Question about Astar LTV-19BG TV
ASTAR 19" LTV-bs/bg HD/TV
Moving vertical lines right to left; black, green, pink, white, red etc. no sound, no controls on tv or remote work. happened to 2 tv's simultaneously. sound only when plugged into cable. turns on when plugged ino outlet.
  • CMV89 Dec 20, 2008
    I have the same problem, only I don't have the unit's original remote. Any suggestions? I've been trying to find a remote for sale but Astar is no longer in business so that makes things really difficult...
  • Anonymous Dec 31, 2008
    There are vertical colored lines across the screen. Can't turn the TV on or off with the remote or the buttons on the TV. I guess this is the same problem that everyone else has.
    Problem Solver:
  • 28 Answers
If you still can't reset your TV by holding the enter button please call my friend at 323-767-6030 he may help you go through it.
Posted on Dec 09, 2008
Astar 27" TFT LCD TV, Model LTV-2701
go to www.vancebaldwin.com and enter your model number and purchase a factory replacement
Nov 25, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Display Issue; Sound, but NO Picture!
if you have cable tv try unplugging and plugging in that cable if that doesnt work you might have a bad cable. check for damage along the cord or bends in the metal ends sometimes that can also be the problem
Jan 09, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Unerversal Remote Codes
Astar got sued by Philips and went out of business. Astar owned themselves rather then having a reproduction redesign of another set. They were a cheap Chinese company that made stuff for Compusa. I've repaired a couple of their sets and they're easy to work on but a little under built. So chances of matching the remote code up to another tv code will be left to guess and check. On some remotes you can enter a setup where you can press the power button over and over until you find the right one, then press another button such as enter or select to lock it in. See if your manual says anything about code search.
Jun 20, 2008 | Astar LTV-19BS 19 in. LCD Television
Astar LTV-2701 27
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jun 01, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Vertical lines in my LTV 19bg tv different colors yellow, blue, pink,white, black, no image only vertical lines with sound
need to reset the remote. Point remote at TV and hold down enter button for 10 seconds.
May 13, 2008 | Astar LTV-19BG TV
Astar LTV-19BS 19" TV -
I contacted the retailer from whom I purchased the TV and he was able to advise me on the fix. He told me that the problem is the remote control, which has to be reset.
To do that hold the Enter button down for 10-seconds, the remote and the TV should reset. It worked just fine for me.
Mar 25, 2008 | Astar LTV-19BS 19 in. LCD Television
Astar ltv 19bs lcd
If you still have the TV, the remote has to be re-set. Hold the Enter button down approximately 10-seconds. It should re-set itself.
Jan 23, 2008 | Astar LTV-19BS 19 in. LCD Television
MY ASTAR TV screenshows vertical color bands and its non responsive
Dec 08, 2007 | Astar LTV-19BS 19 in. LCD Television
Astar LTV-19BG TV Logo
134 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
