmail.
The Mail Fetcher enables you to retrieve email from POP3 email accounts, including Gmail, and send mail as if from a different email address all from within your primary Gmail account. Configure your primary account to manage your other Gmail accounts with the Mail Fetcher.
Sign in to the Gmail account that you want to use to manage your Gmail accounts.
Click the "Settings" icon, represented by a gear cog, in the top left and click "Mail Settings."
Click the "Accounts and Import" tab.
Click the "Add POP3 Email Account" button.
Enter the email address of your secondary email account and then click "Next Step."
Enter the password of your secondary email account and then click "Add Account."
Click the radio button beside "Yes, I want to be able to send email as
[SECONDARY EMAIL ADDRESS]" and then click "Next Step."
Enter the display name for your secondary email address and then click "Next Step."
Click "Send Verification" and then check your secondary email account.
Click the link contained in the verification email to confirm the integration of that account with your primary Gmail account.
All mail sent to your secondary Gmail is now delivered to your primary account, and when responding your secondary Gmail address is displayed in the From section of the email.
Access all your gmail accounts
http://www.businessinsider.com/how-to-merge-multiple-gmail-addresses-in-one-account-2010-12
Reset My Gmail Password
Google introduced Gmail on April Fool's Day in 2004.
The company first gave out 1,000 accounts to Google employees, friends and family members to test out the new email system.
Now, Gmail is a common and popular email application for users around the world thanks to its ease of use, high capacity and wide range of functionality,
Sign in to your Gmail account with your user name and password.
Click "Settings" in the upper right-hand corner.
Click on "Account and Import," then click "Google Account Settings."
A new window will open.
Click "Change Password" under "Personal Settings."
Type your current password, then type your new password.
Type the new password again for confirmation.
Click "Save."
http://mail.google.com/support/bin/answer.py?hl=en&answer=6567
Sep 08, 2013 | Computers & Internet
Adding e-mail addresses to address book
Read the instruction manual and proceed according if you do not have go for free download.
www. fitness.manualsonline. com or www. retrevo.com or www. eserviceinfo.com
God bless you
May 09, 2012 | Copystar CS-4035 Copier
Xerox 7345 Address Book
The problem occurs, only when the CSV file was edited and saved by MS Excel. The solution: use only Notepad, Excel never!
Feb 03, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Where is my printer IP address
The printer IP address is something you have to add. You can go to Xerox.com and go to support, type in your model number and then to support again.
Then enter IP in the search box and it will tell you step by step how to set it up.
You can set the printer up with a USB cable and it will skip that all together.
The reason it is asking you for the IP address is so it can find the printer and automatically add it.
If you need help. e-mail me at rak458@aol.com I will try and help you that way.
Dec 22, 2009 | Xerox Phaser 6125 Laser Printer
Help with Xerox DC 440ST Machine
This problem can only be cured by a Xerox engineer or by someone who has access to a Xerox laptop. You have to have a special program called AltBoot to be able to reload the software.
The only other way is to replace the SCSI hard drive in the ESS (network controller unit) with one that has been pre-programmed.
Sep 10, 2008 | Office Equipment & Supplies
Replacing an IDE HDD in a XEROX DC 440st
congrats you have done great job solving the problem for hard disk error.
Could you please share same to me also?
pmbajracharya@gmail.com
May 25, 2008 | Office Equipment & Supplies
Deleting names in the e-mail section
Utility button on panel
Chose: One Touch Registration
Then: Scan
Then: Address Book
Then: Email
from there you can edit create and delete email addresses.
Feb 19, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
1,631 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
