Question about Pioneer CDJ-1000 CD Player
LCD won't work
The screen in the middle of the jog wheel faded and then turned off, the rest of the unit still works including the info screen. Has anyone any ideas?
  • 68 Answers
Sounds like a jog dial pcb fault or power supply fault to the jog dial, if you havent had it repaired you can send it to us.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 06, 2008
Laptop screen has gone blank
I assume that your laptop's display has been damaged. Are you sure that other things are working normally? If other components are working, then problem will be with the display unit. Try to repair or replace with new one.
Nov 28, 2012 | Compaq Presario CQ56110US Laptop
In my P1I touch screen not working? how to rectify?
just try this.. enter service menu by pressing jog dial up, *, jog dial down, jog dial down, *, jog dial down, *.
jog dial is rounded things at the right side of the p1, slide it up or down, follow the instruction.
then enter the menu hardware test, lcd test, write something in ur touch pad, if the letter u wrote visible it mean ur lcd fine.. so , just close the menu and its magic.... its worked.
Apr 27, 2010 | Sony Ericsson P1i
He middle of Jog Wheel is not working. It will not let me select options on my phone. The outside of the wheel works fine.
I had this same problem and I figure out that u can just use the enter button on the keyboard in place of the middle wheel button. It is the 1st button above the lower right corner message button.
Dec 01, 2009 | Samsung Blackjack SGH-I607 Smartphone
Can you help me
Sounds like you have a broken Sheet Switch. Basically, there is a circular piece of plastic which goes underneath the jog wheel, so that when you press the wheel, it activates the switch and stops the track / slows it down, and also puts the indicator on in the middle of the wheel. The part is readily available from Pioneer, and is a bit of a tricky fit, however is not the hardest thing to fit on the unit. However, it is the most fragile part of the player, and most common to fail if the unit has had physical trauma, eg dropping, spillage etc.
Feb 28, 2009 | Pioneer CDJ-800 Turntable
Left jog wheel on CDN *88 remote controller not working
Hi tmal004,
I don't have a technical manual for this unit, but I have worked on these before. They are fairly easy to dismantle, take care to apply even pressure when removing the jog wheel, use something like a butter knife (2 off) to slide under opposing sides of the wheel and gently prise up. Spare parts for this unit are available directly from Numark, however you can source them from elsewhere. you'll probably need to replace the transducer.
Good Luck.
Feb 13, 2009 | Numark CDN95 2-Disc CD Player
Pioneer CDJ-1000 CD Player jog wheel display
The only way of solving this is to bring it to repair shop and get a replacement screen.
Jan 30, 2009 | Pioneer CDJ-1000 CD Player
Cdj mk3 jog
Does the jog wheel lcd light up ?
Regards.
Paul.
Dec 27, 2008 | Pioneer CDJ-1000 CD Player
Cdj800 jog wheel stops working after 45mins
The drive motor on this unit is probably about to die, or the contact pad underneath the platter is damaged. In either case, you'll have to take it to a qualified service technician for diagnosis and repair.
- Optic
Digital Analog Therapy
www.repairny.com
www.1200s.com
Oct 05, 2008 | Pioneer CDJ-800 Turntable
CDJ 800 JOG WHEEL IS not working
sounds like the jogwheel sensor,if you havent had it repaired you can send it to us.
thanks.
May 06, 2008 | Pioneer CDJ-800 Turntable
Pioneer CDJ-1000 CD Player Logo
160 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
