The console has been given to my daughter but I'm not sure if I have the correct cables to connect to tv.The console has been given to my daughter but I'm not sure if I have the correct cables to connect to tv.
AnonymousNov 22, 2008
lols i have the exact problem as u...but im sure that i have plugged the cables correctly...the green light is activated but nothing happen...the screen is like...rusty metal in colour
AnonymousJan 20, 2009
same problem ! frustrating, i have 2 cables for it which i believe are correct, but when i fiddle around with the black one i can get a picture, but for about 1 second. not sure what to do same problem ! frustrating, i have 2 cables for it which i believe are correct, but when i fiddle around with the black one i can get a picture, but for about 1 second. not sure what to do
You can't post conmments that contain an email address.
The only way someone can get a PS1 to play PS2 games is if they modified a PS2 to look like a PS1. The hardware inside a PS1 is not powerful enough and not complex enough to run PS2 games. They would need to take a PS1, and take the insides out. Then take the insides of a PS2 and modify it so it functionally fit inside a PS1. This seems like cool albeit pointless way to modify your PS1 and PS2. Thanks for the question!
uhmm.....now that is a stumper..., ill ask u this: does the PS1 memory card have any space let on it? (is it full)...if not...well then, im at a loss =/
your slimline might not normally play the games Use swap magic it should have two discs one for booting PS2 games and one for booting PS1 games you simply put the appropriate swap magic disc and then the game you want to play
Are you inserting a PS2 or a PS1 memory card? PS1 games can't use a PS2 card because they don't "understand" how to read them. To save a PS1 game on a PS2 you will need a PS1 memory card.
I hope this helps, I assume this is what you are referring to with your question.
Your question is somewhat confusing, using a playstation 2 memory card, will have PS2 game saves on it, how would you play PS2 games on a PS1 from the save, you can't.
If you just mean you are using a PS2 card for a PS1, the way a PS2 card saves data is different to a PS1 card, so it probably won't work
You can use your PS1 memory cards in the PS2. You can only use the PS1 memory cards to save PS1 games that you are playing in your PS2. You can't save any PS2 game data to a PS1 memory card
