Question about Singer Inspiration 4210 Mechanical Sewing Machine
I removed the positiong plate
Ok so I removed it and I can't get the bobbin holder back on. I removed it so that I could figure out why the bottom thread kept bunching up while I was trying to sew jersey. So is it ruined forever or can it be fixed with out spending an ton of money?
  • Anonymous Oct 15, 2008
    My positioning plate was also removed (to retrieve a fallen needle) and I'm unsure if this can be resolved. Thanks in advance for any suggestions.
  • Anonymous Apr 11, 2009
    what is the hold down lever against the spring pressure
With the pressure foot up, and the bobbin holder in place (make sure it rides on the groove in the rotating hook that grabs the upper thread) push the locator or positioning plate to the left then tighten the two screws in front
normally the bobbin holder is removed & replaced by moving the hold down lever against the spring pressure counter clockwise so the bobbin holder can be lifted uo and out toward the operator.
Posted on Feb 25, 2009
I removed the posiotioning Plate(A). Singer Inspiration 4205. How can I get it back in?
Posted on Nov 17, 2008
The directions are very vague about how to thread the bottom bobbin. I have no idea how this is to be done or how the needle will pick it up. Help Please!
you don't thread the bobbin as such
wind sufficient thread on to the bobbin (use the rewind section of the machine )
place the bobbin in the bobbin carrier in such a manner that the thread unwinds anticlockwise
take the thread and pull it around the edge of the bobbin holder until you reach the slot in the holder
pull the thread down that slot and under the flat spring plate at the bottom of the slot
That plate controls the tension of the bottom thread
pull out about 5" of thread and while holding the thread put the bobbin holder and the bobbin into the machine making sure that it goes right in and clicks in place ( turn it to achieve the click
The needle should be fully up for this procedure
now thread the needle and hold the end of the thread while you hand turn the machine in the sewing direction
the needle will go down and if not on the first time will on the second time pull up the bobbin thread
pull that bobbin thread up and place it along with the needle thread under the foot plate and out the back comment if that doesn't work as there may be a bigger fault that can be fixed
May 27, 2016 | Sewing Machines
Problem with thread getting caught under bobbin holder
have you applied any lubricant to the bobbin holder the one that holds the bobbin? I would suggest using your manual and lube your machine. sounds to me like your mechanism is sticking.
Jun 08, 2015 | Janome Sewist 625e
Singer 8280 (prelude) I had 2 threads coming out from my bobbin area, so I decided to open it up and take a look. I accidentally took out the whole bobbin shuttle. The manual doesn't tell me how to...
Ok, hang on! This can get tricky! Remove the bobbin. Remove the presser foot and the needle. Remove the throat plate. This gives you plenty of room to monkey with your bobbin case. NOW, lay the bobbin case in its correct area and gently rotate it until it falls into place. It may take several tries. Once you're satisfied that it's secure, snap the holding clips into place and it should all fit nicely. THEN place your bobbin in the case correctly...check the diagram in the manual. Depending on the machine, some bobbins have the threads coming off counterclockwise and others have them coming off clockwise, but your manual should show. Sometimes, there's even a diagram on the throat plate or the bobbin case as well.
Good luck. Hope this works. If this solves your problem, please come back and rate my answer!
Jun 07, 2011 | Singer 8280 Mechanical Sewing Machine
I have an elna lotus sewing machine and have refilled the bobbin but cant remember how the bobbin goes back into its place. the machine will sew for awhile and then the cotton gets tangled .can you help...
Is this a Swiss made Elna Lotus with top loading bobbin (check machine plate on right beside power inlet for manufacture details) ? (the original Lotus was released back in 60's but that name has been reused on a number of different models since, some made under licence elsewhere) If yes, then the following applies:
Bobbin should have holes on one side only, always wind it with the holes on top and load it into the bobbin holder the same way so it is rotating anti clockwise when you pull the thread.
Drop wound bobbin into bobbin holder and, while holding the bobbin still with one finger, pull the thread tail towards you into the tension spring, then press down on the thread until you hear it "Click" into the tension spring.
Then hand wind the fly wheel towards you while holding the top thread tail to catch the bottom thread and bring it up to the top needle plate, close the back sliding plate over the bobbin.
Other thing with these machines is ALWAYS hold the two thread tails firmly when you start a new seam so the threads don't get pulled down into the bobbin holder area. Really important.
You can dowload a manual from www.arizonaexpressionz.com for most of the Swiss machines.
If it is not Swiss made one, then your bobbin may be vertical front loading (like the Brothers).
There are threading diagrams for lots of machines at www.sewusa.com, there might be one there that covers your machine.
May 22, 2011 | Elna Sewing Machines
Sews good on top but balls up on bottom.
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Mar 14, 2011 | Brother LS-2125 Mechanical Sewing Machine
The bottom tension is too loose and i can't figure out how to tighten it...is there a screw or something that needs to be turned?
First make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out. This might not be exactly the same as yours but should give you an idea of the position.
images?q=tbn:and9gctsx7tfg-qvx2b_xrsfrqdrbqtvimfbpccfean9z4xvqfq0xy_miw
Mar 04, 2011 | White Sewing 4042 Mechanical Sewing...
Bobbin holder won't stay put
If the bobbin case/holder is trying to lift up and the thread is staying partly around it, your bobbin case may have turned part way.
Remove the needle plate and the bobbin case. The outer edges of the bobbin case should be very smooth. I suspect you may see a needle hole in the flat area that was under the foot. If so, you will probably wish to take it to your dealer and show them. They may smooth it or recommend replacing it. When the bobbin case is placed back into the hook cup that it sets in, the retainer at the 11 o'clock position on it should only allow the case to lift up about 0.8 to 1mm at the most. If it will lift up more than this, press down firmly on the retainer and move it closer to the bobbin case. You must have enough room for the thread to pass between the retainer and the bobbin case, but too much clearance will allow the bobbin case to turn in the machine and it will be damaged by the needle.
Apr 09, 2009 | Husqvarna Viking 1
Anna had this problem with her Pfaff 332 sewing machine, I do too
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
Jan 30, 2009 | Sewing Machines
Pfaff 1222 Bobbin holder stuck with thread
With power off, take the needle out and the presser foot. Remove the two flathead screws that secure the needle plate from the machine and remove the plate. You'll have a top view of the bobbin housing and see the thread that's stuck to it.
Jan 30, 2009 | PfaFF Tiptronic 2030
I took apart my bobbin case, plate andbobbin holder. I can
I had the same problem and can't find my Owner's Manual. I found the answer on-line. Hopefully, you have the same type of bobbin casing. To get the answer, go to www.startsewing.co.uk and choose "How to thread a Sewing Machine". If you have the same type of bobbin casing, you should be able to figure out the proper placement of the parts by looking at the one in the demonstration. I am thrilled (!) and hope this works for you, too.
Jan 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Singer Inspiration 4210 Mechanical Sewing Machine Logo
414 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
