Question about Lands Phones
I have a Panasonic KX-TH112. It showed an error and I disconnected it for a while. Now it will not charge at least it does nothing.
  • 5 more comments
  • dougsaleeby Nov 16, 2008
    My kx th112 is having power problems, too. It shuts off, etc. One thing I figured out is that removing the batteries from the handsets and putting them back in helps them charge.
  • Anonymous Dec 05, 2008
    My base unit died completely although it continues to charge the
    handsets.. It's been in operation for less than 8 mos or so. Should I be sending this for warranty repairs ? Any suggestions ?
  • HandyHank Jan 10, 2009
    Mine is about 2 years old and the base just suddenly died. Power is OK. I am considering opening it up to see if there is anything obvious (like a fuse) that I can repair.
  • gloran Jan 14, 2009
    Do you think a repair service that Panasonic recommends can fix the KX-TH 112.  The base does not charge on mine as well.
  • smillers Feb 19, 2009
    My handsets gave the same error. The base station had the "answer on" LED flashing rapidly, but the LCD display was blank. After disconnected the working power supply and reconnecting, the base is completely dead. The unit is less than 6 months old. Does anyone know the warranty for the system?
  • stereotim Apr 18, 2009
    Had the same problem Solution worked for me too. Just took the power cord from one of the extension phone chargers and now the base works.
  • Anonymous May 20, 2009
    The Solution worked for me, too! so happy now. Thank you.
Exchange the power supply from one of the satellite handset recharge units. The power supplies are same model number. In my case the base unit would not show any power. When I exchanged it with the satellite power supply, the base worked properly and the old base power supply would actually work fine with the satellite charger. . . probably because the satellite charger has less power requirement. Also, my system had some noise in the line prior to the failure -- for about 2 weeks. This solved the noise problem as well.
Posted on Feb 23, 2009
How can you fix a no screen problem on a Panasonic KX-TGA101S?
Maybe this will help. You can download the manual here:
http://phone.manualsonline.com/manuals/mfg/panasonic/tga101s.html
Panasonic is always helpful when it comes to support for their products so give them a call.
Aug 14, 2014 | Panasonic KX-TGA101S Cordless Handset
What is Error 32 on a panasonic KX-P8000 / 8420.
Error 32 on Panasonic KX-8000 / 8420 is ALSO a "Memory Error". Try to power cycle the multi-function printer by turning it off, disconnecting the power cable from the wall socket and leave it disconnected for 10 minutes. Then plug it back in and turn it ON.
If the same problem occur, then you need to contact the manufacturer for service. It the problem remains after the power cycle, it means that it has a deeper problem.
Thank you and good luck!
Nov 06, 2010 | Panasonic KX-P8420 Laser Printer
Call service 3 panasonic kx-fl612
hello sir i have panasonic fax kx-fl 612 error code is call service 3 pls help us how i can run my fax plz
Jun 24, 2010 | Panasonic KX-FL611 Plain Paper Laser Fax
Panasonic Kx th112 sceen is dead answer light blinks red
Try swapping the AC adaptor from one of the handsets with the adaptor from the base unit. That fixed my problem.
Jul 21, 2009 | Lands Phones
Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
Jul 16, 2009 | Panasonic KX-TGA101S Cordless Handset
Panasonic KX-TG2258 with E1 ERROR CODE
I was having that problem after cleaning the base and handset. It seems to resolve itself simply by disconnecting the power supply and possibly the phone input line for several hours. I reconnected my phone and it works again.
Apr 14, 2009 | Panasonic KX-TG2382B Cordless Phone
My hand set is not working even after charging
you need to flash your mobile. And it will be online again :)
Feb 27, 2009 | Panasonic Phones KX-TG5571
KX-TG6051B panasonic cordless phone - lcd screen doesn't work
I am just now having the same problem tried everything short of taking it apart. got six years out of it.
Nov 01, 2008 | Panasonic KX-TG5632 Phone
Lands Phones Logo
434 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
