Question about Broksonic CTGV-5463TCT TV
TV won't tune above channel 12?
I have been using this television for 2-3 years with no problem until suddenly it will not tune channels above #12. It is connected to my cable through a CAT5 connection. When I use the remote to scan for a station, it actually stops on the channel number just above the one desired. For example, when trying to tune to Ch 55, it flashes the image at 55, but stops on 56, which does not have the image (just noise.) I tried to connect this to two other cables in my home and get the same result. Also tried the connection in the family room set, which tunes just fine and same thing. Any ideas?
    Top Expert:
  • Broksonic Master
  • 75,025 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Posted on Apr 15, 2017
3 Suggested Answers
SOURCE: My Tv suddenly will not tune to a channel
please help in unlocking my broksonic CTVG-5463GVC
Posted on Feb 09, 2009
  • 517 Answers
SOURCE: I have a Broksonic model
Good day!!!!
if you remote is universal???
you need to set up code....if you have a manual of your universal remote,,the procedure of setting the remote and the list ofbrand and model of different kind of TV that compatible to that remote control...
if you have more clarification and query just add a comment..
Thanks for using fixya...
Posted on Sep 11, 2011
How do I connect an external DVD/VHS player to an old Coby Cx-Tv1 television with no RCA cable?
It should have also an Audio in jack . Take a photo of it and go to some radio/tv parts shop for a converter. They know
May 17, 2015 | Coby CX-TV1 5 in. Portable Television
How do i tune the channels on a toshiba rc3910
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
Jul 10, 2011 | Toshiba Televison & Video
Tune in channels
Switch TV on
Press “MENU” on remote until 3 blue arrows appear
Press “VOLUME” keys to tune up or down (shown on blue bar)
When required programme is tuned, input required Channel number (appears on 2 green lines at top) e.g. 02 or 14
Carry on tuning and allocating channel numbers
Select “MENU” to clear or wait until it clears by itself
Channels should now be tuned to allocated numbers
Feb 21, 2010 | Televison & Video
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
Programming Channels
Your TV is likely set for "AIR" tuning rather than "CABLE" mode. In this case channels above 13 don't tune correctly. The tuning mode is adjusted through the setup menu (it's been too long since I've seen one of these to remember exactly how the menu looks). Once you set the tuning mode for cable, all the available channels should come in properly.
But you've said you have satellite, so you should have a satellite receiver connected to your TV, and you'd be changing channels there rather than on the TV. Your TV would be staying on channel 3 or 4 (if using the satellite antenna output connection), or on the A/V input you have the satellite connected to (if using the direct A/V outputs). Am I missing something about your system?
Feb 18, 2009 | Mitsubishi WS-73905 73" Rear Projection...
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
LN-R460D 46in, channels intermingled
are you using digital or terrestrial transmission? try fine tuning it...and hey, check the antenna direction, and also the wires...if the sockets are tight enuf and are correctly connected.
May 18, 2008 | Samsung LN-R460D 46 in. LCD Television
Tuning in the tv
Most TV's auto search feature will try both the Cable and the Air frequencies, but perhaps yours doesn't. Go to the menu page for tuner setup and make sure it is set on Air (might be called broadcast) and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
Jan 10, 2008 | Televison & Video
Suddenly cannot tune
Reset everthing in the menu. Mine does this every few months or so. I scroll thru the menu option until a come to a reset thing.
Dec 18, 2007 | Pioneer AirWave XM2Go Satellite Radio...
Broksonic CTGV-5463TCT TV Logo
52 people viewed this question
Top Broksonic Televison & Video Experts
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
