Question about Sony Computers & Internet
Computer does not power on
I'm not able to power on my computer. Is there a fuse or something?
  • 1,124 Answers
Could be the power supply, the power button, the connector on the board, or the motherboard. Try taking out the battery and see what's happen.
Posted on Sep 23, 2008
Dell computer wont start up
Tough one, but inspect the motherboard for a blown capacitor. You could test the power supply with a simple voltmeter. Not to mention simply seeing anything lit with the case open while powered one. gl
Dec 12, 2012 | Dell OptiPlex GX280 PC Desktop
2000 grand prix blows 10 amp ecm fuse as soon as you turn the ignition on
According to the wiring diagram on autozone's website, that fuse only powers the computer. The computer controls several components by grounding them.
It's possible something has shorted out the circuit board inside the computer.
You could unplug the computer and try the fuse again. If it blows there is something in the wiring harness between the computer and the fuse.
On most models the computer is behind the glove box or on the passenger side of the engine compartment.
Jul 18, 2012 | 2000 Pontiac Grand Prix
Inspection station cant connect to my computer on truck
check your cigarette lighter fuse that fuse usually powers your computer port
Nov 12, 2011 | 2004 Ford Explorer Sport Trac
Trying to locate the fuse that is for the power steering for a 2007 Chevy Equinox....battery needed to be jumped and lost the power steering
Before continuing with your power sreering problem, please review these articles:
Where's The Fuse?
What Else Could Be Wrong?
The fuse for the Electronic Power Steering (EPS) is marked "EPS" and is located in the underhood fuse block on the left side of the engine compartment. It is an 80 Amp fuse. If this fuse was blown as a result of jump-starting the engine, something must have gone terribly wrong! Like - maybe the cables got hooked up backwards or something? You probably have some serious computer system damage...I would get prepared to spend some BIG BUCKS!
Apr 12, 2011 | Chevrolet Equinox Cars & Trucks
Why would my ecm fuse blow?
Well if you are lucky the power supply wire to the ecu is shorted to ground and the fuse saved the computer. It could be the computer. Also it could be something the ecu supply's power to shorted to ground. Get a wiring diagram and a ohm meter and start testing.
May 18, 2010 | 1991 GMC Sonoma
I have a Creative Gigaworks S700 (subwoofer) with no power out. LED off. Fuse ok.
first fuse as standard is in the plug to the power adapter. The second fuse is located at the back of the box where the power lead goes into. It is covered so look closely you just need something flat to open it. I have the S750 and that is what im basing this on but if the s700 is the same then you will find this helpful. Sorry did not notice this before.
Hope this helps.
Dec 11, 2009 | Creative Labs Gigaworks S750 Computer...
Cambridge megaworks 250D won't power up.
Yes, Hi there, as junk996 say, check for the FUSE , and carefully see if burn, or something is bad waired, other than this, if you can RMS the unit is better, or with warranty.
If not, check with s tech guru , for open the panel and check cables, or broken wires. (board inside the sub)
good luck!
Open Sky+
Jun 20, 2009 | Creative Labs MegaWorks THX 250D Computer...
well first is there a fuse you state fuse available not that one is there -----the surge didnt blow the breaker or fuses either if currant made its way to your components --as to why fuse didnt blow --- no fuse ---surge came through ground --surge blew something before fuse blew your case blew power supply
Jul 21, 2017 | Gateway 180Wt Power Supply NPS-180EB...
Monitor power suppply
hi there, check the hardware of the monitor, do some test at the power supply., i.e. fuse, resistors, transistor, etc., have some check up for cold solder. ty
Feb 17, 2008 | Computers & Internet
No Power to Sub
If you think the fuse is blown replace it take card you use the right one (fuse) then see if it goes.
Aug 31, 2007 | Level 9 Sound Designs MM-1000 Computer...
Computers & Internet Logo
127 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
