Question about Belkin Computers & Internet
Ball in Mouse is blistered -- WON'T ROLL RIGHT --- need a new one --- F8E812-BLK --
  • 706 Answers
Not worth replacing the ball.. consider buying a laser type to replace it.. ( no moving parts and not mechanical) much more reliable..
Posted on Sep 23, 2008
Can I fix the roller in my wireless mouse?
Open the mouse. (Slide the panel on the bottom that surrounds the ball, and pull the ball out. Clean the ball and the rollers inside the mouse with rubbing alcohol. Remove all debris, hair, lint, etc.
Voila!
Sep 26, 2014 | Computers & Internet
Won't scroll down but will scroll up, have tried turning it upside down & rolling the ball around but it didn't help
Have you tried cleaning out the inside where the ball sits? If you flip your mouse upside down you should see a circle around the ball that should have "open" and "close" arrows. Spin the circle towards open and once it stops spinning flip it over -- the circle and the ball should fall right out. Take a look at the 2 straight bars that sit on top of the mouse ball -- one is for horizontal movement, the other for vertical. Most likely, there is a buildup of dust and debris on them (it will probably look like a grey spot that covers the center of the bars). Remove this debris with your finger-nails (as they will not scratch the bars themselves) and then wipe them with some rubbing alcohol on a paper towel. Once the bars are clean, drop the ball back in, and put the circular cover back on (don't forget to lock it in place by spinning it to "close".
This SHOULD resolve your issue. If it does not, there may be a problem with your mouse's movement sensors ... which would most likely mean that you should buy a new mouse (they are pretty inexpensive these days). If you have to buy a new one, I recommend grabbing an optical mouse -- it has no moving parts and will prevent this problem in the future.
Jun 07, 2011 | Apple Mighty MA086LL/A Mouse
I can't scroll well using external mouse on laptop Dell inspiron1525, how can i fix this??
The problem is from the external mouse if your mouse is a ball mouse roll the ball round with your hand to ensure that it rolls freely clean all forms of dirt on the mouse and around the ball
If your mouse is an optical one wipe the optical surface with a clean cloth or cotton wool.
always ensure that you use your mouse on a smooth surface for proper scrolling.
Aug 21, 2010 | Dell Computers & Internet
Rollerball on Wireless mouse keeps getting gummed up. Cleaning done frequently but need to open mouse to get inside cleaned ?
The Apple wireless mice aren't made to be disassembled, not even by techs. If you disassemble it to clean it, you must glue it back together.
The best way to clean the rollerball is to remove the batteries and roll the ball upside down on a cloth soaked in alcohol. Be sure to roll the ball alternately depressed and not depressed for the best cleaning, and roll it in all directions.
When this no longer works, you can either attempt to clean the ball yourself at your own risk, or purchase a new mouse.
Nov 25, 2009 | Apple Computers & Internet
Scroll Button does not work
Take the mouse off of the computer. Turn it upside down on a piece of clean printer paper, so that the scroll ball is touching the paper. Roll it around briskly on the paper. This will help clean off the scroll ball.
Mar 30, 2009 | Apple Mouse
My mouse cursor does not move when I move my finger across my mouse.
I'm assuming you're moving the whole mouse, and not just using something like a trackpad. Pick up your mouse, and turn it upside-down. If there's a ball, grab a can of compressed air, squirt it into the edges around the ball, and roll the ball around. If there's a piece of glass, there's supposed to be a red light, called a laser, coming out of that. If there is no light, you'll need to get your mouse replaced.
Dec 03, 2008 | Computers & Internet
Mouse does not roll, I have to keep jerking it ans it is all over yhe pc
reset the speed viacontrol panel/mouse
check the hookup and ensure it is securely plugged in
if wireless mouse--install new batteries
clean the mouse ball if a wired unit.
you furnished a small amount of data too assist.
Jun 22, 2008 | Computers & Internet
Marble mouse USB
The trackball can be removed by pulling up on it a little to the right or left of center.
May 15, 2008 | Logitech Optical Marble Mouse USB PS/2
Mighty Mouse won't scroll down
I have had the same problem on occasion.  I found that if I turn the mouse over and tickle it...  It works!  Only kidding...
Turn the mouse over, push down hard so the ball is depressed, and move it vigorously in all directions.  That usually dislodges whatever is trapped inside.
Dec 19, 2007 | Apple Mighty MA086LL/A Mouse
Computers & Internet Logo
18 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
