Question about Cameras
I HAVE AN NIKON COOLPIX L4 CAMERA, I CANNOT TAKE ANY PICTURES BECAUSE IT IS SAYING THAT THE MEMORY CARD IS WRITE PROTECTED WAT DO I DO?
  • Anonymous Dec 04, 2008
    Ayup same problem for me.
My camera got a grain of sand in the card slot. ( Long day at the beach:-) ). Once I got that out, the write protected window went away, Yay!
Posted on Feb 05, 2011
Nikon coolpix memory card write protected
Check the memory card theres a little switch on it make sure its in the correct position
Sep 23, 2012 | Nikon Coolpix S3100 14MP Digital Camera...
Trying to transfer pictures taken on nikon coolpix L4 to apple imac computer. i have the cable plugged in to computer. camera says preparing to transfer but doesn't transfer. what can i do? i have...
Welcome to Fixya
Try the alternate way of transferring the pictures to your computer instead of using cable.
To download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer. Once the card is plugged in, it will appear to your computer as a removable drive. Just drag&drop pictures from the card to the computer's hard drive, the same way you copy any other files.
Thanks
Mar 06, 2011 | Nikon COOLPIX L4 Digital Camera
My memory card is saying that it is write protected what do I do?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 18, 2011 | Nikon COOLPIX L4 Digital Camera
My camera says memory card is write protected and I can't get it off to take pictures?
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 28, 2010 | Nikon COOLPIX L4 Digital Camera
Memory card is write protected
Hi..
Suddenly the card you have inserted is locked so that's why is says write protected. To unlocked the it get or remove your card from your camera. You can see in your memory card there is a small button her try to slide the button to unlocked. Insert your memory card back to your camera and try to take a picture it will take a picture.
Thanks for using fixya
Regards
PCmania
Sep 03, 2009 | Nikon COOLPIX L5 Digital Camera
I have a Nikon coolpix L4 camera and it will not work. I get an error message " memory card is write protected" can you assist?
Dec 28, 2008 | Nikon Coolpix 4500 Digital Camera
Digital camera problem NIKON coolpix l4
I have the problem by turning on... But the camera start when I press about 10-15 times on the switch. I think the problem is not coming from the switch because by turning of, it goes the first time.
I have tryied to take the batteries or/and the memory card out but it doesn't help. By taking out the memory card I never lost the pictures...
Jun 24, 2008 | Nikon COOLPIX L4 Digital Camera
Nikon Coolpix L4 Memory card problem
Back up all the pictures on the card and then format the card.. Everything will be back to normal.
Note: While formatting select FAT32 file system as it is more reliable..
Jun 18, 2008 | Nikon COOLPIX L4 Digital Camera
Memory card malfunction
Pictures can sometimes be recovered by sending the card to a service provider, or by downloading software designed to recover the pictures from the card. It is not clear weather the problem is the card or the camera, however to recover the pictures from the card would be the same process. If you do not have one you will need to buy a USB card reader to load the card on the computer. Consider buying another card to test in the camera, if you so wish. If the camera is new enough also consider contacting the manufacturer for warranty assistance. David Millier Advance Camera Repair
Feb 26, 2007 | Nikon COOLPIX L4 Digital Camera
Cameras Logo
125 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
