Question about Relic Watches
Relic Watch Fogged Up On The Inside
My Relic ZR77106 watch suddenly and randomly got fogged up under the face piece glass. It will un-fog if i apply hot water over it, but then it just fogs right back up again. I was wondering if there was any way to get under the glass face piece to wipe away the condensation that appears to be causing the issue. I just wanted to know if it was easy enough to do with the proper tools, so i do not have to bring it to a repair shop and get charged more than i paid for the damn watch. Please let me know if you have any suggestions. Thank you
  • 106 Answers
SOURCE: seiko watch
the seals are starting to go in it. i will have to take it apart and replace them(or send it into the dealer)
Posted on Jun 02, 2008
SOURCE: my nixon watch shows fogging
The problem is that water or humidity is getting into your watch. You either need a new back gasket 9 probibly nicked when changing a battery, or your crown ( the little piece used to change the time) gasket is bad, or you have a crack in your crystal. Turn your crown as if to wind it , if it turns REALLY easy your crown gasket is bad, if not you need to open your watchback and insert a new gasket around the back cover. Make sure that it fits tight ( you probibly have to stretch it a little) and then reclose the watch. The only place I know you can get a seal is at a watch repair shop.
Posted on Jun 29, 2008
SOURCE: My six-month old Casio watch
Take it back, the battery must have been changed sometime when it was in the store, and the back has not been sealed correctly. If the store won't take it back I would send to the company. If you don't want to do that, take it to a reputable watchmaker ( NOT A JWEWLER) and have them check out the seal, and how well the back was put on. If you have anymore questions, please feel free to ask. Good Luck!!
Posted on Aug 09, 2008
SOURCE: My casio Edifice (2747) EFA-110 has stopped
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf the setting guide u can refer from this pdf file :) mine is also EFA-110
Posted on Jul 23, 2009
escapement
  • 2334 Answers
SOURCE: water inside the watch
Click on my profile (escapement), then click on TIPS AND TRICKS. There you will find explanation about water/ condensation inside watch. Rate me, plz.
Posted on Feb 26, 2010
Broken Armani sign
Yes it can be fixed but may need a jeweller. You cannot take the glass face out on it own, you have to remove the watch back plate and then pull out the watch mechanism. (Once the back plate is off removing the mechanism is not difficult) You then have access to both the inside glass face and the watch face. If you can do this you will need to glue the Armani logo with something like super glue, but not applied directly to watch, too risky. If you have tweezers hold the Armani logo in them. Use a pin and dip it into a small blob of super glue, apply the pin to the back of the logo and then place it on the watch face as quickly as possible and align. Once aligned apply a little pressure with the tweezers on the logo to help adhere, about 5 seconds, leave to dry and then put watch back together. If this all seems to difficult a jeweller can do it in about ten minutes.
Jan 08, 2014 | Watches
Casio sea pathfinder fogged crystal. Worked in yard. No water exposure other than sweat. Advice please?
condensation inside a watch means the watch's internal temperature and humidity reached dew point.
The watch needs to be disassembled "completely" and dried out. Get the battery OUT! Get a can of dust remover spray and get it dry. You can use some alcohol and a swab to clean it too. But careful, alcohol may act like a solvent and the parts may melt. If its been a few days, it might be too late. If you don't have the tiny tools or patience to do this yourself, try a local jeweler. They'll tell you right up front if its shot or not...
May 06, 2013 | Watches
I have moisture in the center of my watch face. It is a circle shape, right in the center of the face. Looks like it is fogged up, like steam.
Hi Its condensation if its a watch with a button to set the hand then pull it out to its max and put your watch in a nice worm place over night would be good.
its important to get it dry as soon as possible to stop it going rusty
If this is useful please rate me
Yours ian
Mar 08, 2011 | Watches
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
Some of the numbers on my relic pocket watch fell off.
Unfortunately you will not be able to get the watch glass off without braking it. Watch glasses usually are friction set or glued into the watch bezel using special press or special glue. Both are of such a good quality, that it is allmost impossible to remove the glass without special equipment.
You can try, of course, but it will be on your own risk.
The best way is to find your nearest watch repair shop and ask for help.
Do not forget to rate, please.
Feb 10, 2009 | Relic Degrade Pocket Watch
Can't put (back) back on my timex indiglo
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
Jan 11, 2009 | Timex 27191 Wristwatch
Water build up inside watch face
Relic Returns
10615 Sanden Drive
Dallas, TX 75238-1720
Metro Service Center
10615 Sanden Drive
Dallas, TX 75238
If you have any further questions, please contact customer care representatives at (800) 699-3948.
Dec 21, 2008 | Relic 0504648FA
Seiko watch
Jun 02, 2008 | Watches
Watches Logo
355 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
Jim Parker
Jim Parker
Are you a Relic Watch Expert? Answer questions, earn points and help others
