Question about Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit
It doesn't run even with a charged battery pack.
While using my cordless to drive in fasteners on my deck, the power began to wane slightly and the bit broke inside the head of the fastener. The bit is a 2+ and is 3.5 inches long. I found another bit that was shorter, but the power wasn't as strong and the bit kept coming out of the fastener. So I charged the battery pack for an hour, removed it and charged the spare pack. I removed that before going to bed. In the meantime, I bought two extra bits that were identical to the one that broke. In the morning, I put on a pack and got zero power. I checked the trigger and it was set in the forward position. I don't know what torque to use, but that shouldn't matter, should it? Neither battery packs produce any results. I charged one for several hours but I still get zero power.
    Scholar:
  • 58 Answers
Dear T,     The problem here is not your driver, but what you are asking it to do.  A good rule of thumb for carpentry jobs is "Always use the right tool for the job!" I work in the carpentry shop at the metropolitan opera in New York.  We use 14.4v and 18v cordless driver drills only.  However, you should know that cordless tools are to be used for small, short jobs.  Once you subject a cordless tool to constant, repetitive tasks that require lots of power, the tool will suffer performance problems and may fail.  Your broken bit indicates that you are expecting this tool to do more work than it can handle.    When driving long (2-1/2" or longer) screws into very hard (most decks are made of pressure treated lumber at least 1" thick) material, the proper tool is a corded drill.  This tool is made to deliver constant force for long service cycles.   When driving screws over 2" into hard woods or other dense material, any cordless drill is only good for less than 6 cycles of use.  A 12 volt battery will give out after several drive cycles under this type of demand.    Unfortunately I think you have depleted your batteries life expectancy.  Most Ni-Cd batteries will only last 1 to 2 years under normal wear.  I think your batteries will need replacement or repair.  Good Ni-Cd repair centers are hard to find, but with determination and persistence, you may find a battery recycler who will replace the cells in your batteries for a fee of about 1/2 the cost of new batteries.  DeWalt batteries are not cheap, so you will have to determine your best choice.  To drive several screws into your deck, I would recommend a corded drill.  It will stand up better under the demand.      As for broken bits, heavy use will always take a toll on your bits.  They will break less if they fit the fastener perfectly.   Also care must be taken to drive the fasteners in perfectly straight, perpendicular to the work surface.    Remember the adage, "Always use the right tool for the job!".  Take one of the fasteners with you when you but new driver bits.  Check for the best fit to the fastener you want to use.   For decades the standard drive bit has been the "phillips" bit.  At the Met we only use "Robertson" drive or square tip wood screws.  They cost more but slip less, and the bits rarely break. Always select a bit that best fits your fastener.    I hope this solution brings you success in your projects.  Best Regards,  Michael Mittelsdorf
Posted on Jan 11, 2009
I have a GF28WW cordless framing nailer. The fan will not actuate. yes the battery is charged, yes the nails are in correctly, yes the gas cartridge has fuel. Any help would be appreciated.
Hey Deck,
these guns take a lot of power to run... your battery may appear to have the necessary voltage,, BUT, the battery may NOT have the amperage required to run the gun... Amperage is what "pushes" the voltage to make the gun work,,, If the battery is even a few months old..AND been through quite a number of charge/discharge cycles.. its probably time for a new one.. This is the nature of cordless tools.
Jun 12, 2017 | Air Tools & Compressors
BLACK AND DECKER CORDLESS POWER PACK FOR 12 VDC SLA BATTERY #243215 for a Grass Hog Cordless Trimmer
Sorry, but I haven't solved any problem. I'm still waiting on the experts to solve my problem from June 16 on my trimmer not operating even with new fully charged battery. As for your replacement, I would suggest retail stores that sell trimmers, such as Home Depot, Lowes, Ace hardware stores or maybe B&D website.
Jul 07, 2014 | Black & Decker String Trimmer Cordless 12"...
95 chevy g20 van started to lose power while driving and began to spit and sputter
Ck your alternator output, should be between 13.8 and 14.2 volts, A bad alt will cause the battery to discharge when driving, Once voltage drops to a certain level (9.8 I think ) the ecm starts to shut down causing all kinds of strange problems, like running bad ,trans not shifting right, even the radio ! It happened to me in my 95 chev p/u
Jul 31, 2012 | 1995 Chevrolet G20
I had a routine tire rotation and car alignment on yesterday. As I drove my car later in the evening, the vsc/ecm dash light came on, followed by the brake and battery light, radio and dash lamp lights...
Sounds like you lost the charge from the alternator.
When the alternator quits charging your battery light comes on and your car will run on battery power only...and only for a short time.
As the battery gets its stored energy used up...everything that is electrical will get slow or dim.
I'd check your alternator for proper operation and its drive belt...
Hope this helps...
Aug 14, 2011 | 2003 Lexus LS 430
I have an 18volt Dewalt XRP 1/2 inch drill. The drill has been working perfectly up until this morning when I took it froms its case. I was using it the evening before to screw in some 2 inch screws into...
Check electrical contacts in drill body where battery connects. Check wiring inside the drill, trigger and check also brushes. You do not have to invest 329, you can buy "body only" machine for few bucks and reuse your charger and battery packs. Juraj
Oct 20, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Problem charging makita batteries 18v li-ion
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 8 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. Buy Makita should definitely have a few words with their supplier before they become a liability!
Aug 16, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
GE 6.0 Dual Cordless Phones
No, the battery packs can not be ruined by leaving them in the charger. It is wise to keep both handsets charged up all the time. It won't hurt to leave them off the charger for extended periods..even several days. Of course, the amount of power left in any battery depends on at least two things: the amount of time since the last charge (yes, they do lose power just sitting) and the amount of use since the last charge. In this case, we are dealing with nickle metal hydride batteries and they do not develop a memory like nickle cadmium batteries do. Charge 'em up and just place them back there periodically or always. Not to worry.
Dec 29, 2007 | GE 28112EE2 Cordless Phone
Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit Logo
140 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
