Question about Janome 8080 Computerized Sewing Machine
Bobbin winder has no tension
All of a sudden I cannot wind a bobbin because when I do, there is no tension, no matter how many different ways I try to do it, so the result is a loosely and tangled wound bobbin. What has happened? I have had this machine for two years, it has always wound bobbins perfectly. Help!
  • meghann5 Sep 24, 2008
    I actually finally figured it out, I had never noticed (I guess it had always done it on its own) that it actually clicks in place around the head that the thread winds around to go to the bobbin. Once I made sure it was clicking in, it worked great. Thank you so much for your reply!
  • 120 Answers
Are you sure you have the thread over the right place? it should be from the spool to the small metal wheel on the top of the machine and nothing else, also make sure your using a janome or s-class bobbin ( also it should be a plastic bobbin if it loads from the top of the machine and not the front ) when i fill a bobbin i also start out slow sometimes keeping my finger loosley on the thread itself before it winds on the bobbin to give it more stability.
Posted on Sep 24, 2008
  • Tally Girl
    Tally Girl Nov 08, 2011
    I agree; and would endorse what Andy says, keep your finger loosely onto the thread spool that you are winding off all the time - use the curved handle of a pair of scissors perhaps. You want to ensure that the spool doesn't bounce or **** as this will definitely impact on the winding you get onto your bobbin. Many manuals don't say this but it truely makes a difference to winding a bobbin. Check out my tip here if you'd like more info. http://www.fixya.com/support/r10598580-w...
What's your problem?
if the bobbin thread is winding around the bobbin winder spindle then
the bobbin is not sitting correctly on the bobbin winder spindle,,
the bobbin (metal or plastic) should lock in on the bobbin winder spindle
& the the thread should be around the bobbin tension guide
Apr 04, 2012 | Sewing Machines
Bobbin not winding tightly
Consult your owner's manual. Possibly, you are not threading the bobbin winder correctly. The thread does go through a tensioner somewhere along the way that creates tension on the thread.
Janome MEMORY CRAFT 9700 Instruction Book Threading For Bobbin Winding
Or perhaps the tensioner is not working properly.
If neither is problem, then you can always pick up a stand-alone bobbin winder (Amazon, JoAnn's, etc) for ~$30. One brand is called Sidewinder. These bobbin winders are marvelous because you can wind bobbins without unthreading your machine. It also saves wear and tear on your machine.
Or take your machine for service.
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
Bernina 135 bobbin winds unevenly
If you are finding that the bobbin is winding with more thread towards one edge of the bobbin than the other, the bobbin winder motor needs to be adjusted so that the angle of the winder shaft is properly aligned with the tension disc next to the head cover. Unfortunately, unlike many of the other models, you have to remove the covers on the Activa range to get at the adjuster. There is a spring-tensioned screw just to the left of the bobbin winder motor that adjusts the angle of the motor and therefore how it loads the bobbin. If the winder is loading the bobbin with most of the thread towards the bottom edge, the screw should be turned clockwise and if most towards the top, it should be turned anticlockise. Make adjustments until the thread is winding evenly or, at least, towards the centre of the bobbin.
If you are finding that your bobbin is being loaded somewhat randomly, make sure you are using the vertical spool holder to hold the spool and that you've got a foam pad under the thread spool. Route the thread through the thread guide before winding around the tension disc in the correct direction (see the arrow on the case) and ensure that the spool and thread do not vibrate unduly when the bobbin is being wound. If you let the spool vibrate whilst the bobbin is loading, it may result in varying tension on the thread and uneven winding onto the bobbin.
Oct 02, 2011 | Bernina Activa 130
I have a Freesia 425 - I have wound the bobbin successfully, but the bobbin will not come off the winder - any explanations
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
May 04, 2011 | Husqvarna Freesia 425
When winding a new bobbin, the bobbin itself is breaking in two. (splits in half, the top and bottom split apart). It seems logical that there is too much tension perhaps. It happens almost at the end...
There's really no way to increase the bobbin winder tension. Check to see that you have it threaded correctly for bobbin winding. There should be just a little bit of drag on the thread as you pull it over to prewound it on the bobbin.
May 03, 2011 | Brother PE-150V Computerized Sewing...
Bobbin winder plastic part came off, now it won't
You must put that black ring back on the sewing machine. It will not work without it. There is a groove in the black plastic part that lines up with the black metal "fin" that is in the middle of the bobbin winder. Put the "fin" in the 12 O'clock position and line the groove up at 12 O'clock as well and push it onto the spindle. It will "click" when you have it on all the way.
The reason it got pulled off is because the thread has too much tension on it as the machine was winding the bobbin and it crushed the center of the bobbin onto the spindle and the black piece that pulled off the machine. If you are winding the bobbin through the needle you must go under the presser foot, (always have the foot in the up position)and the foot must be a metal one and you DO NOT put the thread over the silver button like guide on the right side of the machine to wind the bobbin. That guide is a tension device that is used to put tension on the thread when you use the guides on the rear of the machine instead of the regular path through the needle. If you use the normal thread path through the needle and that button like tension device, it creates too much tension on the thread and wraps it too tightly on the bobbin, some it even breaks in half. You can also have bad stitching even if you get the bobbin off the machine because it can distort the shape of the bobbin which can cause it not to spool properly so you sewing tension of the bobbin is compromised.
Oct 12, 2009 | Husqvarna Viking 1
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Jul 29, 2008 | Elna Heirloom Edition 6005
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Jun 05, 2008 | Kenmore Sewing Machines
Can't wind the bobbin
Bobbin will not lock on bobbin spindle, what can I do?
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Janome 8080 Computerized Sewing Machine Logo
192 people viewed this question
Top Janome Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
