Question about Garden
Pressure washer, john deere 3000 psi, honda engine
Engine runs fine, no problem, water pressure builds up and then goes down up and down sometimes it will be fine for 15 sec then no pressure,
  • Anonymous Mar 03, 2009
  • Efrain Vazquez Jun 25, 2013
    you need a new pump
  • 97 Answers
It sounds like your intake is plugged with debris. What usually happens is a water hose that has been laying around will get various stuff in it -- dirt, grass clippings, small insects (and whatever they take into it nest building). These days most homeowner pressure washers do not have a proper inlet filter, but just a screened hose washer like on a washing machine. The unloader valve can cause pressure variance, but usually not in the manner that you described. The pump is being "starved" for input water. Just use a pair of needle-nose pliers and pull out the screen and clean it or replace it.
Posted on Feb 21, 2012
  • 1,388 Answers
Pressure variance is caused by the unloader/pressure regulator valve or slipping belt on belt drive systems. Worn packings in the unloader will not maintain pressure. Try lowering the pressure to 1000 psi then slowly increase until problem reveals then lower pressure again to maintain steady stream. This problem can also develop if the wrong size tip is used in the gun. Example, if output rating is 3000 psi at 4.5 gal per min and you are using a tip for 3000 psi at 4 gpm. The unloader will release causing variance of pressure. Easy way to lower pressure of system is to increase the size of the tip to 5 or 5.5 gpm in a system rated at 4.5 gpm. Enjoy
Posted on Dec 02, 2008
No pressure build up
try to clean the engine....
Apr 19, 2013 | Honda Pressure Washer PSI 3000
Pressure washer cranks and runs fine but wnt build up pressure.
there might be a broken piston in the pump.
you will need to check each one & replace the faulty one.
Dec 18, 2010 | Honda Pressure Washer PSI 3000
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
Husky ran great for couple of hours. Now no pressure at all. Water comes thru for suds, but no near enough. Engine runs fine but will not build pressure. Checked for trash blockage-all clear. Thanks,...
Same old problem... water admitance valve sticking.
Remove the valve spool and clean the bore with crocus cloth on a dowel rod.
Replace O rings and lube lightly with plumber's grease. Reassemble... good as new!
The valve senses pressure and blocks further input water. It sticks in the high pressure position blocking water flow.
Aug 05, 2010 | Honda Pressure Washer PSI 3000
We have a Black Max 3000 psi with a Honda GC 190 engine and the water will not come out of the power washer anymore
cud b a few things 1.check filter 2.check 2 c if water is returning tru the over flow 3screw down pressure valve as far as u can
Aug 02, 2010 | Honda Black Max 3000 Psi Pressure Washer
NO PRessure
Hi It sounds to me like your unloader valve is stuck, this is the thing that is meant to move up and down when pressing the trigger.Please remove the unloader valve assembly and check for damage. If no damage is found then grease and lubricate this part and replace and this should work ok again.
Jun 15, 2010 | Honda Pressure Washer PSI 3000
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
My pressure washer works 4 a while then starts to sputter & dies?
I am going to suggest a tune of of the engine. Change the oil and oil filter. Check the air filter is clean and replace it if it isn't. A new spark plug.
Jul 05, 2009 | Karcher 2500 PSI Pressure Washer
Water comes through nozzle, but no pressure. it is a john deere, with a honda engine.
The engine doesnt matter. Most pumps are DeVille Bliss. Get the model off the pump and go to their website for trouble shooting information.
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
3,424 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
