Try first resetting the camera or you can also update the firmware of it because this can also be a problem with the firmware of the camera that's why the flash is not working...
Did you replace batteries and also did you clean the battery contact ?
If you have done above things still your problem exists then You need to have a check over the bulb it might have burnt out .
You need to replace Flash Circuit of your DSC-S730 Cybershot.
Its part number is A1444049A (ST Block Assy) and its available at Part Store , price is approx $69.78
You must verify how you set the flash: auto, on or off. Set it "on" and try it. If it not work so, it's out of service. In "auto" mode it's possible to not work sometimes because light sensor.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
When shooting MPEG movies.
When shooting in the Twilight or Handheld Twilight mode.
If shooting with the Burst or Multi Burst mode.
Shooting with Sweep Panorama.
Shooting with the Fireworks or High Sensitivity mode.
If an external flash is connected.
Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
If the issue persists, please reset the Camera and make sure that battery is fully charged. You can use the initialize option on the Menu to reset the Camera. If the issue persists after performing all the above mentioned troubleshooting steps, service is required. Please let me know if you require any further assistance. Thanks for understanding.
It is common problem with Sony DSC-S730 camera and flash board will be replaced to fix it.
I can provide you required flash board part number info if you can replace it by yourself or take it in to local camera reapir tech.
Let me know if you have additional question.
Thanks.
It is common problem with this model and flash board will be replaced. Part number of flash board is as under.. A1444049A... ST BLOCK ASSY Available in Part Store. If you are not comfortable with replacing flash board then take camera to qualified camera tech as camera will be apart for flash board replacement. Thanks.
1. You can not use the Flash when the Camera is set
to Burst or Multi Burst mode.
2. You can not use the Flash when the ISO
or Twilight mode is selected in the Scene Selection.
3. You can not use
the Flash when mode dial is set to Movie.
Also try these steps and check:
4. Ensure that the battery is
fully charged and the flash is turned ON.
Please set the Landscape mode
or Snow mode or Beach mode in the Scene Selection and check if the
flash is working.
5. Try initializing the Camera and check if it works
normally.
NOTE: Initializing
the Camera will reset the settings of the Camera to the factory
settings including date and time. It will not delete any data saved in
the Camera.
6. Please press the Menu button on the Camera. Then, select
the SETUP menu and select the SETUP 1 option of the Camera. Then,
select the Initialize option to OK.
7.
Try to power reset the Camera and check if it helps to resolve the
issue. I suggest that you reset the Camera by removing the battery from
the Camera and inserting it after 1 minute.
8. If the issue still
persists then the Camera requires service.
Its known problem in DSC-S730 Sony Cyebrshot and you need to replace Flash circuit board in camera. If you have experience of camera repair then you can do it yourself. Get flash circuit board by following part number from Part Store. A1444049A ST BLOCK ASSY Good luck.
I had the same problem with my flash not working on any setting, but I found a way to fix it: hit the menu button, make sure the "rec mode" choice is set to normal instead of burst. I think the burst mode takes multiple shots in a row, so the flash isn't compatible with that setting?
