New batteries in the remote and it still doesn't work. Used to work if I took out the batteries and put them back in. Do I need to reprogram or ??
If the remote works for sometime once the battery is put into , it means that the circuit is erratic as the frency seems to change from the set value. This can be a fault in the processor IC in the remote, a fault in the crystal or associated capacitors. Check also the IR driver transistor which can be leaking and so changes the output.
